E34 (1989 - 1995)
Old 10-15-2011, 10:02 PM
DLS_91_525i's Avatar
DLS_91_525i DLS_91_525i is offline
I Wonder What This Does?!
Send a message via MSN to DLS_91_525i
Mein Auto: 91 BMW 525i 72 VW Variant
Bleed Screw Question
Okay so I was reading how the plastic screw can fatigue and the screw top can pop right off. Well it looks like mine has done that it is just a smooth black thread in there. Is there any way to bleed the system without the screw being removed?
I have already order a new brass bleed screw but I have to have the car monday and just need some kind of quick fix until it gets here so I can bleed it properly.
Thanks for any Help!
DARRiN http://www.facebook.com/E34DARRiN3391
(1991 BMW 525i 260,XXX miles)
(1972 Volkswagen "The DEATHWAGEN" Variant 64,XXX miles)
Old 10-15-2011, 10:08 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Thats the only way to bleed air .you could go to a parts store and try to match the threads on the bleed screw to a standard brass bolt of similar length.would work.
Old 10-15-2011, 10:15 PM
Is there anyway I could just put the radiator cap on slightly and let the air escape that way?
Old 10-15-2011, 10:23 PM
luckydog's Avatar
the radiatior and over flow side are different levels fluid comes in low into the over flow side when hot .I doubt that would would bleed it .
Old 10-15-2011, 10:31 PM
dang....
Well off to the parts store tomorrow it seems.
Old 10-16-2011, 07:22 AM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
*delete*
Good food, good people, good times.
Old 10-16-2011, 10:39 AM
Originally Posted by Radian View Post
*delete*
Would you mind to explain further?
delete what exactly?
Old 10-16-2011, 11:25 AM
EyeDoc1 EyeDoc1 is offline
Transplanted JrzyBoy
Send a message via AIM to EyeDoc1
Mein Auto: 91 525i & 94 325is
Bleed screw
I assume you got the broken pieces out of the radiator. I had this happen last month to me...dang thing just snapped. I was able to get a Dremel tool and drill two small fine holes into the soft plastic of the remnants of the screw and carefully use very fine needlenose pliers and "screw it out" without screwing up the threads. Hope this helps.
Christen
Old 10-16-2011, 11:31 AM
Radian's Avatar
It's a message for the moderators. It means I posted something...then came back and want to delete it. It has nothing to do with the thread.
Old 10-16-2011, 11:52 AM
oh okay!
