Old 10-14-2011, 07:25 AM
Flug540's Avatar
Flug540 Flug540 is offline
Mein Auto: 1998 BMW 540i 6-spd
Originally Posted by franka View Post
When the engine mounts fail the engine' rock is great enough to pull the upper radiator hose into the fan blade. I had it happen to me.
Of course if you keep new motor mounts on the car at all times it will not rock as severly. But on the otherhand with at least 1/3 more torque the engine will rock over farther than normal and will wreck the engine mounts sooner than later.
Just something to keep in mind.
Wow! Didn't realize it could be that bad. Good thing I just recently replaced my failed mounts.
On the other hand, I remember from Dinan installation instructions they say somewhere to leave clearance of at least 1/4" between the engine and the components.
Old 10-25-2011, 07:14 PM
bricas45's Avatar
bricas45 bricas45 is offline
Mein Auto: '01 540i6, '94 325is
What size injectors did your Dinan kit come with? I have a few sets and confused myself which ones I need now with their SW.
2001 540i - Orient Blue
M5 bumpers, wheels, mirrors
S/C, water/air IC
A1 Headers, Random Technology Cats, Eissenmann Exhaust
3.15 diff, evosport power pullies
Koni Sports, Eibach Springs/Sway Bars
Old 10-25-2011, 07:42 PM
Flug540's Avatar
I have these: RC SL2-0310.
Old 11-01-2011, 12:01 PM
Flug540's Avatar
Any update?
Old 11-01-2011, 12:37 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Bricas45, would the local Dinan rep who happens to have a day job analyzing jet engine failure modes for the FAA be Dan K from Atkinson?
He's got a nice garage setup!
Old 11-01-2011, 03:04 PM
bricas45's Avatar
Yes sir! He knows his stuff. I need to give him a call about my software.
S/C, water/air IC
Old 11-01-2011, 03:07 PM
bricas45's Avatar
Any update?
Should be receiving everything else from Dinan today! Maybe delayed though with storm up here. I haven't done too much lately. Going to fit the brackets and have a buddy of mine work on the inlet/discharge pipes. Photos to come.
How about yours? All running smooth now?
S/C, water/air IC
Old 11-01-2011, 04:37 PM
Flug540's Avatar
I wish... Fixed another air leak in the supercharger itself, but didn't help. Based on the symptoms I'm having, I believe there should be another leak still. Building a smoke machine to smoke it out.
Old 11-01-2011, 05:52 PM
bricas45's Avatar
Ever try the propane vacuum leak trick? It has worked for me in past
S/C, water/air IC
Old 11-01-2011, 06:15 PM
Flug540's Avatar
I've heard about it, but never tried, sounds a bit scary, plus I think smoke will show the leaks with better accuracy. I already have all the parts for the smoke machine, just a matter of putting it together.
Old 11-02-2011, 05:10 AM
bricas45's Avatar
Yeah it sounds a bit scary I suppose but it really is pretty safe. Worked well for me. Good luck with finding the leak. Have you been able to raise your boost by remove some of the leaks? You were reading about 3psi right? I am probably going to be dealing with the same issues soon. Maybe worse as the temps are dropping into the 30s here. May not even need an intercooler anytime soon haha.
S/C, water/air IC
Old 11-02-2011, 06:13 AM
franka franka is offline
Mein Auto: E39 540i Sport
That would be nice but still the engine runs at the same internal temperature including the compressed intake charge.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 11-02-2011, 10:01 AM
bricas45's Avatar
I was joking I actually pulled the trigger on water to air intercooler.
S/C, water/air IC
Old 11-02-2011, 10:56 AM
Flug540's Avatar
So which one are you getting? Curious to see how that works out, that's another thing I still need to do later.
Old 11-02-2011, 11:51 AM
bricas45's Avatar
I figured it would allow me to not have to custom route coolant lines as I can just go down an come back up on otherside with this. I have to have inlet and discharge pipes made anyways.
I got the long flow, with the larger radiator up to 600hp with basic pump and plumbing. Not sure were I will put it all yet probably figure that out when I get it in.
Type 19 from silicon intakes is the intercooler.
S/C, water/air IC
Old 11-03-2011, 02:58 PM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
I would really like some of these wonderful toys!!!
Old 11-03-2011, 04:28 PM
bricas45's Avatar
Dinan stuff came in a couple more brackets, the silicon inlet, the crank pulley, T9, and T15 modules!!!
Photos to come just got power back on after 6 days!! Not sure whether I am more excited for that or this dinan stuff!
S/C, water/air IC
Old 11-06-2011, 07:41 AM
bricas45's Avatar
Photos of the toys...
Installed brackets and crank pulley. Need to take it to fab shop for piping this week after i get the intercooler Tuesday.
ID:	299987   Click image for larger version
ID:	299988   Click image for larger version
ID:	299989   Click image for larger version
S/C, water/air IC
Old 11-06-2011, 08:51 AM
Flug540's Avatar
Nice!
Why did you get two different turbotronics modules? I believe I have T9 installed, what is the difference between T9 and T15?
That's an interesting 90 degree you have there, is that for S/C inlet?
As for the raising my boost, I didn't notice any impact to the reading I'm getting, which is still about 3psi at WOT. The only way I can tell the difference is by pressurizing my intake. Before it would hardly hold the pressure, after I sealed the S/C leak, it became better, but it still is loosing it too fast after compressor is disconnected. As I fix the leaks one by one it is getting harder to pinpoint the next one as the air is hissing past partially open intake valves, piston rings, valve seals etc, so it is not silent and hard to say where the actual leak is... I'm hoping the smoke machine will help.
Old 11-06-2011, 11:31 AM
bricas45's Avatar
Nice!
T9 is for MAF re-mapping as you know
T15 is for boost control at cold engine. It works like the controller on the SAP on the vanos engines. It turns off boost at cold start up. Not sure I need it but also not sure how software will like it without this so I will put it on.
The 90 houses the PVC and the BOV. It is the inlet to the supercharger. This is the Dinan part for the vanos v8s. Is yours different?
Yeah I am getting close to the full install. Maybe next weekend need to fit a few things. I am removing my Dinan CAI today and just running the filter off the MAF for the time being so it is out of the way and I can fit check the whole bracket and SC with belt etc.
Then I get to play with leaks and all that fun stuff.
S/C, water/air IC
Old 11-06-2011, 02:12 PM
bricas45's Avatar
Fit check and CAI delete haha
ID:	300058   Click image for larger version
S/C, water/air IC
Old 11-06-2011, 10:04 PM
Flug540's Avatar
My 90 degree fittings are the plain standard type without the extra nipples, which are instead located on the large intake steel pipe.
Did you already relocate the ABS module / expansion tank / oil filter housing ?
Old 11-07-2011, 06:02 AM
bricas45's Avatar
I have put spacers in oil filter. I am not using the Dinan oil block instead I have the TRS oil distribution block. I think it will fit easier than the Dinan one. I have not moved abs or expansion tank yet as I am doing that along with the intercooler to make sure I get a good fitment. Should do that this week and weekend.
Also not sure whether I am going with the Dinan or a custom tune yet. I have a guy here that does it.
S/C, water/air IC
Old 11-07-2011, 07:07 AM
Flug540's Avatar
If you are going with the same expansion tank that Dinan uses (a tank off of E30), oil filter has to be moved forward, I didn't use their bracket as it moves the filter too much right into my headlight.
I also ended up not using Dinan oil distribution block. It fit with no issues, but I wanted to add an oil pressure and temperature sensors. Pretty happy the way it turned out.
Moving ABS took some time. Unless you are replacing the hydraulic lines, there is a limit to how much you can push the module back, I pushed almost as much as I could.
Old 11-08-2011, 07:40 AM
bricas45's Avatar
On the m62tu motor Dinan does not move the oil filter forward as there is more space there than the pre-vanos cars. They just use spacers to re angle it for the oil distribution block. You have a few things there in front of the power steering fluid reservoir my car doesn't have. That is where they put the reservoir on mine. I am using the e30 tank and have that in pile of parts to go on car this week.
S/C, water/air IC
