E90/E91/E92/E93 (2006 - 2013)
Old 10-18-2011, 09:04 PM
3Coupe4me 3Coupe4me is offline
Mein Auto: 328i Coupe
Replaced my DSC Hydro Pump
Sometime ago I got the dreaded ABS, Brake and DSC trifecta error while coming home from work but it went off after I restarted the car.
This intermittent fault continued on and off for some time afterwards until about a month ago it finally stayed permanently on. I decided to take the car to an indy mechanic and have the codes read. The fault cade came back as a "5DF0" code which is a faulty DSC Hydrolic Pump. The estimated cost of repair was $530 for the pump + 4 hours labor to fix it.
Having worked on all the cars I've ever owned I decided to tackle the pump replacement myself. I ordered the part from Tischer for about $100 less than the dealer and with a free weekend coming up I decided to do the job myself. The part that I was most worried about was bleeding the ABS pump which requires special software at the dealer to cycle the pump as part of the bleeding process. However I did some research and saw where you can cycle the pump using the old school method of stomping on the bakes on a slippery surface while driving at a slow speed. Well, I had such a surface on my nearly 100ft long gravel driveway which would affect nobody but myself if I somehow screwed up on bleeding the brakes correctly.
When the part arrived I was actually pleasantly surprised that it had installation instructions included from the manufacturer. Even though it should have been just a simple swap of the parts the instructions showed how to relieve the pressure from the brake lines and how to prevent the lines from loosing but a little fluid. Another surprise was that during the installation of the new pump I discovered that it was already bench bled from the factory and already had fluid in it.
In total it took only about 10 minutes to do the swap. The hardest part was bleeding the four wheels until the brakes were firm then activating the ABS using the method described above and then bleeding all four wheels again until the entire brake system was flushed with new fluid.
Here are some pics and a description of the steps
ABS PUMP LOCATED HERE
CLOSE-UP VIEW OF PUMP WITH THE INTAKE AN OUT BRAKE LINES REMOVED
PUMP REMOVED AND LINE CAPPED TO PREVENT FLUID LOSS
THE CAPS I USED
PUMP ASSEMBLY WITH CONTROL UNIT ATTACHED
OLD AND NEW UNIT SIDE BY SIDE
PREPARATION FOR PUMP SWAP.
I swapped just the pump and kept the control unit because it is already programmed for the car. If I had put in the new one i would have had to take it to the dealer for programming.
After all that work it was good to see this
I also tested the DSC, Start off Assist and Cruise Control and everything is now fully functional.
ZPP,ZSP
Old 10-19-2011, 06:27 AM
90rr 90rr is offline
Mein Auto: 2007 328i
good job !
Old 10-19-2011, 09:54 AM
Pat_X5's Avatar
Pat_X5 Pat_X5 is offline
Mein Auto: 335d
Wow! Amazing because I thought something like a hydraulic unit would need an experienced indy or dealer.
Old 10-19-2011, 11:18 AM
invariant's Avatar
invariant invariant is offline
Mein Auto: 2008 335i
Neat! Bookmarked/subscribed
2008 E90 335i 6MT + SSK + CDV-delete / ZSP / aluminum / black leather / Conti DW + compact spare / integrated portable nav plus
2005 E83 X3 Auto
Old 10-19-2011, 12:01 PM
B-737 B-737 is offline
came and went...
Mein Auto: 993 6MT
did you use, or could have used a Motive Pressure Bleeder?
2011 328 xi coupe
Old 10-19-2011, 12:05 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
pressure bleeder wont purge bubbles in the dsc unit.
if you have a bmw specific scan tool, you can get the dsc pump to cycle during a bleed to purge the dsc unit as well (or do the abs actuation method to force fluid to cycle through)
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 10-19-2011, 12:19 PM
Clifton Clifton is offline
Mein Auto: Cars...
Nice work! Thanks for the post!!!
Regards,
Clifton
BMWFTW91 BMWFTW91 is offline
GONE
Mein Auto: .................
Amazing! Nice job man!!
Old 10-19-2011, 12:31 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
You need a pressure bleeder in conjunction with DIS to purge the unit. Simple to do.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 10-19-2011, 02:43 PM
I did the two person method to bleed the brakes. Orient330iNYC is right, the ABS pump has to be cycled and the brakes bled again to remove all the air in the brake lines. What I will invest in is a Bavarian Tech Tool for stuff like this.
ZPP,ZSP
Old 10-19-2011, 02:47 PM
rtgirard's Avatar
rtgirard rtgirard is offline
1-5-3-6-2-4
Send a message via Skype™ to rtgirard
Mein Auto: 2013 335xi
Great work!
F30 335xi - Ordered on 9/5/2012... Delivered 10/29/2012
Alpine|Coral|ZSL|ZPP|Nav|ZDH|SportAuto
BMWCCA# 457109
