E34 (1989 - 1995)
Old 10-20-2011, 06:38 PM
feistdabeast feistdabeast is offline
Mein Auto: '92 318i w/ 218k
My brother took it apart, and I don't know where things go (head job)
Ok,I'll start at the beginning, I bought my 1989 525i from my brother mostly apart all that was left was a nut holding on the exhaust manifold and the belts in front with pulleys and covers. I have since put in the new head gasket, # 6 cylinder was leaking at the rear between block and gasket; put new timing belt on and the covers and pulley with dampener and the distributor. now I have to put on the intake manifold, and the entire intake track, which he took off and the wires and coolant tubes that went with is, including two brackets, one full of wires another with a multi-connection plug attached to the full rail which need to be mounted somewhere but I have no clue, unfortunately, neither does my brother as it has been like a year since he took it apart. I have searched bimmerfest forums, google pictures, the bently manual as to any clues as to what these are or where they go, was hoping to maybe find like a "blueprint" if you will of where things went, but I know that is a high hope. I have some pictures from some of what I have done and of the parts I have yet to put in, hopefully these will help anyone else that needs help.
Old 10-20-2011, 08:23 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
You need someone there to help that is familiar with that engine. looks like it wont be to bad to put back together.make sure all the hoses are correct before installing the manifold. Try RealOE last 7 digits of the vin will enable you to pull up the catalog and schematics on that engine hopefully.http://www.realoem.com/bmw/select.do
Old 10-21-2011, 10:46 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Search for images of BMW M20 engine and you'll probably get the visual. None currently in my fleet so I cannot oblige myself.
The wire harness attaches right over the fuel rail if I remember correctly.
Finishing another's job is always an adventure.
Take my advice, I'm not using it.
Old 10-21-2011, 06:37 PM
thank you for the link lucky dog, it helps with the coolant. still digging through it trying to find out where the Fuel injector plug bracket and the front wiring harness mount to, might just try putting it together as is and drop it off at a German auto shop near Norristown and let them figure it out, it should last a few hundred miles like that, right?
Old 08-17-2014, 07:55 PM
Still using that link, though I had some issues getting that '89 525i through PA state and emissions inspection and donated it to purple heart (sold at auction for over 500).
It was running loudly, but was running. success for a first time head gasket.
currently have a '92 318i and having emissions issue ( http://www.bimmerfest.com/forums/sho...=1#post8532749 ). just been reading other posts and read how people got upset without an update.
I also learned with this car, as opposed to what all previous owners that I talked to of both cars said, that you MUST run premium 90+ octane gasoline (unleaded). and part of the problem with emissions with that 525i was I was running '87 (gotta save the $).
but thank you. here using the link on my brilliant rot '92 318i Snowbal.
Old 08-18-2014, 07:48 PM
BMWFatherFigure's Avatar
Old School
Out here I run 98oct in all of mine. Any less and they rattle like a baby's toy.
Current:
E38 Parts Car
Previous:
Old 08-19-2014, 08:47 AM
only times I see anything higher than 93 octane is at an airport.
Old 08-19-2014, 01:00 PM
DrCharles DrCharles is offline
Mein Auto: '81 745i, '97 540i Dinan
In Europe and Australia, and likely other places, gas is rated by RON, Research Octane Number. American gas is rated (RON+MON)/2 and the Motor Octane Number is typically 10 points lower than the RON.~
So Euro 98 octane = US 93 octane. Euro 95 ~= US 89.
Old 08-22-2014, 01:25 PM
Got to talking with my dad about this stuff and made me think more about my current problem of emissions inspection here in South Eastern Pennsylvania. Luckily I have the Owners manual and in there on page 20 it says that it needs Premium unleaded gasoline only (90 AKI (Anti Knock Index) or 95 RON (Research Octane Number). Now taking that to mean 90 MON and 95 RON that means that in the USA we need to have 92.5 Octane, which means that my current use of 91 is in adequate and that you should be able to use something under 98 out there in Australia. But it also makes me wonder, since my emissions test was done using 93 US Octane, that my knock sensors could be the culprit as I have the 1286 code ('92 318i M42). However I see alot of oil before my throttle plate and think that the added oil could be causing the horrendous emissions, but I do not have a CCV. Any help on this earlier M42?
coolant system, electrical wiring, head job, intake
