Old 10-11-2011, 06:38 AM
guydutil guydutil is offline
Mr
Mein Auto: 2007 530 XI Touring Wagon
Exclamation Tire Pressure Monitor Intermittent Failure
2007 530XI Touring Wagon, my TPM suddenly comes on while driving without any loss of pressure or flat tires. It resets OK. It has happened twice in the last month. Any ideas on how to check/fix?
Old 10-11-2011, 06:45 AM
crewzer crewzer is offline
Mein Auto: 06 E61 530Xi 6-spd manual
Lightbulb
Do you keep your car in a garage overnight?
It might be something as simple as reduced outdoor temperature causing a drop in tire pressure. Considering your location (Ontario), marked drops in ambient temps in the Autumn might be the cause.
More info: http://www.tirerack.com/tires/tirete....jsp?techid=73
HTH,
Jim / crewzer
E61: 2006 530xi Sports Wagon | N52B30 & 6-Speed MT w/ CDV mod | A08 Silver Gray | Premium- & Cold Weather Packages | Member BMWCCA/NCC
E3: 1972 Bavaria 3.0A, retired long, long ago...
Old 10-11-2011, 06:56 AM
Mr
The car is garaged every night. The tire pressures are all good, within 0.5 pounds on each axle.
Old 10-11-2011, 07:31 AM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
Right but what happens is that as you drive outside where it is cooler, the tire pressure drops due to the drop in ambient pressue which kicks off your TPM warning. Nothing unusual for this time of year.
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 10-11-2011, 07:37 AM
Lightbulb
Almost! The tire pressure drops as a result of ambient air temperature being lower than garage air temperature. It's that dang Ideal Gas Law thing.
The solution is to normalize tire air pressure for outdoor conditions. The "old" way as to add ~1 lb of pressure for every ~10 degree F (~5 C) increase in garage temp vs. outdoor temp. This way, the tire pressure would drop to "normal" after the vehicle was moved out from the garage.
But, the TPMS may not be so easily fooled. I suggest you leave/move the car outdoors for several hours in the AM, set and check the tire pressures (different front & back?), and then reset the TPMS. This way, the cold tire pressure(s) and the TPMS will be set for ambient driving conditions instead of the warm and cozy garage.
Regards,
Jim / crewzer
Old 10-11-2011, 08:43 AM
Mr
Thank you All.
Old 10-11-2011, 09:25 AM
Crewdzer - I meant temperatuer - good catch and yes dang ideal gas law: PV = nRT - I was having flash backs to highschool chemistry and Chem 101 when I was typing up my response
BMW CCA Member
Old 10-11-2011, 10:08 AM
PimoX3 PimoX3 is offline
Mein Auto: 2008 550 m-sport, 2006 X3
Are you getting a low pressure warning, or "TPM Malfunction" message? If the latter, then you may have a sensor starting to fail in one of your wheels - I had this off and on for a few months with my winter wheels until the faulty sensor was replaced.
Old 10-11-2011, 01:03 PM
Mr
I am getting "tire loss of pressure" quickly followed by "flat tire" warning. I will have my sensors checked.
Old 10-11-2011, 01:27 PM
Lightbulb
I got the same message and warning this past Saturday. I had some wheel and tire work done that morning, and the techs didn't restore all tire pressures to the original references (30 F / 38 R). All is fine since I corrected the tire pressures and re-initialized the system.
HTH,
Jim / crewzer
Old 10-14-2011, 04:15 AM
Question
Update?
Thx,
Jim / crewzer
Old 10-14-2011, 04:28 AM
Mr
I have increased all my tire pressures by 2 pounds. It seemed to have solved it for now.
Old 10-14-2011, 06:06 AM
Cool
OK; thx.
Regards,
Jim / crewzer
