00 740i - Losing oil - Bimmerfest - BMW Forums
Old 10-07-2011, 08:31 PM
bimmerboz bimmerboz is offline
Mein Auto: 2000 740
my 2000 740il has an oil leak at the rear of the engine
Old 10-08-2011, 06:48 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Rear main seal failure/or rear gasket (to fix that engine has to be removed).
Most likely is valve cover gasket. they are leaking on the block (under the intake manifold/ between heads), but the block has 2 draining hols at the rear, which will fool a rear seal failure.
In pic attached the draining holes are clogged. One draining hole is where the yellow ring is.
JOY = BMW
Old 10-08-2011, 09:58 AM
rplecty rplecty is offline
Mein Auto: 740IL
What happens if those draining holes get clogged?
Sent from my HTC Wildfire S using Bimmer
Old 10-08-2011, 04:57 PM
silverhair silverhair is offline
Mein Auto: 98 740i
Then the oil will have a hard time draining and just pool up there. Am I correct Joyism.
Old 10-09-2011, 11:26 PM
joyism5's Avatar
Yeap! You will get so much oil in there , it might be visible under the throttle body. Finally will drip at the rear of the engine because of gravitation.
JOY = BMW
Old 04-26-2012, 04:58 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
@ Bimmer boz
Is the leak visible through the transmission bell housing inspection hole? If its your rear main seal, you don't have to remove the engine. My indy quoted $500 to drop the exhaust, drive shaft, and transmission. All three have to be removed to replace the seal. Good luck.
Big Boyz with Bad Toyz.
HTML code is Off
