Old 03-22-2016, 10:46 AM
kingfisher1 kingfisher1 is offline
Mein Auto: 528i
Chk eng.light came on
Car ran rough.stopped.turned off car.waited a few minutes.started up and ran fine.??
Also tending
2003 Dodge Cummins
1999 Jeep XJ Country
2014 F-150XLT off road
Old 03-22-2016, 10:56 AM
JKRIT JKRIT is offline
Mein Auto: '03 525i
OMG!! Sell it fast! No, really, just read the codes to see what's happening.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 03-22-2016, 10:59 AM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
3 suggestions...codes, codes , codes
99 528i 5sp sport
be alert...the world needs more lerts
Old 03-22-2016, 11:25 AM
Mein Auto: 528i
Guess i need a code reader..or does the car give on dash..
Old 03-22-2016, 11:40 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Get a code reader--please! A good stand-alone reader costs $50-70 and will soon pay for itself. Or you could by the PA-soft bundle for use on a laptop, which runs $20-30, I think. In any event, you want to be able to display live data, such as fuel trims and wheel speed sensors, in order to help diagnose vacuum leaks and ABS issues efficiently. Otherwise, you're likely to spend untold time and expense replacing random parts or trying to chase down your problems.
If you get a "check engine" light, it means an OBD code has been set. If you get the code (or codes) read and post it here with the explanation so that we don't have to look it up, we can help your proceed from there. Some code readers can reading pending codes as well, meaning that there's a malfunction detected that will set a code if it persists.
BMW--giving new meaning to the phrase "disposable income."
Old 03-22-2016, 12:50 PM
mattmar1's Avatar
Wingnut
he pretty much covered it
99 528i 5sp sport
Old 03-22-2016, 12:52 PM
Mein Auto: 528i
Thk you guys alot.gettin one tomorrow.
Old 03-22-2016, 01:09 PM
Mein Auto: 528i
ok,had the o'reilly guy check with the store tool.It was weird,he was a tech yrs ago @ a bmw dealership in Houston(its what he said)plugged it up and NO codes at all cept it had a misfire in cyl. 4.Coil pack(s)? they ordered a scanner i'm getting tomorrow.
Old 03-22-2016, 02:29 PM
Brandon002's Avatar
Brandon002 Brandon002 is offline
Mein Auto: 2002 530I Sport
No codes at all except a misfire?
Misfire is your problem. Swap the 4 coil pack with another cylinder to see if the misfire goes with the pack before throwing money down on something that you may not need.
Old 03-22-2016, 02:31 PM
Mein Auto: 528i
Thank you i will.If i knew how.will read up.
Old 03-22-2016, 02:43 PM
mattmar1's Avatar
Wingnut
iirc, setting a misfire results in a code given..unless he made that up...pull the left engine cover off, count from the front 4 coils, swap 4 with another adjacent coil and see what it reads. all thats needed is a 10 mm socket.
99 528i 5sp sport
Old 03-22-2016, 04:41 PM
Mein Auto: 528i
LMAO..It was actually"service engine soon" light..geez,i've owned to many cars with idjut lights..lol
Old 03-23-2016, 12:51 AM
creeky creeky is offline
Mein Auto: 2002 525i
The check engine or service engine soon light codes can be read with a cheap $15 code reader which you should have, at the very least.
The service interval is something different.
Old 03-23-2016, 03:00 AM
The "Service Engine Soon" light is actually the same as the "Check Engine" light, and it means that a code has been set, but if the problem has been fixed, the light may go away.
