E34 (1989 - 1995)
Old 09-29-2011, 09:46 AM
PFCWITTNER PFCWITTNER is offline
Mein Auto: BMW 525i (91)
Please Help! 1991 E34 Trans Program
Hello I know that this topic has been discussed in the past and I need some advice. I purchased a 91 E34 about 3 months ago for $450 dollars. The Transmission was bad when I purchased it, so I pulled the tranny and rebuilt it. After putting the tranny back in the car It will not engage at all. when you rev the engine the "trans program" comes on the instrument cluster. I have looked at everything in the previous forms and began to see that the previous owner had already been in all of the suggested repair areas! The transmission did have burnt clutches and needed to be rebuilt. The last thing I did was disconnect the upper transmission cooling line from the radiator and start the car... after putting the car in gear NO FLUIDE CAME FROM THE HOSE! Does this mean the oil pump in the transmission is bad? Any Suggestions?
Thank You;
PFC Wittner
Old 09-29-2011, 10:45 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
potentially. However i would be more incined to think, based on what you have said, that there is not enough oil in there. These transmissions take a LOT of oil, a lot more than youd thinking. Mine took about 5 Liters or so.
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 09-29-2011, 10:54 PM
when I filled the transmission I put around 6.5 quarts of fluid in it... So im not sure that that is the problem, im going to test the torque converter tomarrow...
Is it possible that the screw on the outside of the case next to the front cooling line could be causing this problem if over tightened? What is this screw for and does anyone knpw if there is a specific torque for it
Kind regards PFC Wittner
Sent from my SGH-T959 using Bimmer
Old 10-21-2011, 08:16 AM
So found the problem... When I put the trans on I did not line up the torque converter notches to the correct place and broke the male notches on the oil pump gears... Ooops, I guess you learn from your mistakes but other then that the trans works great. Not too bad for a first time trans rebuild. Thank you everyone for helping...
Old 10-21-2011, 08:33 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Glad you got it fixed. I wish I had the cajones to try a tranny rebuild. But alas, even if I did, my overall health would probably not allow it considering my bum knee and all ....
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
