Old 10-28-2011, 08:24 PM
Trisikad Trisikad is offline
Mein Auto: 2012 X5
2012 x5 Base tire compatibility
Anybody switched their tire size from 255/55 r18 to 275/55 r18? Any difference in handling?
Old 10-29-2011, 09:16 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Tris, go over to the tirerack thread here on the 'fest. Gary the moderator is very helpful and might be able to give you some answers like -- will they fit properly.
Old 10-30-2011, 12:08 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
You would probably need to go to a 275/50 r18 in order to maintain the original diameter, otherwise your speedo and odo would get thrown off. As the poster above said, you can give Tire Rack a call for advice.
Old 10-30-2011, 12:04 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i M Sport; Twin X1's
Most folks who come here realize that a 275/55 is a totally different size / diameter than a 255/55. First, the 0.9" difference in diameter is going to screw up your speedometer, odometer and gearing. Second, the increase in diameter and increase in width may very well cause clearance problems with your fenders, particulary on your front wheels, when turning. Third, the 275's are designed to be mounted on a wider rim, meaning you are changing the overall tire geometry, likely leading to sloppier handling.
As others have said, seek professional help before you try this on your own.
Current BMW's:
2014 535i MSport Space / Black, ZCW, ZDA, ZLP, ZLS, ZPP, H-K and 704
2015 X1 28i xDrive Alpine / Black, xLine, ZCW and Ultimate
2015 X1 35i xDrive Black / Black, ZCW, Ultimate and Xenons
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 10-30-2011, 08:49 PM
miniapple3 miniapple3 is offline
Mein Auto: 2012 BMW 535i xDrive
I had Michelin Latitude Tour 275/55R18 on my 2011 x5d for about 2 blocks, the tires rubbed on the suspension just above the tire on the inside. It was not touching until I turned, never drove over 15mph to see how bad it would get. Went back to Michelin Latitude Tour HP 255/55/R18 none run flats this time. Good Luck
