Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > New Member Introductions
Welcome to Bimmerfest! Whether you are a current BMW owner, shopping for a new or used BMW or just interested in cars, we hope you enjoy your visit. Take a moment to introduce yourself and post a picture of your BMW for the rest of the Bimmerfest BMW community to see.
Old 10-12-2011, 11:10 AM
mkdx5 mkdx5 is offline
Mein Auto: bmw x5 3.0d msport
error code 5f12
im new to the site just wanted to hi to everyone
had new brakes replaced on my x5 3.0d msport 2008 model 6 weeks ago and keep getting error code brake pads need replacing had it checked out at the garage replaced the brake sensor and still keeps saying error code 5f12c replace brake pads front axle please can someone help thanks
Old 11-06-2011, 08:36 AM
nik_uk nik_uk is offline
Mein Auto: 645ci
Hi - did you ever resolve this issue? - just replaced the PADS on mine, and now i keep getting 5F12 code - thanks in advance
Old 11-10-2011, 02:44 AM
problem still not resolved been to a couple of garages (owned by friends) tried resetting it but no joy
Old 11-10-2011, 02:59 AM
Mein Auto: 645ci
I sorted mine - I followed: - Note it took 3 times - then it worked
1. Turn ignition to 'ON;' DO Not Start Engine
2. Press and hold the Instrument Cluster Set/Reset button
for 10 seconds.
3. The upper display in the Instrument Cluster will be
illuminated with a Service Item (example: An oil can is the
designation for Oil Service). The lower display in the
Instrument Cluster will indicate the remaining time or
mileage left for that Service Item (example: 14000).
Pressing the button repeatedly will allow the display to
scroll through all of the Condition Based Service Items.
4. Press and hold the Instrument Cluster Set/Reset button
again
5. Pressing the Instrument Cluster Set/Reset button again
will allow the "RESET" to appear in the lower window for
that service.
THIS IS IMPORTANT
Releasing and reapplying the button one more
time will reset the service displayed in the upper window
only. Repeat the procedure for any additional service reset
needs.
Good luck chap
Old 11-11-2011, 05:08 AM
thankyou youre a star took a while but got there in the end.took 3 attemps to clear it but t was worth it no more annoying messages on he screen thanks again
