Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 10-02-2011, 06:58 PM
rayshaaky rayshaaky is offline
Mein Auto: 2006 bmw m6 dinan
Just bought a 2011 bmw m3
I have BMW apps, but don't have an iphone i am going to get one. But when i do, i just put it in the cradle?
So i have an IPOD touch, what adapter do i need so i can see all the songs, playlist, etc on the i-drive screen?
Ray
Here's some pictures
Uploaded with ImageShack.us
Old 10-02-2011, 09:50 PM
richard1138 richard1138 is offline
Mein Auto: 335i sedan
Wow, really good time to get an M3 I guess, I just got mine Friday, and if I'm counting correctly that makes 7 people this weekend that just got M3's!! Dang!
AT any rate I THINK the iPOD just plugs right into it. I'm using a Nexus S, and I'm able to play my music thru the audio system with no adapter whatsoever. It just plays the audio over Bluetooth. It's really nice, not having to have an extra cable to dangle out of the console.
Not sure if iPod's have bluetooth these days, but if you plug it into that interface in the console you should be able to see you playlists and stuff on iDrive. Good luck!
~Richard
Old 10-03-2011, 06:48 AM
kscarrol's Avatar
kscarrol kscarrol is offline
Mein Auto: 2011 E90 M3 + 1997 Z3 2.8
Assuming the car was built after Spet 2010, the standard white Apple cable that came with the Touch is all you need...
Old 10-03-2011, 07:10 AM
Well, it's a 2011 so i believe the car was built after sept 2010.
Old 10-03-2011, 07:57 AM
kscarrol's Avatar
You can look on the door jam inside on the driver's side, there will be a small plate which shows the production date in month/year so that July '11 build will show 7/11... The "official" 2011 MY in the US started before Sept '10 so there are some '11's out there without the combox (which allows the display of album art and uses the Apple cable). Pre-Sept cars use the BMW "Y" cable to connect Apple devices...
Edit: Nevermind, just re-read the original post! If you have BMW apps then yes, standard white Apple cable will do the trick for the Touch...
Old 10-03-2011, 05:28 PM
On Idrive how come i cannot delete contacts from the phone book? It just lets me edit contacts. What's the fastest way to delete contacts from IDRIVE?
