BMW Scanner Fault Code List Needed - Bimmerfest - BMW Forums
Old 10-20-2011, 08:26 PM
bzeboymenz bzeboymenz is offline
Mein Auto: 2005 BMW 645 Ci
Hey Guys,
I have one of the 3 in 1 BMW Scanners + DASH that I recently bought.
My 2005 645Ci recently had the check engine light come on.
Can any of you kindly post the Fault code list that explain the codes listed below?
# Fault codes
ECU Fault type Code/Parameter (hex)
CAS -> IM messages 9304/68, 9906/28
LM -> IM message 930D/64
DME -> DTC 2EF4/E2
EGS_SMG -> IM message 4F86/38
SGMZ -> IM messages 9394/24, 9395/24, 9397/24, 9398/64
SGMS -> IM message 93F3/20
IHKA -> DTC 9C54/24
Old 10-20-2011, 08:54 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Could not find them all, but here is what my older document has matches for:
# Fault codes
CAS -> IM messages 9304/68, 9906/28 - 0x22419906 9906 Coding,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),at variance
DME -> DTC 2EF4/E2 - 0x016A2EF4 2EF4 Map thermostat, mechanism
EGS_SMG -> IM message 4F86/38 - no 4F86 but before and after it = 0x02614F85 4F85 Ratio monitoring, clutch E and 0x02614F87 4F87 Ratio monitoring, gearshift 1 - 2
SGMS -> IM message 93F3/20 - 0x244193F3 93F3 Key switch,passenger airbag:coding data fault
IHKA -> DTC 9C54/24 - 0x05619C54 9C54 AUC sensor
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 10-20-2011, 09:01 PM
Thanks, Yorgi!!
Old 01-23-2013, 07:51 AM
Blaknificent Blaknificent is offline
Mein Auto: '05 Black Sapphire 645ci
Hey Yorgi,
Happy New Year to you.
I recently had valve gaskets and upper/lower timing gaskets changed....somehow during the 3 day DIY, my batt went dead which required a jumpstart.
Lo and behold, a code appeared out of nowhere...."passenger airbag restraint, tension, fault".....
Never had ANY problems before and this is my first time seeing this code.
Ever heard of this?
Can it be reset/cleared?
I know this forum keeps you busy, but I would appreciate your knowledge and wisdom on this one.
Thank you in advance.
Old 01-23-2013, 04:53 PM
HerbP HerbP is offline
This code comes up often with a weak battery. You should be able to clear it with a good battery, with a full charge. Mine only cleared with a new battery, with a full 12 hour charge. The new battery off the shelf would not clear the code. I was glad to see it clear after putting a fresh charge on it.
Good Luck!
