Old 10-01-2011, 11:00 PM
teklord69 teklord69 is offline
Mein Auto: 2001 330ci 5-Spd
DISA Autopsy
I got bored and opened up the DISA. It was pretty hard to pry apart but I wanted to see the internals of this overpriced piece of plastic.
The rod is actuated by vacuum to move the yellow plastic up and down. At 100K miles, the rod as well as the metal clip that holds it to the yellow piece looked good, nothing was cracking or brittle from what I can see.
The vacuum is done by this spring and rubber (silicone?) plunger. The spring looked good as well as the rubber part. It was still flexible and seemed air tight.
The design flaw is here. This is where the DISA flap is connected to. After thousands of movement opening the flap on and off, it stresses this part and will eventually break.
This and the seal of the DISA valve to the intake manifold are the weak links.
ID:	295549   Click image for larger version
ID:	295550   Click image for larger version
ID:	295551   Click image for larger version
Old 10-02-2011, 05:23 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Thank you for taking the time and energy to autopsy your DISA (for the team)!
A few questions come to mind as I look at the nice photos:
Q1: Where does the DISA get its vacuum (there is no vacuum hose connection, for example so, does it 'make' its own vacuum)?
Q2: What happens when you put 12 volts DC to your DISA valve (presumably it will generate the vacuum to open the valve)?
Q3: Both Doru & Bazza-Aus noted the new DISA o-ring is 'ribbed and glued' while the old DISA o-ring is flattened; did you see the same phenomenon with your old & new DISA?
BTW, would you kindly compare the before-and-after closeups of the rectangular-cross-section o-ring side by side?
Here's what seems to be the case based on old/new DISA pictures from Bazza-Aus in this post:
- E39 (1997 - 2003) > DISA 0 Ring
Originally Posted by Bazza-Aus View Post
The sealing is done via a built-in "lip" on the base of the unit that mimics an o-ring.
BTW, we need a better non-destructive TEST procedure!
- How to test DISA operation on the BMW E39
And, for the record, here's another DISA autopsy:
- E39 (1997 - 2003) > Press Gas, hesitation, stall...
Wear melt on corner.
Crack on pivot.
Distortion when open.
Notice the ribbed new DISA o-ring:
Notice how THIN the new DISA o-ring is:
Notice the new DISA o-ring is contiguous with the valve ring:
Note: I'll cross reference this nice autopsy to some of these threads for others to find:
- Why check the DISA at 85K miles to 90K miles or whenever the airbox is removed (1) (2) & how to repair a rattling DISA unit (1) (2) (3) & why the DIfferenzierte SAuganlage ("Differential Air Intake") valve flap breaks (1), sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) & how the disa valve o-ring fails (1) (2) & how it can cause all sorts of cold-engine rough idle problems (1) (2) & where to get just the DISA valve o-ring (1) & how the DISA valve operates (0) (1) (2) (3) (4) & an example of how a broken DISA valve can ruin your engine (1) & how to test DISA operation (0) (1) (2) (3) (4) & how to install an M54 DISA DIY (1) & a nice DISA autopsy (1) (2) & yet another seemingly complex set of misfire codes reputedly traced to a broken DISA valve (1)
Old 10-02-2011, 08:34 AM
Fudman's Avatar
Fudman Fudman is offline
Nice analysis, CSI Teklord!
Old 10-02-2011, 09:25 AM
No vacuum hose. There is a nipple that sucks air inside the valve.. Not sure what the electrical connection really does. I know that the spring and rubber piece is what creates the pressure for the rod to go up and down. Anyone care to chime in?
The new DISA O-ring is ribbed like that to create a one-time seal. Im guessing it flatens out shortly after you put in along with the heat of the engine. Thats what I said, its a one time deal once you take it out of the engine.
I could be wrong. Since this is new part#, it could be the major change is a flat ring vs. a ribbed one.. Who knows.
Old 10-02-2011, 11:22 AM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
moderator
please change the name of forum
bimmerDISA.com
Old 10-02-2011, 04:32 PM
gchand's Avatar
gchand gchand is offline
Mein Auto: 03 530i sport
valve gets its vacuum by being connected to the intake manifold I'm guessing.
Old 10-08-2011, 06:59 PM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
Not at all. The vacuum is part of the dampening for the DISA. It's self contained.
Old 10-08-2011, 10:34 PM
bluebee's Avatar
I'm confused since there is no vacuum hose going to the DISA, yet, people say it works on vacuum.
Does the 'motor' on the aft end of the DISA generate vacuum to turn the valve?
Old 10-09-2011, 06:27 AM
Entwicklung 39
It doesn't actually "work" on engine vacuum. The flapper valve is dampened by a spring and a air-tight bellows. That system forms resistance at a set rate to the air flow in the intake manifold. In my case, the bellows had failed and the flapper valve moved freely within the DISA housing therefore offering no resistance to the air flow.
Think vacuum secondaries on a Holley carb.
Old 10-09-2011, 03:14 PM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
Precisely. There is a small ~1/16 dia hole on the intake side of the DISA, inside the circular profile gasket. It seems to be a passage into the recctangular box. This box seems to be a vacuum reservoir. The solenoid valve is likely a 3-way type .....it applies vacuum to the actuator (when energized) or it vents this vacuum to atmosphere when de-energized.
Bluebee, how's your resealed DISA holding up? Have your lean codes stayed away?
Paul S
BMW CCA 69606
Old 10-09-2011, 05:24 PM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
Paul S
BMW CCA 69606
Yep, this is 100% correct. The large plastic box is the vacuum reservoir. The 1/16" hole leads internally to a 1/4" round pipe. In this pipe is a white filter screen that when removed holds a 1-way check valve in place. ( See the OPS first photo.) This way when you stomp on the throttle and vacuum goes to near zero, the DISA works of the vacuum in the reservoir.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 10-09-2011, 06:35 PM
bluebee's Avatar
I tested my CCV and re-inserted my DISA; yet the large set of lean codes remain!
- Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (1)
Is this what you guys are referring to?
Old 10-09-2011, 07:29 PM
gtxragtop's Avatar
Yes, inside of the plastic pipe/tube underneath the white filter is a one-way valve. If you look on the DISA valve side (intake manifold side) you will note a small 1/16" hole.
As for your lean codes, I noticed on my 03, that the vacuum tubing is deteriorating. for example, the small hose from the fender well to the air hose between the MAF and the other
air hose that goes to the throttle body was not looking too good. So I replaced it and in doing so I noted by bending it is cracked wide open. You may have a cracked hose
somewhere leaking air. The tubing BMW used like most of the other plastics is not of a good American brand tubing like Gates.
Old 10-09-2011, 07:40 PM
Entwicklung 39
Nope. Engine vacuum does not affect DISA operation. Air flow across the flapper valve is regulated by spring tension and dampened by a bellows within the DISA. The more air flowing by the flapper valve the more it opens.
There is no interaction between engine vacuum and the DISA valve whatsoever.
Old 10-09-2011, 07:47 PM
gtxragtop's Avatar
I think I'm understanding your statement but I believe you are wrong. The secondaries work off vacuum. There is a small spring in the bellows that keeps the secondaries closed and provides for controlled opening rates. When you mash the throttle at low RPM, you end up with low vacuum. The secondaries will not open. As the RPM increase, so does vacuum and then the secondaries start to open. They open with vacuum. At low RPM when you mash the throttle, the secondaries do not open and hence no bog.
In the case of the DISA, it works off controlled vacuum. The 2 wires on the DISA are connected to a vacuum solenoid. It either blocks the passage of vacuum or allows it based upon the commands from the ECM.
Old 10-09-2011, 08:23 PM
Entwicklung 39
Perhaps a primer on venturi vacuum versus manifold vacuum is in order.
Old 10-10-2011, 02:18 AM
bluebee's Avatar
It would be nice to have a definitive explanation on what exactly is opening the flapper valve, and how ...
I don't disagree. The problem is finding it ... I'll look, one by one:
- How to locate all the vacuum hoses in the E39 engine bay (1)
Old 10-10-2011, 05:34 AM
BMW CCA 69606
This is wrong.
The DISA flapper is either fully open or fully closed. There is no intermediate position on a properly working DISA valve. A DME controlled solenoid uses manifold vacuum to close DISA flapper and spring action to open the DISA flapper.
Paul S
BMW CCA 69606
Old 10-10-2011, 08:39 AM
Entwicklung 39
This is wrong.
Paul S
BMW CCA 69606
I stand corrected Paul. My vacuum secondary comparison was also off. After much research I found this to be the best DISA operation decription I could find.
"The disa valve has an outer seal (inside the manifold) and a diaphragm inside the valve itself. The valve is constantly fed 12 volts during normal throttle operation and then open circuits on higher RPM and throttle opening. This deenergises the coil which stops the manifold vacuum from reaching the diaphragm. The butterfly then springs open."
Do you concur?
Old 10-10-2011, 11:38 AM
BMW CCA 69606
AG,
Actually I'm partial to the description in posts 10, 11 and 18 of this thread. However your research has found a description that is also consistent with my observations. The mystery to me was the vacuum source. I had my M54 DISA out for inspection recently and discovered the 1/16" port. My 129k DISA is fully functional, no loose or broken parts, no play in linkage, diaphragm holds vacuum, solenoid is functional. Another dose of form-a-gasket and I reinstalled it.
Paul S
BMW CCA 69606
Do you concur?
Old 10-10-2011, 06:47 PM
gtxragtop's Avatar
Just to be clear, the venturi have nothing to do with the opening or closing of the secondaries on a Holley carb. The venturi are used to create a low pressure area that allows atmospheric pressure to force the fuel to dribble (metered by the jets) into the carb throttle bore. When the butterflies are closed, there is minimal airflow across the venturi. No airflow, no low pressure zone, no fuel flow. As you open the butterflies, the airflow increases across the venturi, and out flows the fuel. The purpose of the choke is to create a low pressure zone at starting cranking speeds that results in engine manifold vacuum sucking out the fuel through the venturis. Remember at low cranking speeds, there is little airflow.
The Holley vacuum secondaries work as I described. The Carter AVS used on Mopars has a choke like spring loaded flapper valve on top. The spring tension is adjustable. The Rottenchester Quadrabogger (Rochester Quadrjet) had a similar design. Both relied on this choke like air valve to enrichen the mixture to prevent bogging when you stomped on the gas and the mechanical secondaries opened up. The Carter AFB and the Eldelbrock Performer series have the flapper valve between the butterflies and the venturi. It's sole purpose is to not allow full airflow when you mash open the secondaries to prevent bogging. The flapper has a fixed counter-balance weight on it. There is no adjustment.
Lastly there are the double-pumper mechanical secondary carbs. Like the primaries, they use a small pump to squirt extra fuel into the secondary bores when the butterflies are opened quickly. As airflow increase across the venturi, the fuel flows.
Old 10-10-2011, 06:57 PM
gtxragtop's Avatar
Found this http://blog.bavauto.com/8443/bmw-m52...084-p1085-etc/
And this on the Mt 330I forum. The photos are simply wonderful. Worth going through these on the various pages.
http://forums.my330i.com/showthread.php?t=8770&page=15
Old 10-10-2011, 07:16 PM
gtxragtop's Avatar
DISA theory... Takes a bit to carefully look at the diagrams. DISA valve is close to the engine side of the diagram.
http://2.bp.blogspot.com/_LzEU1X_t40...ntake1copy.jpg
http://3.bp.blogspot.com/_LzEU1X_t40...M54Intake2.jpg
http://2.bp.blogspot.com/_LzEU1X_t40...M54Intake3.jpg
I also found this (thanks to the my 330I forum) See post #92 This is the same diagrams with some text. Great stuff.
http://forums.my330i.com/showthread....d.blogspot.com
So based upon this description, with the engine not running put a mark on the external rod from the vacuum dashpot to the DISA valve. Start the engine and let it idle.
The mark should have moved since engine vacuum allowed to enter the dashpot will pull the DISA valve closed.
Old 10-10-2011, 10:17 PM
bluebee's Avatar
Review:
  • Title: BMW M52TU and M54 Lean Mixture Fault Codes DISA Valve? (P0174, P0171, P1084, P1085, Etc.)
  • Vehicle: 2002 BMW 530i
  • Diagnosis: Lean fuel mixture
    • Vacuum leak on intake
  • Visually check for:
    • rubber upper and/or lower intake boot
    • the plastic F vacuum hose connector on the boot
  • Run a smoke test to visually check for leaks in:
    • All vacuum hoses
    • oil-separator/check-valve system for the crankcase ventilation system
    • the throttle-body gasket
    • the intake manifold gaskets
    • and the various smaller vacuum hoses that run under the intake manifold.
  • Check the DISA
    • The flap door breaks and the valve no longer properly controls the intake air flow through the manifold.
Notice this article says that the DISA valve flap malfunction can cause lean codes. This is surprising (to me) since I 'thought' we determined the lean codes aren't from the broken flap but from a leaking o ring.
Q: What's the consensus on 'how' the DISA causes lean fuel mixtures?
ID:	296650   Click image for larger version
ID:	296651   Click image for larger version
ID:	296652   Click image for larger version
ID:	296653   Click image for larger version
Old 10-10-2011, 10:51 PM
Review:
    • All vacuum hoses
  • Check the DISA
I am still leaning on my broken DISA flap that cause the lean codes. I have read that link as well as many others on the E46 sites where replacing the DISA got read of the lean codes. Up until now my car hasnt got any codes since replacing the DISA.
