Old 09-30-2011, 04:19 PM
sunny 2005 bmw sunny 2005 bmw is offline
Mein Auto: Bmw 2005 545
Help on replacing coolant Expansion tank
I just had my coolant tank develop a hair line crack. Changing it look easy but I canít seem to figure out how to remove the two hoses attached to the tank. Could someone please tell me how to remove these. I have changed the whole coolant system on my jeep but these clamps look very different than I am use too. I found a picture below.
Old 09-30-2011, 07:23 PM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
use small flat head screw driver slide out those wire clips. Then use slightly bigger flat head screw driver to pop out the hose (prying it on the edges, go around slowly). Just be careful not to break the conector at the end of the hoses.
Old 10-01-2011, 04:48 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
take this opportunity to inspect the condition of all hoses, radiator, water pump, and thermostat.
Old 10-05-2011, 10:58 AM
thank you Took it to the dealer it was the radiator vent hose instead of the tank. The dealer wanted $400 i will do it myself
