Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 10-11-2011, 11:52 AM
jerimagoo jerimagoo is offline
Mein Auto: Z4
Mechatronic sleeve gasket
Hi guys!
My '07 Z4 3.0si needs to have the mechatronics sleeve gasket change. I need help in changing it DIY way. I would really appreciate any links or advice, thanks
gerry
Old 07-26-2012, 08:30 AM
rsutoratosu rsutoratosu is offline
Mein Auto: Z4
I gotta check my notes, I was under warranty and did look it up, its very involve, I found a diy somewhere, but for another car. I believe at least the transmission pan needs to be dropped. So you do need to get some atf if its automatic. Ill check tonight when I get home
Old 08-30-2012, 11:28 PM
latitude39 latitude39 is offline
Mein Auto: E46-325xi; E60-530xi
I've done the job, this year, on my wife's 530xi. No more leak!
Mechatronic sleeve is a $25 part. It's a cylindrical unit with a pair of O-rings. The new, replacement sleeve is exactly the same but the O-rings are now black instead of red.
Accessibility on th Z4 will be different than on the all-wheel drive xi 5-series, which I can speak to. Because of the transfer case, the exhaust system must be removed--not too difficult but it adds time and labor. Once the 90-lb exhaust system is on the ground, drain the transmission, drop the transmission pan, unclip the Mechatronic sleeve, which is held fast by a clip WITHIN the confines of the tranny pan, unplug the wiring harness going through the sleeve, replace sleeve, being ABSOLUTELY certain to clip the sleeve retainer BEFORE putting the pan back on--ask me how I know. BMW instructions tell you to check that the clearance between the sleeve and transmission body is less than 3mm. Use a 3mm allen wrench to gauge this. The idea is to get the sleeve FULLY seated. If you can clip the internal clip in place you're probably there.
Now you'll have to refill the transmission, using the fluid you drained into a clean container-- unless it's time for new fluid in which case you will use new fluid that you have purchased. Follow Bentley's procedure for refilling.
You'll need a new pan gasket, exhaust gaskets(2), 5 copper nuts--for reconnecting the exhaust system, an extra quart of ZF Lifeguard fluid for topping-off.
It took me a full day, including draining and filling a second time to check that I had clipped the internal Mechatronic fastener. I checked my work a week later and looked fine.
