E46 (1999 - 2006)
Old 10-04-2011, 05:26 PM
john2654 john2654 is offline
Send a message via Yahoo to john2654
Mein Auto: 2003 330xi
WTB: e46 1999 3 series valve cover
Well I cracked the port that goes around the spark plug trying to remove the old gasket.
Anyone have a good used valve cover?
I have a 1999 323i sedan e46
Sold- 2003 BMW 330xi Sedan, 1999 BMW 328i Sedan, 1999 BMW 323i Sedan, 1992 BMW 318i Sedan
Old 10-05-2011, 03:40 AM
stickbuilder stickbuilder is offline
Mein Auto: Touring and others
Check with BavAuto, ECS Tuning, Pelican Parts, or your local dealer. A used one that has been through that many heat cycles will be brittle as well.
Old 10-05-2011, 07:18 AM
Bavarian Auto Recycling hooked me up for ~$105 including shipping.
Thanks.
My original cover wasn't brittle, I thought I was smashing the hard, crusty gasket out but instead I was breaking the valve cover. I will be a lot more careful this time!
I'm guessing I also have to buy a new gasket set because the new one will be on there for about 2 weeks.
Oh well, another costly lesson learned.
Old 10-05-2011, 03:58 PM
Be sure to change all the seals under the bolt heads (nuts) there are about 15 of them, and if you don't replace them along with the new gasket set, I'll bet you have a leak.
Old 10-05-2011, 04:15 PM
Tfk's Avatar
Tfk Tfk is offline
My Spoon Is Too Big.
Mein Auto: E46 1999 MT
I have one laying around from my old 2.5
pm me.
Old 10-05-2011, 05:47 PM
Really?? There weren't any on there before and none are included in the gasket set.
Old 10-05-2011, 06:04 PM
Oh the valve cover washer seal/ grommets? Yeah I replaced those. Will replace again with the new install.
Old 10-25-2011, 07:57 AM
Ughhhh... After 3 weeks of waiting. I tried calling Bavarian Auto Recycling to see where my valve cover was. After multiple calls (because no one would pick up) I find out that all the covers they had, had cracks in them. Now they are refunding my payment. Why did they wait until I called them?? Just hoping I would just forget about it?
Anyone got a non cracked one available?
Old 10-25-2011, 08:21 AM
Guess I should just ask if it is even necessary to replace my valve cover.
Here is a similar valve cover.
When I was prying with a screwdriver trying to removing the crusty old gasket, I cracked a piece off. I tried showing in the following picture by circling (or the arrow) of what part I damaged.
It is a piece off the inside circle which goes over the spark plug hole. The outer circle is still there. My dad said that it should be fine and not leak because of the new gasket part that fits in between the two and the outer plastic circle still there.
Any thoughts? I was just worried and wanted a whole new cover.
Old 01-17-2013, 01:45 PM
JoshBosh JoshBosh is offline
Mein Auto: 1994 BM
Did you end up replacing your valve cover or just using the cracked one? If you used the cracked one, could you please let me know if it gave you any problems. I had the exact same thing happen and was considering just using it because I figured the new gasket should keep it pretty well sealed. Thanks!
Old 01-17-2013, 01:53 PM
I just used the valve cover as it was. Since the outer ring was still intact, it did not leak.
Was just fine until I sold the car.
