Old 03-06-2012, 10:27 AM
teklord69 teklord69 is offline
Mein Auto: 2001 330ci 5-Spd
Wheels spacers for oem 17x8 style 42
Anyone running spacers on stock wheels? I like my oem style 42's but the fronts looked a little "tucked" in for my taste. What is the proper size to get the front a little further out? 10mm? or 15mm? Also is it common to use spacers in the rear also? What size for the rears recommended?
Old 03-06-2012, 11:08 AM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
measure how far the tire is from lining up with the fender first. ecstuning has spacers with extended bolts.
Old 03-06-2012, 11:36 AM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
This link will tell you exactly the difference between your current setup and the 42s.
You'll need the offset (ET info) from each rim though.
http://www.1010tires.com/wheeloffsetcalculator.asp
Note, you'll still need to determine the spacing needed to prevent rubbing or fender rolling though depending on suspension setup.
Old 03-06-2012, 01:32 PM
ECSTuning's Avatar
Instructor of the Stig™
Everyone has a little bit different taste so I suggest taking a few measurements to figure out where you'd like the wheel to sit. HERE is a pdf explaining how to measure for spacers, and HERE is a link to my selection of spacers. To give you a starting point, I ran 15mm spacers with style 5s on all 4 corners of my old E39 which was heavily lowered.
ECS Tuning
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 03-06-2012, 02:16 PM
SilverE39's Avatar
SilverE39 SilverE39 is offline
Mein Auto: '01 530i S/P 5sp
15mm spacers on all corners. No problems.
OEM M5 F Bumper | EuroDyne R Bumper | Magnaflow Exhaust Manifold and Full Cat-Back Exhaust | Koni+H&R Sport | CDV Deleted | Eibach f/r sway bars
Hard-wired V1 Radar | E60 shifter w/ZHP shift knob | 18x9 Style 42 | Continental DW 255/40 | Zimmermann XDrilled F/R w/Akebono Euro Pads
35% Madico tint | Infinity Basslink | E0n0n D5201Z Navi | Thule Bike Rack
Old 03-06-2012, 02:18 PM
ECSTuning's Avatar
SilverE39 that looks great! From the looks of it you could have probably gotten away with 20mm and still had zero rubbing issues.
ECS Tuning
Old 03-06-2012, 02:35 PM
SilverE39's Avatar
^ yes, 20mm up front would work. The rears you might have to roll fenders. I'm using 15mm for my 18" Style 42s and it's perfect for all corners.
Old 03-06-2012, 08:19 PM
E39_Ryda E39_Ryda is offline
Mein Auto: 2001 530i Sport
Can't believe I'm saying this, but those 18" Style 42s look just as good as the M-Pars, if not better!
Old 03-06-2012, 09:06 PM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
^ OMG!!!!!!!!!!!!! style 42s in 18 look amazing. never seen them before. NO BS those **** on M pars. where did you get them?
Old 03-06-2012, 10:05 PM
SilverE39's Avatar
Purchased from getbmwparts.com.......over 1-1/2 years ago. You can't find them anywhere.
Old 03-06-2012, 10:49 PM
Thank you! That is exactly the picture I need to see. Since the fronts seem to be tucked in more than the rear would 20mm front and 15mm rear be ok?
Old 03-06-2012, 10:56 PM
champaign777's Avatar
same here , 18" wheels
15MM all around for 8" and 10MM all around for 9"
the perfect choice
Old 03-07-2012, 06:56 AM
ECSTuning's Avatar
Purchased .....over 1-1/2 years ago. You can't find them anywhere.
Well.... not the wide 18x9 but people can find 18x8 squared if they are interested in special orders from Europe.
Old 03-07-2012, 10:47 AM
SilverE39's Avatar
Yes, I would say it's safe to use 20mm up fronts.
Old 01-20-2017, 07:29 AM
frknvgn frknvgn is offline
Send a message via ICQ to frknvgn
Mein Auto: 2002 530i Sport Pkg 5spd
Just (barely) lowered my 2002 530i Sport on coilovers and installed 15mm hub-centric spacers with new lug bolts. I think I'm something like 13.5" from hub center to the top of the wheel arch. I didn't want to lower much and I was already almost scraping curbs when I parked. It looks stock to the layperson, but better than stock (sport package) to my trained eye.
