Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 09-29-2011, 07:40 PM
PsychDoc1's Avatar
PsychDoc1 PsychDoc1 is offline
Mein Auto: 535xi
(Stupid?) Question about "Auto-H"
I notice that if you set this when you come to a stop you really don't have to disengage it when you want to go. All you have to do is step on the accelerator. The "Auto-H" green light remains lit between the speedometer and the tachometer and the car seems to automatically go back into full auto-H then next time the car comes to a stop. Is there any down side to leaving the auto-H engaged or should you always put your foot on the brake and disengage it from the button behind the shift stalk when you want to begin going again. If you leave it permanently "on" are the brakes always partially grabbing the rotors or anything like that?
Again, sorry I advance if this seems like a stupid question.
2011 535xi, Space Gray, Cinnamon Dakota Leather, Anthracite Wood, PP1, PP2, Top/Side Cameras
Prior
Acura TL, Lexus ES (2), Volvo S70 GLT, Volvo 850 Turbo, Lexus LS, M-B 300E, BMW 735i, Audi 5000
Old 09-29-2011, 07:44 PM
bavariancraving bavariancraving is offline
Mein Auto: 2011 535i M-Sport
Haha... I asked my SA the exact same question! He told me that it automatically disengages completely when the throttle is pushed and only engages when a true complete stop is reached.
Old 09-29-2011, 07:52 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
+1. Auto-H has no effect until you come to a complete stop. You can coast at 1/2 mph and nothing happens. And it doesn't engage the parking brake each time, it simply holds the pads against the rotors until released. If you shut down the car in Auto-H, the parking brake will automatically engage. (And then you can hear the parking brake motor). BTW you can disengage Auto-H while in motion. The only time you have to apply the brake to disengage it is when you are actually stopped and it is holding the car. All that said, I don't always like it, I only use it occasionally.
BMW-CCA
Bimmerfest Supporting Member
2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm
Old 09-29-2011, 07:58 PM
Quacker Quacker is offline
Mein Auto: 2012 535i xDrive
I think it's a pretty clever system. The only downsides I can find are:
1. It puts on the parking brake for you when you shut the car down. I don't care for that.
2. If you get too used to it and start driving another vehicle or even your vehicle without it, you may start to roll after stopping and not notice it until you tap the guy in front of you.
2012 535ix Space Gray, Cinnamon, SAT, Premium, Prem sound, Cold W., Sunshades, Gloss Black Grille, Gloss Black Side Markers, RE970AS 245/45/19 non-run flats that run very smooth + quiet and also correct the otherwise optimistic speedo
Old 09-29-2011, 08:02 PM
markl53's Avatar
One other thing -- if you forget it's activated, your car will act "weird" in some maneuvering circumstances. I stopped at a gas station once when I forgot Auto-H was set on and I couldn't figure out why the car wouldn't roll back when I tried to back up to jockey into position at the pump.
BMW-CCA
Old 09-29-2011, 08:20 PM
yogi799 yogi799 is offline
Mein Auto: '11 535i, '99 328i retd
You don't find the damn throttle delay annoying enough to have another *feature* delay your take-off even more???
2011 535i F10 delivered
1999 328i E46 retired
LOGMYMPG sponsored by ckvideo.ca
Old 09-29-2011, 08:33 PM
PsychDoc1's Avatar
Mein Auto: 535xi
Not sure I'm understanding this. You say "the only time you have to apply the brake to disengage it is when you are actually stopped and it is holding the car." I thought it disengaged as soon as you hit the accelerator.
Prior
Old 09-29-2011, 08:56 PM
dunderhi's Avatar
dunderhi dunderhi is online now
0-60 in 4 secs or less!
Mein Auto: '13 X5M, 650xi
I've tried Auto-H a couple of times and didn't care for it. If I know I will be at a long light or waiting for than a moment or two, I put the car in Park. You can feel it when the burden is lifted off the engine.
BMWUSA 650i xDrive Build Link ...................................BMWUSA X5M Build Link
2013 X5M ........ 2013 650xi ...... 2011 550xi (ret) 2011 335d (ret)
Old 09-30-2011, 04:45 AM
bill13070 bill13070 is offline
Mein Auto: 2011 X5 35D
Disengage / deactivate
Seems a bit of confusion with terms but in a misguided attempt to clarify
If Auto hold is on and engaged ( car stopped ) you can start off moving by only pressing accelerator to go. This actually allows you to get away from stop quicker as you are not transfering the right foot from brake to acc
If Auto hold is on and engaged ( car stopped ) and you want to deactivate system then you must push foot on brake then push button to allow system to deactivate
If Auto hold system is on but not engaged ( car moving ) then you can simply press button to deactivate
Old 09-30-2011, 04:53 AM
Erregend's Avatar
Erregend Erregend is offline
535i M-Sport ED May 2011
Mein Auto: '11 M-Spt 535i & '04 SLK
Don't worry, the two "delays" will overlap and you won't notice a thing.
By the way, how often do you do "rabbit starts" anyway? I get about one or two opportunities a day. [And, no throttle delay in my 04/28/11 built 535i.]
Old 09-30-2011, 07:38 AM
markl53's Avatar
Yes, thanks. Psych had implied that you always need to hit the brake to turn off Auto-H (not engaged) and I was trying to reply to that. The system makes perfect sense. It won't allow a shut-off when it's holding the car unless you take over the brake pedal. Same as with releasing the parking brake.
BMW-CCA
Old 09-30-2011, 08:26 AM
Seriously, it goes exact moment you press the gas pedal?? Whoa.... I have a noticeable delay.
Old 09-30-2011, 09:31 AM
Mine has no delay associated with it. It's off the moment I touch the gas.
Old 09-30-2011, 09:59 AM
Erregend's Avatar
Do you have SAT? How about Dynamic Drive?
Even quicker throttle reaction in "Sport" or "Sport+" modes and/or with SAT on Sport mode.
Could be that the electronic throttle response curve is steeper in those modes.
Old 09-30-2011, 12:06 PM
Nope just the base model 535i with auto tranny. Damn... maybe I should get it checked out then... I have at least .5 sec delay before the car moves. I should probably start a new thread about it (initially I thought I could live with it, and maybe I could, but why is some don't experience it).
Old 09-30-2011, 12:12 PM
Unless we're confusing things... What can be QUICKER than instantaneous? My old e46 and MDX move off the line when you step on the gas, same on my '11 Acura TL loaner. What can be QUICKER than that? So I'm guessing you also have a delay, since quicker is in your vocabulary, just maybe didn't notice it as much (NO sarcasm here whatsoever, just trying to make sure we're on the same page talking about "delays").
I definitely need a new thread, sorry for partaking in a nasty hijack.
Old 09-30-2011, 12:32 PM
soulunderdog soulunderdog is offline
As mentioned in another thread, I like this feature quite a bit. I only use it when I know I'll be in significant stop and go traffic. It can be a pain in parking lots or gas stations, so I've learned to turn it off in those situations. Taking off is instant and as someone posted above just a tap of the acceleration gets you moving again. BTW - no delay with my car..
2011 535i - Space Gray, Black Dakota, Sport, SAT, PP2, CA
Old 09-30-2011, 02:09 PM
markl53's Avatar
+1. Standard base 8-spd auto 535i.
BMW-CCA
Old 09-30-2011, 05:03 PM
alex md alex md is offline
Mein Auto: 2011 550xi M sport
i dont care for this feature, came in my 550 xi M , BUT I WOULD NOT paid for this option
use it only in a heavy traffic in NYC
2013 X3 3.5 ZMP,ZCW,ZPP,Carbon black/black/wife/ 2011 550XI ZMP,ZCW,ZAV,ZP2,610,465,5DL,2TB,416,LC ED6/28/11
2007-2011 X5.4.8/E70/
2010-2012 GLK 350/wife/
2008-2011-328XI
2004-2007-CLK55
2007-2010-X3 3.0
2001-2004-A8 4.2
2004-2007 X5 3.0/E53/
1999-2001-SL500
1996-1999-ML320 4MATIC
1992-1995-VOLVO 850 TURBO
1990-1992-525I
1987-1990-OLDSMOBILE CS
1981-1987-LADA/VAZ 2105
Old 10-02-2011, 01:20 PM
schraderade schraderade is offline
Mein Auto: 2011 550i
I love this feature. I live in San Francisco with traffic and HILLS. This city was made for Auto-H
