F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
So I disabled ARS....
Following up on the tail end of this thread, I conducted an experiment that I've been wanting to try for a while. I figured that it deserved a new thread.
My thoughts exactly. ARS Part 1 - Discussion on Anti-Roll Quote:
ARS isn't necessarily meant to increase performance handling. It's used to create luxury handling, in my mind. Two cases in point: ARS was first introduced on the 7 series. Second, new M5 has DDC (active dampers) but NOT ARS (active anti-roll bars). In fact, I do not believe ARS is even an option on the M5. Think about what ARS does and what an anti-roll bar does. An anti-roll bar is designed to do what it's name says, prevent roll. It does this by connecting one side of the chassis to the other by a rigid bar that is mounted on links. These links allow the bar to rotate if both of the opposing suspension components move at the same rate (i.e. you hit a speed bump). However if the opposing suspension components do not move at the same rate (i.e. lateral loading from one side to the other) the bar is not free to move and acts as a transverse spring (think the Corvette's rear leaf spring) which resists the outside suspension moving upward by the lateral forces acting on it. However, this system is far from perfect. If you are driving straight, and your left wheel encounters a bump in the road, the anti-roll bar is not free to rotate, and it transmits motion to the other side of the suspension. Therfore, you experience a "head tossing" motion. There are many other motions where the anti-roll bar isn't countering roll, but instead creating extraneous movements in the suspension. Now, ARS does two things. First, in steady state forward driving, it de-couples the roll bar from one side to the other. This means that the suspension is free to act completely independently. This offers much more comfort as the extraneous suspension movements are reduced. However, if you start giving even a bit of steering input and corresponding lateral load, the car will roll quite a bit. So this type of setting is desired only when the car is tracking straight ahead. Second thing that it does is effectively vary the rate of the anti roll bar action. Up to a certain g force level (0.5g, I believe), it will twist the anti-roll bar to resist outside suspension upward movement (i.e. resist the car leaning into the turn). After 0.5g, it starts to relax, letting the car roll so that it feels natural and, as the driver approaches the limit, predictable. Essentially, ARS is acting as a variable anti roll bar from zero (decoupled) to much stiffer than normal (0g to 0.5g) then back to what a normal standard anti roll bar would be (after 0.5g). In summary, ARS is designed to eliminate the compromise found in selecting anti-roll bar setup. Running a stiffer anti-roll bar is great for handling, but sacrifices ride comfort. Likewise, a thin bar is good for ride, but bad for handling. To me, the ARS is designed to reduce harshness of a sporty roll bar setup, not enhance cornering stiffness of a thin bar.
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians Last edited by Needsdecaf; 09-25-2011 at 11:50 AM. |
Part II - ARS in action.
So while Stealth.Pilot is true in saying that ARS reduces "wallowing", that's only true if you define wallowing as excessive roll. To me, there are many other suspension movements that feel unnatural that I consider wallow, not just excessive roll. I have always felt that the car feels a bit "bouncy" encountering certain bump patterns. It does not feel tied down. It can feel, at times, less than BMW-like. I have always blamed this on two things. First, soft springs required with the active dampers. Second, the active anti-roll bars. So I wanted to drive the car with the ARS disabled. The requisite fuses are in the trunk fuse box. However, BWM's fuse labeling system leaves a lot to be desired. There's no fuse marked ARS. In fact, each "function" has a number of fuses shown to it, sometimes up to 8 fuses! For instance, there is a pictogram of a shock absorber, with about 6 fuse numbers listed next to it. Then there is a picture of a car with rolling arrows with another 6 or so fuses. Two of the "anti-roll" fuses are not shared with the "shock" fuses, so I pulled those. As expected, I got two errors, but not the ones expected. First was a lack of self-parking. Second was a lack of lane departure warning. Interesting. These systems are REALLY interconnected. By playing with the two fuses (131 and 134) I found that if I left 131 in, I would have everything except self-parking and ARS, with the lane departure warning going away. If I left 131 only in, I got ARS back, and only lost lane departure warning. I only did about 10 minutes worth of driving with ARS disabled, but I can say that the car is MUCH different. I observed much more of the traditional head toss from a car with standard roll bars, however, it was very tolerable. Moreover, I found that the car had lost quite a bit of the floatniess that I feel in normal driving, even in Sport. Finally, I did not get a chance to really lean on the car, so I cannot compare the amounts of roll in ARS on vs. ARS off. I plan to run ARS off over the next week and see how the car responds in normal driving. Certainly the differences should be enlightening. One other thought is that there was still some float in the car even with ARS disabled. I suspect the springs are still pretty soft because when ARS is active, it resists roll that the springs do not need to counter. I would be willing to bet that the spring rates for the 2012 sport car (DDC, no ARS) are different than the 2012 car with DDC and ARS, or the 2011 DHP or M Sport cars. More observations to come. Thoughts are welcome......
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians |
First of all I laud your experiment. Great initiative and also quite ingenious. I am curious to hear your perspective after a week.
My sense is from the initial experience you describe that it may boil down to taste. I haven't felt so much of the floatiness that you describe in the BMW - but it may be because I am used to ARS from my Lexus. However I hate body roll in corners because for me the most fun I have is how fast I can drive the car through highway-to-highway ramps (I have several on my 15 minute commute) and body roll reduces my enjoyment of cornering. BTW I am surprised that you say it decouples the sway bar. I would have thought it goes from normal setting (same as non-ARS) to more tightly coupled. If it truly decouples it then I would argue this is bad programming by BMW. Perhaps Dinan can address this when they release their suspension programming for the F10. Quote:
On the Lexus website it is described thus: Quote:
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP Last edited by Stealth.Pilot; 09-25-2011 at 12:29 PM. |
Yes, BMW's system completely de-couples the roll bar in the middle during steady state driving. I, too, do not like excessive roll. This is not what I am feeling and describing as floatiness. The floatiness that I feel is more of an overall up and down pogoing motion. Trust me, I am going for sportier, more tied down, and not less roll resistance. By the way, what mode do you normally drive in?
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians Last edited by Needsdecaf; 09-25-2011 at 12:56 PM. |
I am ordering my 550 next week and I am still on the fence on ARS, so I really appreciate you taking the time to do this. I don't want floaty feeling but didn't think that ARS controlled that at all. Is it possible that piling the fuse impacted something else too?
If you're ordering, I'd drive both configurations first.
I drive the Lexus with Suspension and ECT both set to Sport. You can't turn off the APSSS on Lexus either.
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP |
How do you actually know ARS is off? Is there a light on the dash? Just curious.
'11 535i Space Gray/Cinammon Brown/Anthracite/M-Sport/2TB/PP1&2,ZAV,ZCV,CWP,HUD,4zone,S&T camera,BMW apps..ED 06/27/11 '08 650i retired ![]()
I don't think ars makes a car floaty per say. I have not experienced or heard of float from any other BMW with ars including my 2008 E60. It doesn't mean that it doesn't contribute to the float in the F10 since it could be that ars is a bad match to ddc. I.e that ddc is the cause of the float and that ars is less effective in masking it than a passive roll bar would be. It's really difficult to say but since my E60 with ars was free from float and very good suspension wise I'm inclined to blame the long soft springs used with ddc.
It's very obvious the the ride is different.
NeedsDecaf thanks a lot for your insight/// so can i count on this "ARS will soften the harshness of a thick Sway Bar and yet avoid the body roll" ?
reduces the twist on the bar as turning increases? More correctly, the reference for: "Now, ARS does two things. First, in steady state forward driving, it de-couples the roll bar from one side to the other. This means that the suspension is free to act completely independently. This offers much more comfort as the extraneous suspension movements are reduced. However, if you start giving even a bit of steering input and corresponding lateral load, the car will roll quite a bit. So this type of setting is desired only when the car is tracking straight ahead. Second thing that it does is effectively vary the rate of the anti roll bar action. Up to a certain g force level (0.5g, I believe), it will twist the anti-roll bar to resist outside suspension upward movement (i.e. resist the car leaning into the turn). After 0.5g, it starts to relax, letting the car roll so that it feels natural and, as the driver approaches the limit, predictable. Essentially, ARS is acting as a variable anti roll bar from zero (decoupled) to much stiffer than normal (0g to 0.5g) then back to what a normal standard anti roll bar would be (after 0.5g)."
Tom '11 M-Sport 535i, Carbon Black - Cinnamon, Head-up, P-II, SAT, + Returned to the Mother Ship: 2008 335i E93 Last edited by Erregend; 09-25-2011 at 04:25 PM. Reason: Added full quotation. |
Here is an old one: http://www.caranddriver.com/reviews/...530i-road_test Quote:
![]() Here is a better link, which quotes ZF as a source....good source, those manufacturers. It also discusses Anti-Roll bars better than I did: Quote:
Here's what it can do:
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians Last edited by Needsdecaf; 09-25-2011 at 04:33 PM. |
Thanks for the citations.
But, as I read this:"Activated by sensors and an electronic control, the oscillating motor creates torsion and thus adapts the stabilizer to the driving situation. The result is impressive: with lateral acceleration up to 0.5 g, the system fully compensates body roll. As a result, the vehicle remains absolutely parallel to the road surface." it doesn't say the twist in the bar is reduced after 0.5 g, just that 0.5 g is all it will counter. |
http://www.bmwmotorsports.org/pdf/e7...%20Systems.pdf The 0.5 g is an engineering choice. It is designed to permit roll after that so the dynamics don't seem unnatural.
OP, excellent write up and technical explanation... BMW should hire you as a consultant to better explain to the average consumer as to how some of their technology works in 'Layman' term.
I must agree with you that on the E70 the ARS is programmed more for comfort than for improved performance. It is programmed to act like a thin anti-roll bar when driving straight ahead or turning slowly, making the ride smoother and handling neutral. When turning at faster speeds it acts like a fatter and fatter anti-roll bar with a max countering force equivalent to the size bar that would hold the car level in a 0.5 g turn. This size bar allows for body roll at sharper fast turns and allows under-steer to develop so that inexperienced drivers will sense the approaching limits of adhesion. It is also programmed to balance the "bar size" in the front and back so that over-steer does not occur. Maybe one of the tuners will be able to "race tune" these with the suspension. |
I'd settle for just the suspension tuning!
My understanding is that Dinan is working on this.
![]() 2008 328i dark graphite ,cold weather pack,USB/ ipod/black leatherette SOLD hers: 2009 X5 alpine white, dakota tobbaco leather,sport, DHP premium pack |
While I applaud your experimentation I find one major fault. What is the default setting an ARS equipped car uses when power is disabled to the system? You do not know if the roll bars are working at all or if they are lighter or heavier than a stock non ARS equipped car. What effects will those variables have on the floatiness of the car? The only way to tell if ARS improves handling or not is to compare to a DHP car without ARS.
I had a suspension malfunction (valve block) that disabled ARS and I found the car downright dangerous! In corners even at low G loads the car leaned like an 80's school bus driven by Steve Mcqueen...
2012 650i convertible, titanium silver, vermillion red, M sport, IAS, ARS, premium sound w/B&O, cold weather, drive assistance, luxury seating, 20's, leather dash, ceramic controls, BMW apps. 2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... 2010 Escalade ESV Platinum nuff said.... 2011 550ix (gone) |
#25
My experiment is just that, an experiement. It's not going to tell you with 100% certainty that a non ARS car is better than one with it. As you said, the default setting may differ than a non-ARS car. Also, the DDC tuning may be different as well as spring rates. Bottom line is that it's not the way that I'd run the car all the time, but gives you a bit of a peek into the life of a DDC car vs a DDC / ARS car.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
