Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 09-21-2011, 08:56 PM
Nightlviper Nightlviper is offline
BMWFAN4EVER
Send a message via MSN to Nightlviper
Mein Auto: 1988 BMW E28 M5
Exclamation 1991 E32 740iL Problem
I have a problem with Mine i have a 1993 740Il and the RPM's Don't work and the Speedometer has a lag to it, as well as the temperature needle of the engine it does not state weather it cold or hot when i start the car it just barely goes up but doesn't show anything else.. Any Help?
1993 E32 740IL ( Sold )
1988 E28 M5 A.k.a. MAD5 ( Summer Daily / Restoration Project )
2001 E46 330I A.k.a SnowWhite ( Daily / Beater )
2003 E46 330I A.k.a Misty ( Daily / Beater )
-Tomas
Old 09-21-2011, 11:48 PM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Smile e32
The most likely cause is that the backup battery in the service indicator board has failed, The best solution is to buy a new si board from BMW, Trying to fit a non genuine battery is a waste of time as most times it will not work properly, You may be able to find re built boards elsewhere but again I have found that they are not very good, Peter
Old 09-28-2011, 05:07 PM
BMWFAN4EVER
Thumbs up Thanks!
Thank you Appreciate it!
-Tomas
odometer spedometer 1993
