X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
I am planning to replace X3 Front breaks as it time. Can you suggest which break pads should i use? Should I go with original BMW break pads or can I use other Break pads that will fit X3. If i have to use Other which one is recomended? How long will break pads last?
There is a lot of info on brake pads and the difference between OEM and aftermarket pads in these threads. Brakes are pretty much driver specific in that some drivers will get a lot of miles out of their pads and rotors while others go through them very quickly. This depends on how you drive your car. Generally the rear pads on an X3 wear down first, then the fronts about 15 or 20K miles later. Again all depending on how the car was driven. The rear pads may not need new rotors, the front pads almost certainly will. You don't mention if your car is under some kind of warranty, if not then a good independent (indy) BMW oriented shop will be a good place to have the brake work done. Actually, brakes are not difficult to install and virtually any quality brake shop can do the work if they have the right pads and rotors. A light will go on when your brakes need work. Check your manual and familiarize yourself with what all the little warning icons on the dash mean. Good luck and check out the other threads here for more info.
I went with centric rotors and Pagid pads, feel just like new OEM
When mine go that is what I will look to. Speed and extra power is always a priority with me, but brakes I never skimp on. Having an engine fail is a pita. Brakes a matter of life and death.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
I am going to call Tirerack today and see if I can return them. But in no way do Hawk's compare to OE. I found out the hard way. |
BRAKES please
BRAKES BRAKES BRAKES
I hope my brakes don't break If your brakes break get new ones I broke my brakes braking to hard My broken brakes aren't braking well I braked with my brakes hoping not to break anything I braked hard with my brakes
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired |
I went with Zimmerman Coat-Z rotors and Cool Carbon BRAKE pads on both of our vehicles. Couldn't be happier with that setup!
Cool Carbon
Where and what did you hear about these pads. How do they compare to OEM and how about the dust. Have you had to lay on them really hard yet, and if so did they fade? How much and where did you get them?
Sorry for all the questions.
Unfortunately, they are a little pricy. I think around 110.00 per axle for the brake pads from Bavarian Auto. I haven't had any brake fading whatsoever. Even on my 330i I've had no problems during an autocross or under spirited driving. I do change the brake fluid every 2 years too. Also, its recommended that you do a brake bedding procedure. I used one found under the e46 wiki by Zekenhaus racing I think. My opinion is that they stop better than OEM, are less expensive than genuine BMW pads, and produce less dust. So far so good!
If you want long life rotor friendly and no brake dust a ceramic pad is about the only way to go. I have installed Akebono Euro Ceramic pads with BMW rotors up front and no rotor change rear since they didn't really wear much. The Akebono's take 2-300 miles to bed in with normal driving and show no dust. Once bedded in the braking modulation is close to BMW but doesn't not have the initial bite.
These will probably last 80K miles since the OEMs lasted 65K. If you want help you should state what your requirements are: cost brake modulation brake dust life expectancy etc... |
I've been reading a lot of positives on the Cool Carbons for the street. My X3 rears are about shot---but I've got the maintenance plan so I'll be getting OEM. But if the rears tend to go first, I might be on my own for the fronts in which case I'll probably go OEM rotors and Cool Carbon pads. I've heard negatives on the Hawk stuff and ran Mintex on a past car never to run those again.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
