E34 (1989 - 1995)
Old 10-16-2011, 08:33 PM
Cindysandoval3's Avatar
Cindysandoval3 Cindysandoval3 is offline
Mein Auto: 1992 bmw 525i
What is this
E34 area of fhe car for? Its making noise when i,turn on,the car
Cindy
Old 10-17-2011, 10:27 AM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
That is your fuse box. What kind of noise is it making? Is it a knocking noise by any chance?
Sent from my Droid Incredible
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 10-17-2011, 01:57 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I'm guessing You are hearing large air bubbles in the heater hose hitting 4 circler looking heater valve in front of that black fuse box making a bubbling ,gurgling, popping sound when running the engine. I think its related to earilyer lose hose at block.
Old 10-17-2011, 05:45 PM
Idk how to describe the noise. Its like screeching noise. Umm idk lol
Cindy
Old 10-17-2011, 07:52 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Cindy
if all else fails, thats what youtube is for. we cant help you when "ydk"
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 10-17-2011, 10:12 PM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
Cindy
This is common when your relays/computers cause interference.
Open that plastic box get electrical parts cleaner and remove + clean and securely put back your relays and two larger catriges located above the fuses.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 10-18-2011, 09:54 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
You could be hearing the auxillary water pump which sits below the heater valve. Disconnect the two wire connector just "north" of the jumping terminal in your photo.
Take my advice, I'm not using it.
Old 10-18-2011, 12:43 PM
Thanks, I'm getting my car fixed
Cindy
Old 10-18-2011, 10:06 PM
TommyD525i TommyD525i is offline
Mein Auto: 1992 525Ii
That is the fuse box. It holds the fuses and some of the relays(electrical switches). You could be hearing a relay freaking out and going bad. Or there could be a short in the wiring going to one of the relays.
Just my $0.02
Good luck and hope you get'r figured out.
Old 10-21-2011, 12:34 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
I had a screeching noise from my auxiliary water pump for a while but it went away on its own. It's in the same area as your pic. I imagine I will end up having to replace it eventually but it hasn't made that noise for about a year now.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
