E46 (1999 - 2006)
Old 10-17-2011, 11:31 PM
Rezzakaria Rezzakaria is offline
Mein Auto: bmw 323i
ac/heating not working
My bmw 323i 2000 ac/heating stopped working it slowly shut down when i first bought the car it was working perfect about 9 months later the ac started acting up it would shut down by itself then i had to turn it back on and then it would shut down and i wouldnt be able to turn it back on it would turn back on by its self sometimes i would turn the car off then turn it back on and it would start working soon it just stopped working at all it once came back weeks later and then finally broke for month ive gotten it flushed or recharged i believe and that didnt work can anyone tell me how to fix this?
Old 10-18-2011, 12:02 AM
djstrachan's Avatar
djstrachan djstrachan is offline
Mein Auto: 2004 325i ZSP
Fuses are good?
May want to search this forum for "final stage resistor". Those are a known failure item on these cars and may cause the symptoms you are experiencing.
"It is little use listening to other people as they will either be agreeing with you or saying stupid stuff" - Dogbert
I'm not a pessimist. At some point the world sh!ts on everybody. Pretending it ain't sh!t makes you an idiot, not an optimist.
2004 325i - Sport package - 5MT- clears - CDV mod - M3 gauge faces w/silver gauge rings & red needles - SS exhaust tips - strut tower brace - Hotchkis anti-sway bars -50% tint - shadow grills - roof spoiler - silver CF trim
Old 10-18-2011, 12:24 AM
Mein Auto: bmw 323i
i havent checked my fuese i dont know how (dont know much about cars) what exactly is the "final stage resistor"? i was told by a eruo specialist that the programmer or something has died out and needs to be replaced and re programmed by bmw, i hope thats not the problem the bmw dealer will charge me something i cant afford
Old 10-18-2011, 12:49 AM
djstrachan's Avatar
If you search this forum for "final stage resistor" you will read about the symptoms and how to fix it (if that is what your problem is).
Not sure what your technician means by "the programmer". I'm assuming he means something related to the car's computer system...if so, I can't help you. You are correct in assuming the dealer will likely charge you more than you can afford. Hopefully someone on this forum can point you in the right direction.
EDIT - your fuse box is at the back of the glove compartment. There is a fuse for the A/C system. I doubt that's what your problem is but it's worth checking out...fuses 28,62 and 63 are for the A/C (I think).
Old 10-18-2011, 12:58 AM
Mein Auto: bmw 323i
yes it was the computer system ill research more about the final stage resistor and look at the fuse box thanks!
ac, air condition, fan, heating
