Old 07-29-2012, 11:07 PM
LalaRay's Avatar
LalaRay LalaRay is offline
Boosted
Mein Auto: 03 ///M5
briscas, what you mean evo sport pulleys ? evo as in a lancer ? how do they make a difference?
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower
Supersprint Headers,
Evolve Alpha N Tune,
CNS lightweight dm flywheel/Spec clutch,
ST coilovers,
Eibach Rear Sway bar/Beast Power Brackets,
Drilled slotted Rotors/Akebono Euro pads,
Magnaflow 14816 Mufflers
_____________________________
Old 07-30-2012, 10:06 AM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Originally Posted by bricas45 View Post
Photos of the IC piping.
Wow...!
That inter-cooler is pretty low...
I would be worried about knocking it against something while driving...
At least if it were on my car, because my car is a good 2" lower than the OEM sport height...
Awesome car...!
Jason
Old 07-30-2012, 10:14 AM
http://www.turnermotorsport.com/c-12...r-pulleys.aspx
http://aakmotorsports.com/under-drive-pulleys.aspx
http://www.m5board.com/vbulletin/e39...ey-system.html
Old 07-30-2012, 12:30 PM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
ahhhhh i see..... ok ill buy em
ST coilovers,
Old 07-30-2012, 12:49 PM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
nvm no im not after reading this http://www.m5board.com/vbulletin/e39...ey-system.html
ST coilovers,
Old 07-30-2012, 04:32 PM
bricas45's Avatar
bricas45 bricas45 is offline
Mein Auto: '01 540i6, '94 325is
Originally Posted by DinanBimmer View Post
Damn, you've gotta be seriously devoted to your car to even think about supercharging it. The thought crossed my mind once, but I've decided to get either an e28 or e34 M5 for my next car after my e39 gives in.
Haha yes it is quite a task for sure but a great experience!
2001 540i - Orient Blue
M5 bumpers, wheels, mirrors
S/C, water/air IC
A1 Headers, Random Technology Cats, Eissenmann Exhaust
3.15 diff, evosport power pullies
Koni Sports, Eibach Springs/Sway Bars
Old 07-30-2012, 04:34 PM
bricas45's Avatar
Originally Posted by Jason5driver View Post
Wow...!
Awesome car...!
Jason
I have Eibach springs which sit the car about the same as you say. The IC is in the bumper and barely can be seen. It is about 1 inch higher than the bottom of the bumper.
S/C, water/air IC
Old 07-30-2012, 04:37 PM
bricas45's Avatar
I al sure there have been issues with every single product on the market. I have never had an issue with mine. For the 540 they do not have a pulley for the crank that is stock the sport pulleys are for the waterpump alternator and power steering.
S/C, water/air IC
Old 07-30-2012, 05:31 PM
geargrinder geargrinder is offline
Crapparatus Bendgineer
Mein Auto: E46 M3Cic6MT, E39 540iT
I run them on the E46. Not hugely noticeable but one of those "lots of little things can eventually add up to 15hp which you can notice" items.
Been wondering about them for the 540 - another thing to check out if we can hookup some time Brian...
2003 M3CicM6 TiAg
2002 540iT 6MT Sport TiAg
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Some Stuff FS
Old 07-30-2012, 06:50 PM
bricas45's Avatar
Yes most certainly will show you they are sort of hard to see these days with the piping in the way.
S/C, water/air IC
Old 07-31-2012, 12:06 AM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
how long have they been on ya car
ST coilovers,
Old 07-31-2012, 07:35 AM
bricas45's Avatar
I have had them on for about 40k miles.
S/C, water/air IC
Old 07-31-2012, 08:06 AM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
hmmmm i wont like kill my alternator will i ? lol, cause i do have Led/Hid Everything......
ST coilovers,
Old 07-31-2012, 09:14 AM
bricas45's Avatar
There are 2 versions one that under drive the alternator and one that doesn't. LEDs draws next to no power as compared with regular bulbs. The one that doesn't under drive is suppose to be for big amps for audiophiles. I have the alternator under driven with no issues. I have 3 electric fans and a beefy electric pump for my IC.
S/C, water/air IC
Old 07-31-2012, 09:28 AM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
hmmmm Did you feel any difference with them ?
ST coilovers,
Old 07-31-2012, 09:33 AM
bricas45's Avatar
Throttle response was a bit quicker. But like JC said they don't add a ton on their own but lots of little things add up. Also the benefits of things like this just get better with more mods you make. Since it lightens everything up it increases by a % not just a constant. The car is a system and they all work together...improving everything is the way to get most power.
S/C, water/air IC
Old 07-31-2012, 09:59 AM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
yea i get that, but ok one more question sorry but i just dont put anything on without finding everything out first ya know? Is there any drawbacks to this, Pros and cons... i hear the pros but whats the cons to doing this?
ST coilovers,
Old 07-31-2012, 10:25 AM
bricas45's Avatar
Cons...
Alternator will spin slightly slower causing it to charge slowerer at low rpms. Idle it is around 12.2V and normal driving it is around 13.4V. Very rarely on mine when stopping as rpms drop my battery light will flash on and back off. This is just that the voltage drops below threshold as it seems evosport has it sized to be almost exactly at the level.
Water pump is under driven. This will cause your car to run slightly hotter...this is actually good for performance. Fan as well as pump run slower. Gauge will not show a difference though. You will run maybe a little over 100C on the OBC. I think it raised temp on mine by maybe 3-4 degrees C.
Power steering pump runs slower. This is really the only thing you will notice. At very slow speeds and low rpms steering is a bit stiffer. Like parking and what not it is not horrible but it is noticeable an sometimes have to give a quick rev to spin the pump a bit to assist. You get used to it.
Other con is the OEM belt size is no longer going to work as all pulleys are slightly larger. The kit comes with a belt but it is a standard size you can get at any automotive store I believe it is 6pk1693 I use gates belts they cost like $8. And I always have a spare.
S/C, water/air IC
Old 07-31-2012, 10:53 AM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
Cons...
Thank you for that detailed response but after reading what ya said ill pass ...
ST coilovers,
Old 07-31-2012, 01:46 PM
aspensilver540 aspensilver540 is offline
Mein Auto: 1997 540i
Cons...
My car stock runs about 102-105C. Mattmdrift swears it should be 110. Were you really running sub 100c? that is not normal
Old 07-31-2012, 08:08 PM
bricas45's Avatar
i just checked mine. With the new motor the hottest she gets is 99C on the OBC and that when sitting idle during a drive...if moving she goes down to 95C. In INPA I just read the in and out temps which were 184F (84C) and 204F (95C). I have a very powerful electric fan.
S/C, water/air IC
Old 08-01-2012, 11:15 AM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
Will the power delivery on a Supercharged 540 be at the same Rpm as it was N/A ?
ST coilovers,
Old 08-05-2012, 04:09 PM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
Got a chance to see Brian's car live and up close today. Also experienced driving behind it on the highway...
It's a freakin beast
ID:	335604   Click image for larger version
Old 08-05-2012, 04:50 PM
bricas45's Avatar
Chris, good to see you at the meet up today and thanks for the photos! Some pretty unique cars and 3 e39s at an e30 event is not bad!
S/C, water/air IC
Old 08-05-2012, 04:54 PM
Entwicklung 39
Same here Brian. Had fun at dinner. We definitely did our best "car nerds" discussion.
Got slammed on the way home. The downpour was impressive to say the least!
Hope you get that last 2% tune you need to smooth out your beast and I also hope to see you again at Show and Shine before you're off the the LDU.
