Old 09-23-2011, 10:39 AM
morrisroad's Avatar
morrisroad morrisroad is offline
Mein Auto: BMW 530
Press Gas, hesitation, stall...
Anyone had this experience. Noticed it recently when I presss the gas pedal down quickly, it hesitates for a sec or 2 and then you get full power burst.
Today, I pressed the gas, and it just stalled. Restarted no problem, but I feel the hesitation when taking off from stop.
Any ideas on where to start with this one...
I have replaced CCV, Plugs, Checked Coils.
MorrisRoad
Old 09-23-2011, 10:47 AM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
Check all of the air intake ducts for rips/tears and report back.
Any check engine lights?
Old 09-23-2011, 10:53 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
You have drive-by-wire. There have been a few reports of troubles with that system. Check for pending codes.
Old 09-23-2011, 11:30 AM
fortunateson fortunateson is offline
Mein Auto: 525i
Could it be the CPS? I had somewhat similiar situation, mainly just stalling out. replaced the CPS and trouble went away
Old 09-23-2011, 11:34 AM
morrisroad's Avatar
Mein Auto: BMW 530
There was a code earlier point to the first bank - but the light when away. I didn't record the code unfortuantely.
CPS - crank position sensor?
MorrisRoad
Old 09-23-2011, 11:42 AM
skylord skylord is offline
Mein Auto: 99 528i M package
camshaft position sensor, i just ordered a new one myself, https://www.autohausaz.com/search/pr...er=12147518628, dealer wanted over 100 for it. get the oring too , https://www.autohausaz.com/search/pr...er=12141748398
Old 09-23-2011, 11:46 AM
redbull713's Avatar
redbull713 redbull713 is offline
Mein Auto: '97 540i/6
Try cleaning the idle air control valve. I cleaned my buddies, it fixed the problem you described.
Old 09-23-2011, 11:59 AM
YoungNorrisE39 YoungNorrisE39 is offline
Mein Auto: 2000 red e39
just had the smae problem it was my cam positioning senson.. i got it for like 70 buck off pelican parts.. took abt 45 mins to instal
Old 09-23-2011, 12:20 PM
Mein Auto: 525i
For anyone installing a C{PS for the exhaust side same yourself a lot of time. When I did mine I was lazy and didn't want to remove a lot of stuff for access. I disconnected the sensor near the Vanos and then tied a string to the end. I then disconnected it at the MAF area and gently pulled it out with the string tagging along. When it was finally freed I untied the string from the old sensor and tied the string to the new one. Pulled the string back out and connected sensor at either end. Worked like a charm and took about 15 mins.
Old 09-23-2011, 04:24 PM
morrisroad's Avatar
Mein Auto: BMW 530
I have had an issue with CPS with another car and the symptoms was hard start. I don't have this per se as it starts ok. It like you press the gas and nothing happens, then you get a burst.
Idle control valve is an expensive part. I am going to check for leaks as a start.
MorrisRoad
Old 09-23-2011, 06:28 PM
No ICV on that MY.
Old 09-24-2011, 06:18 PM
morrisroad's Avatar
Mein Auto: BMW 530
I was looking through the threads again and found one that discussed the DISA failure. I had sealed this up on an earlier occassion when I did the CCV, but decided to have another look.
I pulled it off and the seal it looked like it was sealed ok. I was taken a closer look on the flaps and noticed wear/melt of the flap on the edge. Then I worked the flap to the point and noticed that the rim plastic was split on the pivot point causing it to lose shape when it was fully open. Will take some pictures.
MorrisRoad
Old 09-24-2011, 06:33 PM
morrisroad's Avatar
Mein Auto: BMW 530
Wear melt on corner.
MorrisRoad
Old 09-24-2011, 06:35 PM
morrisroad's Avatar
Mein Auto: BMW 530
Crack on pivot
MorrisRoad
morrisroad's Avatar
Mein Auto: BMW 530
Distortion when open
MorrisRoad
Old 09-24-2011, 06:57 PM
Fudman's Avatar
Fudman Fudman is offline
It might be your DISA and/or it might be your Vanos. The DISA varies your intake length and I'm not sure why it would cause your engine to stall or hesitate. A failing DISA should result in suboptimal combustion (reduced power & economy). A failing Vanos will mess up valve timing and can cause hesitation. When I replaced my Vanos seals, my hesitation disappeared.
Old 09-24-2011, 07:19 PM
morrisroad's Avatar
Mein Auto: BMW 530
I am going to do the vano's /besiean procedure in a few weeks. In the interim, it looks like I need to replace this part. The economy/power is definitely off from what it was, so will report back once I install the disa.
Any suggestions on where to buy the DISA, seems pricing is pretty much the same across suppliers.
MorrisRoad
Old 09-25-2011, 05:40 AM
Fudman's Avatar
I usually go with OEM on many critical parts (CCV, FSU, suspension, etc.) to avoid redoing repair work. Haven't heard anything about premature failure of DISA valves so any source would appear to be as good as the next.
Old 09-26-2011, 02:57 PM
xchudyxpl xchudyxpl is offline
Mein Auto: 2002 530i
I had similar problem, car was stalling usually after the start and then wen I was trying to take off( very dengarous). Anyways changed both camshaft position sensors. Since thene everything is fine.
Old 10-01-2011, 04:42 PM
morrisroad's Avatar
Mein Auto: BMW 530
Are there 2 cam position sensors? I looked on pelican and it looks like there are several. Any recommendations?
MorrisRoad
Old 10-11-2011, 06:12 PM
morrisroad's Avatar
Mein Auto: BMW 530
The new disa arrived. I have included some pictures here that show what the gaskets on a new DISA look like. I was surpised how thin the whole gasket was, its entirely flat on my old DISA.
ID:	296750   Click image for larger version
ID:	296751   Click image for larger version
MorrisRoad
Old 10-11-2011, 06:18 PM
morrisroad's Avatar
Mein Auto: BMW 530
While researching and reading disa posts there was a number citing parts that could fall into the intake. There were a number of pictures of broken flaps or parts outside of the space were the DISA sits. It looks like from this picture, that the pin is not likely to fall into the intake unless it falls inward or falls out in the channel as a result of pulling the disa out.
I will report back on how it works tomorrow.
Name:	Disa inside.jpg
MorrisRoad
morrisroad's Avatar
Mein Auto: BMW 530
Note the picture is up side down
MorrisRoad
Old 10-11-2011, 07:41 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Me too I experienced a hesitation but I was cruising around 75 mph. All of a sudden, the car hesitated a few times - felt like no gas was going to the injectors - car was cruising uphill. Then nothing, everything went back to normal, no more hesitation. Home, I checked the codes, had none. A week or so after the incident I changed the DISA. Never had that symptom again. Not sure if it was because of the DISA, but who knows?
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 10-12-2011, 02:21 PM
morrisroad's Avatar
Mein Auto: BMW 530
So - I changed the DISA. When I started it this morning, it still had a miss it seems, not smooth running. So its got to be something else. I did notice that when I accelerate seems to be more responsive.
MorrisRoad
