Old 09-21-2011, 03:46 PM
jbonly21's Avatar
jbonly21 jbonly21 is offline
Mein Auto: 02 525I SPORT
Engine head
Sent from my SPH-M900 using Bimmer
02 525I Sterling Gray, 18" M Parallels, M Tech bumper, Magnaflow Highflow cat, Resonator delete, 3" OBX muffler, H&R spring and Bills sport shocks.
RIP ALPINE WHITE 97 528I
Old 09-21-2011, 03:50 PM
jbonly21's Avatar
Do anyone knows were I can find the socket, and flywheel lock tools, with out having to wait for it in my mail box?
Old 09-21-2011, 06:33 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
You 'can' make your own ...
I'm not sure exactly what tool you're looking for, but, I just did a dumb search for "tool" in the bestlinks and came up with this in a split second.
There are more listings (if I just want to hit the F3) button; but, do these help at all?
How to make your own E39 specialized tools:
- How to make your own BMW cooling system overhaul fan clutch nut counterhold tools (1) (2)
- How to make your own BMW thrust bushing tool (1) or buy them (1) (2) or improvise (1)
- How to make your own BMW car ramps (1)
- How to make your own BMW subframe & differential bushings tool (1)
- How to make your own BMW oxygen sensor removal tool (1)
- How to make your own BMW single-VANOS solonoid socket tool (1)
- How to make your own BMW camber & toe-in alignment tools (1)
- How to make your own BMW hella headlight adjusters (1) (2)
- How to make your own BMW rtab removal tool (1)
- How to make your own BMW upper timing chain locking tool (1)
- How to make your own BMW flywheel locking tool (1)
- How to make your own BMW cylinder head bolt removal tool (1)
- How to make your own BMW cam locking nut tool (1)
- How to make your own BMW crankshaft holder tool (1)
- How to make your own alignment tools to adjust toe-in and camber (1)
etc. (plenty more)
Old 09-21-2011, 07:00 PM
jbonly21's Avatar
Thanks Blue, I try buying the Haynes but I only find the older 5 and the 3 series, can some one tell me which one is the right one?
Old 09-21-2011, 10:59 PM
jbonly21's Avatar
Does anyone knows off a good machine shop in the LA area, and how long does it takes to get your head done?
Old 09-22-2011, 09:02 AM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Valve job ??? Head resurfacing ??? Port & polish ??? Did your car overheat ??? What, exactly, are you trying to accomplish here ???
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 09-22-2011, 09:13 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Likely overheated engine. Classic problem: overheating LOL.
Old 09-22-2011, 12:38 PM
jbonly21's Avatar
Overheated.
Old 09-22-2011, 08:00 PM
jbonly21's Avatar
Almost done removing the head, had to go to work. Hoping to get it to the machine shop tomorrow.
ID:	294291   Click image for larger version
ID:	294292   Click image for larger version
Old 09-24-2011, 12:22 AM
jbonly21's Avatar
Head is off, does not look too bad, should I get a valve job?
ID:	294427   Click image for larger version
Old 09-24-2011, 06:03 AM
franka franka is offline
Mein Auto: E39 540i Sport
I would while the head is off.
Frank
540/6
Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 09-24-2011, 09:23 AM
jbonly21's Avatar
Woke up this morning check the head before taking it to the machine shop and this is what I found....
Old 09-26-2011, 02:11 PM
jbonly21's Avatar
Can someone tell me which is a better brand of head gasket Elring, Reinz, Metric, or Grade A.
Old 10-04-2011, 06:19 PM
jbonly21's Avatar
I know I need new head bolts, but how bad is it? I did my first torque on the head 35 ft lb,forget it should have been mn .
Old 10-04-2011, 06:58 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Are those cracks along the bolt holes?
Old 10-04-2011, 07:19 PM
jbonly21's Avatar
Yes, just got it back from the machanic shop.
Old 10-05-2011, 05:14 AM
The 6 cyl head bolt spec is 30 ft-lb first pass, then 90 degrees more on second pass, and another 90 degrees more on 3rd pass.
Frank
540/6
Old 10-05-2011, 05:59 AM
jbonly21's Avatar
All the post I read says some thing different, some says 30 mn and some says 30 ft lb, so which one is it? I didn't want to take the chance so I took the head off, so now I need new bolts.
Old 10-05-2011, 06:41 AM
The spec I posted is right out of the Bentley manual, page 113-14. It is for the M52 TU and M54 engines with aluminum blocks.
You should get a Bentley manual as there are other details and tricks to removing and installing the head.
The correct figure is 30 ft-lbs = 40 Nm.
Frank
540/6
Old 10-05-2011, 10:15 AM
pshovest pshovest is offline
Mein Auto: '01 530iM, '00 528iTM
If the only error is tightening to 35 ftlbs instead of 30, you haven't stretched those bolts. It's the last 90 degree twist that does the stretching. I'd reuse the bolts. I'd also put a drop of oil between the head of the bolt and washer. This will prevent the jerky movement as the bolt tension rises with tightening. Make sure you clean and blow out the threaded holes in the block. Carb cleaner will remove oil and other residue.
Paul S
BMW CCA 69606
Old 10-05-2011, 10:33 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Paul S
BMW CCA 69606
Very good point. Oil will alter significant the torque specs
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 10-09-2011, 08:24 PM
jbonly21's Avatar
Ok its been a week since I replace my HG, the car runs great and the ride is smooth, but I can't help it but keep checking my cooling system. One question how much pressure is normal when feeling the top coolant hose after a drive?
Old 10-10-2011, 04:57 AM
It will feel hard but forget that and check the system cold for any coolant lost day to day until you are comfortable that you have no leaks.
Frank
540/6
Old 10-10-2011, 03:54 PM
jbonly21's Avatar
Ok now on to my auto trans, when the car had the blown HG, the trans use to kick hard a lot from 2 to 3 when it got hot. Now after the rebuild it stay kicks some times. Any idea?
Old 10-10-2011, 04:01 PM
WhAT DOES THAT MEAN?
Frank
540/6
