Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 10-04-2011, 11:31 AM
casscounty casscounty is offline
Mein Auto: 1982 633CSi
window trouble
Front drivers side window quit working on my 82 633. Any suggestions on possible causes?
Old 10-04-2011, 01:23 PM
catso's Avatar
catso catso is offline
catso
Switches are notorious for corroding. Try switching one from a window that works. Other than that: wiring and connectors, electrical motor or connector, or possibly a window regulator. Use a test light or a voltmeter on the plug that goes to the switch, it should just pop out if you pry up on it.
Don't be gormless; get some gorm!
![/I][/FONT]
Old 10-04-2011, 08:40 PM
Does the rocker switch just pop up out of the panel?
Old 10-04-2011, 08:51 PM
catso's Avatar
catso
Yes, it should. You can use a very small screwdriver or something similar to pry it out.
![/I][/FONT]
Old 10-04-2011, 08:58 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A--165K
Yeah. It's broke. Seems to happen a lot with BMW windows.
Old 10-11-2011, 08:14 AM
Well I finally got around to popping out the rocker switch, and found that the backing plate had come off and all the wires fell out of the block. I tried the switch in another window plug, and it works fine. Now I need to know if any body has a wiring diagram that shows the position of the five wires in the plug.
Old 10-11-2011, 12:18 PM
catso's Avatar
catso
I would think the wiring color code on the other switch is the same.
![/I][/FONT]
Old 10-19-2011, 09:59 AM
Hey Catso, I tried wiring the switch the same as another one, but it didn't help. Do you know where I can find out for sure the correct position of the wires?
Old 10-19-2011, 05:06 PM
catso's Avatar
catso
Here's what I could find in the Bentley's repair manual for an E28 (which should be similar) The Haynes repair manual also has a copy of a similar diagram...... LEFT FRONT: TERMINAL #5-BROWN, 3-RED, 8-BLUE, 1-BLACK, 4-BROWN....... RIGHT FRONT: 4-BROWN, 1-BLACK, 8-BLUE, 3-RED, 5-BROWN........ My guess is the red wire supplies power to the switch. First put a test light on the red to make sure there's power.
![/I][/FONT]
HTML code is Off
