Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 10-02-2011, 06:31 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
Removing Battery During Storage?
The late model BMWs don't allow for easy removal and disconnection of the battery due to the complex electronics. What about the E24? I will probably not drive my car for several months so I would like to remove the battery and place it on a Battery Tender for the winter months. The garage that I use for storage doesn't have any electricity so I can't use the Battery Tender while the battery is in the car. Will I have any issues other than resetting the radio station presets? Thanks.
COL(Ret), US Army
Hagerstown MD
2016 528ixdrive/MSport
2016 Corvette Stingray (Fun Car)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2013 Audi A4(Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Old 10-03-2011, 08:46 AM
catso's Avatar
catso catso is offline
catso
You'll probably have to reset the radio security code, so make sure you gat it when you take possession of the car. You may also want to add some gas stabilizer to the fuel.
![/I][/FONT]
Old 10-03-2011, 10:56 PM
Roku35's Avatar
Roku35 Roku35 is offline
Full Blown Euro Addict
Mein Auto: 1985 Euro E24s
Not going to drive your newly acquired E24? The battery is extremely accessible and switching them in and out will be no problem at all. Setting the OBC is a little tricky the first few times you have to do it, but after that, you will be able to do it in your sleep. Most of the time, all I really want to work is the clock , since it stays on all the time.
635CSi CR 5-Spds (Schwartz & Polaris Metallic )
628CSi Automatic (Zobelbraun Metallic)
540iT Sport Automatic (Schwartz)
http://hawaiisharks.tripod.com/
Old 10-04-2011, 05:43 PM
rmorin49's Avatar
I do plan to drive it on nice days but if the weather gurus are correct, they are predicting a cold and snowy winter for the eastern US, thus the car could sit for weeks without being driven. I hope to be able to install an outlet in the garage I am renting as it has lights but no outlet for a Battery Tender.
COL(Ret), US Army
Hagerstown MD
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2013 Audi A4(Ret)
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 10-04-2011, 05:47 PM
catso's Avatar
catso
If it has screw-in type incandescent bulbs you can just get a screw-in outlet adapter at most hardware stores.
![/I][/FONT]
Old 10-04-2011, 07:08 PM
rmorin49's Avatar
Correct, I have a couple of these but there are 2 lights and I didn't want to have to leave the other light on as they are both switched on with the same wall switch. I guess I could remove or loosen the bulb so it won't stay on. There is a junction box that I can tap into and mount an outlet on the wall if the garage owner is OK with this approach.
COL(Ret), US Army
Hagerstown MD
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2013 Audi A4(Ret)
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 10-05-2011, 10:12 PM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Smile Battery removal
I don't recommend that you remove the battery for too long as the rechargable backup battery in the dashboard service indicator circuit board will drain out and you most likely will then have to replace the service indicator circuit board, This is not the easiest job for a novice.
Old 10-15-2011, 07:47 PM
rmorin49's Avatar
Thanks, I hope I can get permission from the garage owner to install an outlet in the garage so I can use a Battery Tender.
COL(Ret), US Army
Hagerstown MD
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2013 Audi A4(Ret)
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 10-21-2011, 03:53 PM
Bimmmerdude Bimmmerdude is offline
Mein Auto: 2007 6-series
The late model BMWs don't allow for easy removal and disconnection of the battery due to the complex electronics. What about the E24 aftermarket parts? I will probably not drive my car for several months so I would like to remove the battery and place it on a Battery Tender for the winter months. The garage that I use for storage doesn't have any electricity so I can't use the Battery Tender while the battery is in the car. Will I have any issues other than resetting the radio station presets? Thanks.
I see your in MD and yup, they're going to get hit nasty in the Montgomery Country area. Horrible for a nice e24
Old 10-22-2011, 08:14 PM
rmorin49's Avatar
If the weather service is right, we are supposed to be in for a colder and wetter(snow) than usual. The owner has provided an outlet for my Battery Tender so I am all set.
I took the car out today for the first time, drove about 120 miles to a Street Survival School sponsored by the local BMWCCA chapter. Car drove like a dream and I got 22.7 mpg cruising at 65 mph.
COL(Ret), US Army
Hagerstown MD
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2013 Audi A4(Ret)
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
HTML code is Off
