E36 (1991 - 1999)
Old 07-08-2015, 03:29 PM
Fidel_Jm Fidel_Jm is offline
Mein Auto: Bmw e36
Door handle
My door handle from the outside won't open, it is struggling to get it to work, but the key lock still works it's just the handle. However from the inside it does open my car
Old 07-08-2015, 04:37 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
The actuator arm on the outside handle is broken. No really reliable way to fix it. You'll have to replace it. The key tumbler can be transferred from your current handle to the replacement. The handle replacement is a PITA job. Pelican Parts has a pretty good DIY on it.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 07-09-2015, 06:07 PM
Culprit83 Culprit83 is offline
Wanders Aimlessly
Mein Auto: '98 328i '97 328i
The tumblers changed somewhere around '94 so they are not a direct swap (assuming you get a used one). You would have to do a little extra work exchanging from one to the other. If you purchase new, just make sure you get it for your model year.
Old 07-09-2015, 10:18 PM
bronx1987's Avatar
bronx1987 bronx1987 is offline
Mein Auto: Fiat Punto, E36 track car
This ^
I found it out the hard way, my car is a 4/94 model and i swapped with a 7/94 model, door handles all the same, but tumbler was not interchangeable.... so I had to build my own one....
Old 07-10-2015, 08:50 PM
Wanders Aimlessly
Originally Posted by bronx1987 View Post
This ^
There is a way to swap the little metal prongs (don't know their actual name) so the key will work in the other tumbler. It takes a little extra work, but it works.
Old 07-10-2015, 10:54 PM
Daggerty's Avatar
Daggerty Daggerty is offline
Officially broke
Mein Auto: 1995 BMW 325is
By prongs do u mean the pins inside the lock?
Old 07-11-2015, 01:43 AM
bronx1987's Avatar
I attempted that, however, it did not work.
Old 07-11-2015, 01:52 AM
Daggerty's Avatar
Officially broke
A lock smith would do it for a reasonable price even if u don't know what order the pins were in
Old 07-11-2015, 08:57 PM
Wanders Aimlessly
Yea, I meant pins. I did it on my coupe. The lock smith will work too, although around here they want registration documents on BOTH cars in your name. I would hope this is not the case everywhere. After two calls telling me the same thing, I gave up and tried the swap myself. Again, it worked for me.
Old 07-22-2015, 04:55 PM
vwdavi vwdavi is offline
Mein Auto: 1993 BWM 325 is
I have replace several of them it easy to do does take some time key is take off the door panel, and the our side cover is removed by inside the door look for the rubber cover and see this will release the door handle cover.
