Pictorial discussion of charging, testing, removing, & replacing the BMW E39 battery - Page 2 - Bimmerfest - BMW Forums
Old 09-21-2012, 10:35 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Here's a discussion today, covering venting even on the 'sealed' batteries, which may be of interest to others:
- > E39 (1997 - 2003) > AutoCraft H8-AGM battery only for $125.99!
Originally Posted by bowang View Post
I installed a new battery (AutoCraft H8-AGM) from Advance Auto Parts last Saturday. So far everything works great. It's only $125.99 after using a link my friend sent to me. The link saved me $35 instantly. The battery can be used on X3, X5 and 5 Series. I got free installation at local store.
Old 12-18-2012, 08:57 AM
bluebee's Avatar
For the record, this thread mentions a hint for properly tightening the cable connections:
Originally Posted by nedmon View Post
Does everyone know that tightening the 10mm nut on the terminal squeezes down on a little wedge and the wedge in turn pulls the clamp tight on the terminal post.
And if the wedge is not positioned right, the connection will be loose.
Ned
Old 01-06-2013, 10:37 AM
AmesDP AmesDP is offline
Mein Auto: 528i
Thanks for this pictorial DIY. It may be a simple procedure that anyone can stumble through in the end, but nobody wants to do that outdoors in the middle of the winter. Much better to know ahead of time the details of what bolts have to be removed in what order, what to do about the vent tube, how hard is it to lift the battery out, particular bolts not to over-tighten, etc.
Update: Forgot to take any photos, but everything went pretty smoothly for me. I kept one battery connected to the jumper points under the hood at all times to avoid losing power, so I didn't have any issues of any settings being lost.
The only clarifications I would add to this DIY are:
- The battery is very heavy and a very tight fit. Be prepared to do some work to get the old one out and the new one in.
- The vent tube will probably just pop off the connector when you pull the battery out, but if you need to get at it when removing or installing, you can slide the battery over a few inches after you have removed the clamp holding it down at the end (the one at the bottom of that long 10mm bolt). The vent tube is connected to the battery vent hole by a little L-shaped plastic connector - make sure you recover that from the old battery and use it with the new one.
- Be careful not to drop anything down into the battery well when re-installing (like the L-shaped vent connector, the nut for the cross bracket, or the clamp or retaining washer on the bottom clamp. Otherwise you may have to pull the battery out again to get at it, which you won't appreciate (no, I didn't drop anything - just paranoid that I might!)
What are the 2 bits of foam glued to the top of the original battery for? They don't contact anything on my car.
Old 01-06-2013, 12:52 PM
bluebee's Avatar
Originally Posted by AmesDP View Post
Thanks for this pictorial DIY. It may be a simple procedure that anyone can stumble through in the end, but nobody wants to do that outdoors in the middle of the winter. Much better to know ahead of time the details of what bolts have to be removed in what order, what to do about the vent tube, how hard is it to lift the battery out, partiular bolts not to over-tighten, etc.
Thanks for letting us know it helped!
The goal is for everyone, once they have a problem to fix, to find the canonical DIY for that problem, and, then, to improve it.
If you can, add a picture or two to help clear up anywhere in this DIY where it wasn't specific enough for you.
Old 06-14-2013, 06:51 PM
Kamikaze1 Kamikaze1 is offline
Mein Auto: 318i E46
Does the vent tube have to be connected to a new battery?
I'd better post my inquiry here rather than E46 forum because this thread is quite comprehensive.
When I removed my old battery the other day, I found the battery compartment flooded up to 2.5cm high and the vent tube was not connected to the battery at all.
That is why I didn't bother to reconnect the vent tube to the new battery. And of course I plugged the vent hole of the new battery to prevent flooding again.
Am I doing wrong?
Old 06-14-2013, 11:07 PM
Mein Auto: 528i
The vent tube is there to vent excess hydrogen gas which can be produced by the battery under some circumstances, because hydrogen can be explosive if confined in a small poorly-vented space. You shouldn't get water coming in to the battery compartment via the vent tube when it is properly connected. You should hook it up.
Old 06-15-2013, 01:07 AM
Mein Auto: 318i E46
Knowledge is power
I thought the excess water from the battery has flown through the vent tube out to air.
And I thought my battery compartment has been flooded because the vent tube was not connected to the battery.
Anyway, the vent tube is there for excess H2 gas, not for water.
I still wonder where the water came from? Through the side panel?
I'd better find an adaptor for the vent tube.
Thanks for your clarification
Old 06-17-2013, 12:51 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
Check he foam gasket that seals the rear tailight against the the body frame. The gasket make not be making a perfect seal allowing water to seep in.
Additionally, look for dried water marks which sometimes trails back towards the source of the leak.
Old 06-18-2013, 03:13 AM
Mein Auto: 318i E46
VG point. Thanks. Will let you know later
Old 08-28-2013, 03:54 PM
bluebee's Avatar
Drat. Maybe my battery has gone south, after less than 2 years!
-> E39 (1997 - 2003) > It's my turn for the E39 TRANS. FAILSAFE PROG transmission failure stuck in high gear
Originally Posted by bluebee View Post
Meanwhile, I called Autozone.
They don't have the 49-DL anymore.
But, they say mine is warranteed for $127.52 until mid September.
They'll sell me one of these, as a replacement, if my battery tests bad:
  1. H8 ==> $130-127=$3 + 8.75% tax on $130 = $14.37
  2. 94R ==> $165-127=$38 + 8.75% tax on $165 = $52.44
  3. H7 ==> $180-127=$53 + 8.75% tax on $180 = $68.75
Interestingly, I called another Autozone, which gave me different figures (but relatively similar):
  1. H8 ==> $130-105=$25 (plus 8.75% tax on $130 which is another $11.38)
This second store said they'd need to charge the battery for an hour, so, I'd better get going to give them the time to do that.
Googling, I think we can fit any battery of size H7, 49 (aka DIN H8), 94, 95 (aka DIN H9) ... as long as it's at least 850CCA, 720Amps, and 90AH (sometimes called "reserve").
Old 11-03-2013, 07:34 PM
bluebee's Avatar
Here's some advice on buying and replacing a battery, from a thread today:
Originally Posted by airplanelover View Post
First time I have to change the battery on my 2001 BMW 530i so dont know much about it and im a girl so I cannot change it myself.
Pep Boys will charge me $130 total for everything using a BOSCH battery. Is that good? What brand of battery does BMW itself use?
Originally Posted by rdl View Post
Is being a girl a reason or an excuse? It's OK to decide not to do work on cars, but gender is not a good reason - or so I tell my daughter. The only issue with DIY is whether you have the physical strength for the job at hand.
Search the best links sticky thread if you wish to learn more. Also this link
http://jgdarden.com/batteryfaq/carfaq.htm
Unlike some parts, there is nothing to be gained by chosing a BMW brand battery. You want a group H8 or H9, i.e. battery size. Quality can be gauged by the warranty; the longer the warranty the better the battery, i.e. the longer the expected life. Shop, compare and decide.
Whatever you do, be sure that the vent tube is connected to the battery. All batteries except AGM (also labeled as VRLA) will vent hydrogen at times; and hydrogen is highly flammable. There is no risk for a car with a battery in the engine bay. But E39s have the battery in the trunk & you definitely do not want hydrogen there.
Typing /battery f3 in the bestlinks nets this, which is a step by step of how to buy, remove, and replace the battery, from someone, much like the OP, who didn't know anything about batteries before starting (and now knows enough to at least replace one, thanks to your help):
- How to choose a good aftermarket battery (1) and a simple battery replacement DIY (1)
PS: This is NOT the correct way to remove a battery, btw, but they ARE heavy!
Old 04-14-2014, 04:23 AM
bluebee's Avatar
In this thread today, there was a discussion about buying batteries based on the battery manufacturer marketing strategy:
> E39 (1997 - 2003) > Need a battery verdict
Originally Posted by Flightmedic View Post
"72 month, 60 Month, or 36 month" batteries were a marketing strategy
I've said, time and time again, that, IMHO, anyone who buys a battery by that strategy, is using the wrong criteria.
Basically, they're buying something they don't understand (fitment, reserve capacity, cold cranking amps, etc.) using a (misleading) metric that they do understand (months).
Me?
I buy the battery most people recommend here, at the cheapest price I can, and if there is an outright tie, then (and only then), do I bother to even think about "claims" as to "months".
See also:
- Which product warranties are useful and whether or not a lifetime warranty make sense (1)
Old 06-19-2014, 04:48 PM
bluebee's Avatar
In this thread today, someone was worried about the recommended battery vents:
> E39 (1997 - 2003) > E39 battery type
Originally Posted by mixz1 View Post
Of all the alternate types available, which have the vent? I have always been concerned about venting the battery into the trunk. Am I being over-cautious?
So, I posted some vent-specific pictures from a thread referenced in the bestlinks, but I repost them here so that all benefit. They're from jamescd4 over here ...
ID:	446796   Click image for larger version
ID:	446797   Click image for larger version
ID:	446798   Click image for larger version
ID:	446799   Click image for larger version
ID:	446801   Click image for larger version
ID:	446802   Click image for larger version
ID:	446803   Click image for larger version
ID:	446804   Click image for larger version
ID:	446806   Click image for larger version
ID:	446807   Click image for larger version
ID:	446808   Click image for larger version
ID:	446809   Click image for larger version
ID:	446811   Click image for larger version
ID:	446812   Click image for larger version
ID:	446813   Click image for larger version
ID:	446814   Click image for larger version
ID:	446816   Click image for larger version
ID:	446817   Click image for larger version
ID:	446818   Click image for larger version
ID:	446819   Click image for larger version
ID:	446821   Click image for larger version
ID:	446822   Click image for larger version
ID:	446823   Click image for larger version
ID:	446830   Click image for larger version
ID:	446832   Click image for larger version
ID:	446833   Click image for larger version
ID:	446834   Click image for larger version
ID:	446835   Click image for larger version
ID:	446837   Click image for larger version
ID:	446838   Click image for larger version
Old 06-19-2014, 04:54 PM
bluebee's Avatar
The previous post reached the maximum limit of40 pics, so I continue ...
ID:	446842   Click image for larger version
ID:	446843   Click image for larger version
ID:	446844   Click image for larger version
ID:	446845   Click image for larger version
ID:	446847   Click image for larger version
ID:	446848   Click image for larger version
ID:	446849   Click image for larger version
ID:	446850   Click image for larger version
ID:	446852   Click image for larger version
ID:	446853   Click image for larger version
ID:	446854   Click image for larger version
ID:	446855   Click image for larger version
Old 10-17-2014, 05:05 PM
bluebee's Avatar
This lovely summary by QSilver7 is too good not to leverage, so, I include it here, for others to reference, now, and in the future, long after we're gone.
> E39 (1997 - 2003) > Good Replacement Batteries for the e39?
Originally Posted by QSilver7 View Post
See also:
- How to test a BMW battery & alternator (1) & the most often recommended diagnostic procedure to test for overnight parasitic battery drain (1) & one user's attempt to locate, describe, and photograph all fuses and relays in the BMW E39 with a picture of every fuse & relay (1) & how to choose a good aftermarket battery (1) and a simple battery replacement DIY (1) & Cn90's explanation of where to get alternator rebuild parts (1) & how to troubleshoot a bad FSU final stage unit (1) and how to build a test jig for your FSR final stage resistor (1) & how to repair solder cracks in your blower motor resistor (1) & how to replace your HVAC blower motor control (1) (E46) & what FSU is the right one to buy based on user experiences (1)
Old 01-07-2015, 09:24 PM
bluebee's Avatar
There is good information today from cn90 and QSilver7 about fitting an elbow into an aftermarket battery, over here ...
> E39 (1997 - 2003) > DIY: Autozone H8-DL Battery
Originally Posted by misterjim View Post
Just purchased an autozone H8-DL battery to replace my autozone 49-DL that was on its last legs. Battery fit perfectly and is in fact a few mm taller than the 49-DL. I did not need to use the shim that I had with the old battery. My biggest issue is that the vent hole is smaller than what was on the 49-DL and so I couldn't use the old fittings. I asked at autozone if it comes with a vent kit or even if I could buy one and the clerk had no idea of what I was talking about. I went to Home Depot to try to buy an elbow like that mentioned in this thread but they did not carry such a piece. So for now I don't have the vent tube connected. I left the battery uncovered so any hydrogen will hopefully vent into what is the large area of the trunk and tomorrow I will see if I can get an elbow that fits either at the local bmw dealer or another auto parts store. Anyone using this battery should make sure they have a proper fitting elbow first!
See also:
Old 03-02-2015, 08:55 PM
bluebee's Avatar
This thread today has information about the venting:
> E39 (1997 - 2003) > After Market Battery
See also:
- Complete DIY for how to test a BMW battery & alternator (1) & a diagnostic procedure to test for overnight parasitic battery drain (1) & how to find all the fuses (1) & how to choose a good aftermarket battery (1) and a simple battery replacement DIY (1) & where to find the battery explosive charge emergency quick disconnect (1) (2)
Old 07-01-2015, 08:26 AM
bluebee's Avatar
As a related aside, sometimes the battery terminal cable clamp is bent such that it won't tighten properly and just spins, as shown today...
> E39 (1997 - 2003) > Negative battery cable stuck on terminal?
Originally Posted by VNguyen09 View Post
Hey guys, so last week I had a slight fender bender on the way to work, long story short I somehow ended up "sitting" on top of the hood of an 8th gen Civic. After everything was said and done I got back in my car turned her back on and "Check Turn Signal" message popped up (Somehow the force of the accident blew out my passenger side angel eyes).
In my attempts to find that small issue I ended up trying to pull the battery to see if the error would go away. So my issue goes, the negative cable on my battery will spin (with a small amount of force) on the terminal but seemingly will not lift out. I'm fairly confused as to what could have happened to my negative terminal?
It is extremely common and has been happening to batteries and battery cables ever since they invented the things.
It's soft lead.
People torque the bolt clamp too tightly (I've done it myself).
Lead bends.
All you need to do is expand the terminal once it's off. Twist a wide screwdriver in there to open it up a bit.
Sometimes (rarer because batteries are almost always younger than the cable clamps which are as old as the car) the battery terminal itself has been scraped clean by a mechanic such that it's a bit smaller than stock.
Anyway, just pry the thing up any way you can. I think they even make a puller tool, but, I don't know anyone who uses it.
Please snap a picture of your issue and how you solve it so we can use your experience to help others.
Since you had a fender bender, also check the BST...but you didn't mention any codes...
- where to find the Battery Safety Terminal BST explosive charge emergency quick disconnect (1)
Sometimes the positive terminal melts in an accident...
So, it helps if you can please snap a picture of the problem.
battery charging, battery disconnect, battery problems, battery removal
