Old 10-09-2011, 02:20 PM
nfunk nfunk is offline
1998 BMW Z3 2.8L
Mein Auto: 1998 BMW Z3 2.8L
Z3 5 way harness
I am a new owner of a 1998 Z3 2.8L roaster and was wonder if anybody has replaced the seat belts with 5 way harness?
Old 10-09-2011, 03:13 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Only if you have roll bar....an race seats
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 10-09-2011, 04:15 PM
1998 BMW Z3 2.8L
True! It just seems that if worst case scenario occurs and the roadster flips, I am not sure if the OEM seat belts are good enough to hold the occupants inside the car.
Thanks for the reply.
Nick
Old 10-09-2011, 08:43 PM
Are you planning for track ?
Old 10-10-2011, 01:39 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Yes, the OEM seatbelts will hold you in the car.
5 point harnesses are not a good idea without a full race type (cross braced) roll bar, as they prevent you from twisting and ducking down in case or a roll over.
Scroth has a street legal 4 point harness setup, that has a weak point in one harness that allows you to twist and get down further. I don't know if you can mount them in a Z. I know my E46 M3 had the rear mounts installed from the factory.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
