Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 10-02-2011, 01:03 PM
luker669 luker669 is offline
Mein Auto: 2004 645 coupe Black
aux-in
I won't bore you with the install of taking the radio out ,there are plenty of threads on that. If you are like me and think the aux-in in the glove box is in a stupid spot , you should like this. I ran the Wires under the center counsel and came up in the center arm rest .Also at the same time I ran 12V to have aux power ports. Very easy to do ,bought some material at hobby lobby to match 2.50 cents and the spray adhesive was 7 bucks at autozone. The aux-power plugs were 8 bu8cks each.I cut the corner of a old tool plastic tool box to make the piece inside the arm rest.
ID:	295596   Click image for larger version
Old 10-02-2011, 04:05 PM
bigtyme562 bigtyme562 is offline
Mein Auto: 2005 BMW 645
looks good
Old 10-03-2011, 03:06 AM
TimDogg's Avatar
TimDogg TimDogg is offline
Who u r, u r forever....
Send a message via Yahoo to TimDogg
Mein Auto: 2004 645ci
now THAT's "PRO"
Yes, I collect stamps....PASSPORT STAMPS!!!
2010 335i dressed in all black, 2004 645ci dressed in all black as well.....ok, i like black!
Old 10-04-2011, 10:27 PM
thx
Old 10-10-2011, 09:29 AM
amanra's Avatar
amanra amanra is offline
Mein Auto: 2005 BMW 645Ci
Looks great any chance you can put up a DIY on how you ran the wires through the center console?
Old 12-21-2011, 02:46 PM
stevelee203 stevelee203 is offline
Mein Auto: 2006 BMW 650I CONV.
well my don't have AUX
how can i add this AUX to my car radio system?
[/SIGPIC][/SIGPIC]2006 BMW 650I Convertible Black Saphire Metallic / Black
SMG
Premium Sound
Sport / Cold / Comfort Access
19" OEM
Logic 7 Premium
Sound HD Radio
Heads Up Display
Park Distance Control
K&N air filter
Aluminum Racing Pedals
6000k headlight upgrade
fog light upgarde
2010 MV AGUSTA F4 titanium/RED frame
2010 Audi Q5 S Line
Old 12-27-2011, 09:09 PM
hipertec hipertec is offline
Mein Auto: 2005 645ci
hoping you can share or link to a thread on how to get the AUX on our car. I dont have a AuX either but would love to get one so i can play pandora thru my phone.
Sent from my Transformer TF101 using Bimmer
2005 BMW 645ci - DPE 3pc Forged Rims, Coilovers, Britalman full cat-back exhaust system, , K&N Air Filter, LUMMA Roof & Trunk Spoiler.
Old 07-06-2012, 05:57 PM
any update information on this Aux?
SMG
Premium Sound
19" OEM
Logic 7 Premium
Sound HD Radio
Heads Up Display
K&N air filter
fog light upgarde
2010 Audi Q5 S Line
Old 09-20-2012, 01:18 PM
simple1 simple1 is offline
Mein Auto: 6 series
was it a hard install and what is the process you had to go through to tie into the system i own a 2005 645 that i would really like to move up to date thank you if you can help put me in the right direction
Old 10-27-2012, 12:35 PM
shan904 shan904 is offline
Does anyone have a detailed DIY on the aux install for the 05 645ci?
Old 10-27-2012, 03:37 PM
rebel.ranter rebel.ranter is offline
Mein Auto: 630i, 525i, 320iC
To enable the AUX function in your iDrive menu you need to enable it using coding software.
You can probably use the following software:
- Autologic
- Progman
But I know for certain that you can use NCS Expert.
In NCS Expert you connect to the car & change the setting AUXIN from nicht_aktiv to aktiv in the MASK or CAPPL module depending on what you have in your car. You also need to add +NAUX to the VO (Vehicle Order), the VO is usually stored in the CAS & LMA modules.
There's loads of sites with DIYs for updating the VO & coding modules. The changes above would take 5-10 minutes all in. Progman has a fancier GUI & it might be easier to do but it will take longer.
You then buy a retrofit kit, part number: 65 12 0 153 502
Here's BMW's own guide for performing the retrofit for the e60 & e63/4, it is largely the same, all the hardware in our cars are e60.
http://www.kneb.net/bmw/E60-1/Aux%20Input.pdf
