E36 (1991 - 1999)
Old 12-19-2008, 04:24 AM
M5254 M5254 is offline
Mein Auto: 1997 3281 4 door sedan
Clutch switch??
1997 328i, Having a hard time starting the car at times with clutch in. Was told its probably the clutch switch? You cannot start this car unless you depress the clutch. Is it the clutch switch and are they hard to put in. Once I move the stick around and depress the clutch it starts its very erratic? But does start.
Old 12-19-2008, 08:14 AM
E36 Phantom's Avatar
I Am The Machine
If the car tries to start at all, then it's not the clutch switch. Clutch switch keeps the ignition switch from doing ANYTHING.
What do you mean starts erratic?
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 12-19-2008, 10:54 AM
ianiac's Avatar
ianiac ianiac is offline
<-NIKi
Send a message via AIM to ianiac Send a message via Yahoo to ianiac
Mein Auto: E36 M3
Once I wasn't thinking and turned on my car with out putting the clutch in. Actually, accidental did that on both my e36's.. It started.. Just took a fraction of a second longer to turn over..
Old 12-19-2008, 03:09 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Eh??
We dont have this over here...
2001 Mini Cooper R50
Edirty6 for life
Old 12-19-2008, 05:09 PM
e30e e30e is offline
Search: Top right corner
Mein Auto: e36 m3/4
Originally Posted by Pirate_copy View Post
Eh??
Were stupid americans and its in the name of safety.
My buddies f-350 has it and you have to stomp the pedal as you turn the key in the ignition, pretty funny to watch
Old 12-19-2008, 05:14 PM
E36youngster's Avatar
E36youngster E36youngster is offline
blank
Mein Auto: 07 e92 335i
i dont have a clutch switch. i can start mine without depressing it, just have to make sure its not in gear or bad things happen
Old 12-19-2008, 06:26 PM
Mein Auto: e36 m3/4
I believe its the OBD-II models that have it, both my 96 and 97 have it but 93 didnt.
Old 12-20-2008, 11:09 AM
I Am The Machine
Yep, it's OBDII only.......
When I bought my E36, the owner had left it in his driveway and in 1st. I guess he usually parked out of gear in his garage. Anyway, he reached in and turned the key over, and it took off. He had to dive back in to get the clutch and e-brake. Came about 6" from his garage door.......
We had some fun with that one.....he was quite embarrassed.
// Chad //
You're a derbanana
Old 07-20-2015, 04:15 PM
stevengtron stevengtron is offline
Mein Auto: 97 318ti
clutch switch?
Alright, first time on here. Let's see you anyone can help. I have a 97 318ti, one day when I was turning off my car, it won't turn off on me; had to stall the clutch and now it won't turn back on. I switched out the starter and the ignition switch, as I was taking out the switch, I saw that the ignition lock cylinder housing was NOT moving as I turned the key off/on. So I got some pliers and played around with it, the spade at the back of the housing shot right back in. Now the spade shoots out but to turn it off I need to take the key out and put it back in and turn it off. Here's the problem, as I turn the key on, thinking( I fixed the problem) it WONT start. The lights work, the radio is on , the starter even kicks over put the car won't start. What could the problem be?
Old 07-20-2015, 04:27 PM
mywidebody02 mywidebody02 is offline
Mein Auto: 96 328is & 11 328i xdrive
I have a 96 328is is and it starts with out pressing the clutch.
Sent from my SAMSUNG-SM-G870A using Tapatalk
96 328is Alpineweiss
M2 Exhaust
CAI
Old 07-22-2015, 05:20 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Your production model must be before June 96. If it is after, your car was built by accident without the clutch safety switch.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 07-23-2015, 05:45 AM
It is 11/95
M2 Exhaust
CAI
