Old 10-24-2011, 05:53 AM
thewowfactor thewowfactor is offline
Mein Auto: 335 x drive coupe M pkg
Wheel Width Question - Performance
Hello people!
Cars and performance are not my area of expertise but I was wondering if someone with more knowledge on the subject could help me out.
I have a 2011 335i X Drive Coupe with the M Package.
The Tires are 18". The Wheel Width is 8.0 in the front and 8.5 in the rear.
My question is do you lose performance if you purchase rims that are non staggered, or a different size? For instance front and rear that are all 8.5's or all 8.0's.
I've also seen 8.5 fronts and 9.5 rears.
I really like the M6 replica wheels and it seems very difficult to find these rims in 18"and when I do find them they are either non staggered or a different size mentioned above.
These rims would be on my summer set of tires so I would not like to lose performance.
Thank you so much for your help!
Anthony
Old 10-24-2011, 10:22 AM
LMC's Avatar
LMC LMC is offline
Mein Auto: M3 & X3
Welcome to bimmerfest, Anthony!
It's not really a case of "losing" performance as much as a case of slightly changing the handling characteristics of the car. Wider tires in the rear give the car a bit more understeer, which suits the non-enthusiast or less-skilled driver. They also give the car a performance look that many like.
Some will disagree with me, but I think that a square (non-staggered) setup is just fine from a performance point of view.
Larry
BMW CCA #115780
'14 X3 35i M sport
'17 M3
Old 10-24-2011, 10:33 AM
0428's Avatar
0428 0428 is offline
Mein Auto: X5 35i Sport Sapphire
I hate to disagree, but I have to disagree. Take a look at ANY performance vehicle and you will see they all have staggered set up and all their tires are FAT.
Retired
1999 Prelude SH / Pearl White /
2007 X3 Sport / Jet Black /
2010 X5 Sport / Sapphire Black /
Current
2013 X5 M-Sport / M-Power / Alpine White /
DSXMachina's Avatar
Bimmerdex 7.4!
No argument with you there. OP, for normal road use there will be extremely little perceptable difference. You would notice LESS traction on ice, slush and snow with the WIDER tires. Now if you want to talk track usage the thread will light up with a hundred opinions, all good but all different.
For those of us running staggered setups or wider tires (or both) it is more about what we like the looks of than anything else. Until we are cornering and braking at the limits we have wasted our money.
DSX, certified second tier expert.
Old 10-24-2011, 10:54 AM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
Ah, but the WHY is important. Performance cars are intended for dry handing and grip on the street. And in that limited realm, fatter tires are better, within reason.
(Of course stuff like weight, turn-in, and moment-of-intertia are downsides of bigger tires, so people who track cars are going to have a more complex answer, as the Goat already mentioned.)
Roughly, staggered wider tires get you:
* slightly safer handling in dry weather (less oversteer = less chance to spin)
* better 0-60 times (on RWD cars) due to more grip
* looks nicer
Square (narrower) tires get you:
* better ice/snow grip (but tire type is more important than size)
* easier tire rotation (if you want to rotate tires, that's a whole different issue)
* cheaper
* can swap wheels from front to back
None of these are deal-breaking for daily driving, to be honest. For non-performance daily driving, it is reasonable to say that a square setup won't hurt performance in any serious way.
To get back to your original question: if you like the M6 replica wheels that much, get them. I doubt you'll even notice a difference with a square setup.
Old 10-24-2011, 12:22 PM
DSXMachina's Avatar
Bimmerdex 7.4!
* looks nicer
* cheaper
If you keep giving out that kind of informed opinion I will be stuck a ''second tier expert'' for a long time. Good job.
Old 10-24-2011, 12:35 PM
BatteryPowered's Avatar
BatteryPowered BatteryPowered is offline
Mein Auto: '16 X3 2.8 xdrive
It seems that a lot of people here completely forgot why staggered tires are there to begin with. If you have RWD car you need those for better traction. It's hard to put 335i power down on 225 wide tires in rear.
Staggered set up does dumb down the car in turns though, so it gets a little more predictable and less fun.
Old 10-24-2011, 01:01 PM
Pat_X5's Avatar
Pat_X5 Pat_X5 is offline
Mein Auto: '14 F10 +'16 LR Discovery
I can't believe this! Yes everyone is correct!
I have a summer set staggered 18" sport Style 195 with Summer Bridgestone RFT then now for winter / rainy / light snow I have a non staggered (square) 18" Style 197 with A/S Conti DWS non RFT and love them.
Yes the traction issue and understeer is a definite factor but it all depends on where you want to drive.
Icy northeast or northwest will want square snow dedicated tires like the Blizzak or Xi2 Ice.
Dry southwest like me will want the square A/S wet, light snow and dry mixed tires.
Old 10-24-2011, 01:10 PM
Rock36's Avatar
Rock36 Rock36 is offline
Mein Auto: 2011 328xi sportswagon
Hello people!
Anthony
Since most everybody hit the high points already regarding staggered tires vs. Square, the only thing I would bring up are the actual wheel weights.
If those M6 replicas are significantly heavier than your stock setup you will lose performance that way due more to the added unsprung mass; regardless if you are staggered or not. I only say that because I've noticed replica wheels can be pretty heavy in general compared to OEMs.
So additionally, I would also be concerned with what those m6 rims weigh compared to the ones you currently have.
2011 328xi Touring: Alpine White, Oyster/Black dakota leather, 6MT, ZMP, ZPP, ZVP, ZCP, Harman Kardon sound, iDrive, roof rails.
2007 Corvette Z06: Le Mans Blue (yep GM used it too), titanium leather, 2LZ package, Bose sound system
Old 10-24-2011, 01:11 PM
hyperzulu's Avatar
hyperzulu hyperzulu is offline
Ich bin schneller
Mein Auto: 2015 M235i
I think Squidget's post summed it up.
This thread is pretty informative. I was contemplating the same question when researching the pros/cons of going to a rear tire with a 275 contact vs 255 or 265.
Old 10-24-2011, 01:19 PM
DSXMachina's Avatar
Bimmerdex 7.4!
You 'understeer' guys have lost me. Wider rear tires result in understeer? So what? Are you suggesting that drifting or losing the back end entirely are better options?
Wider rear tires result in understeer only because they are hanging on when narrower tires would let go. That's a very good thing as anyone who has experienced snap oversteer can tell you.
Before anyone jumps down my throat about how we should all be learning to drift so we can handle anything that happens, let me tell you this; nobody drifts at the track. If they are drifting they have lost traction, are excessively wearing their tires, and are losing speed. Fail.
Old 10-24-2011, 01:27 PM
Rock36's Avatar
Or you can have my car that can still snap oversteer if the active Handling is turned off, and I have 325s in the back ha ha.... But yeah not fun.
Old 10-24-2011, 01:34 PM
Thanks for the welcome and all the info guys. It gives me a better idea on the subject or I might be slightly more confused LOL!
Thanks Again
Anthony
Old 10-24-2011, 01:41 PM
dtc100 dtc100 is offline
Mein Auto: 2011 328i
On my first autox try, I experienced such snap oversteer during the first run, I can tell you it was fun
If I change the stock 225s to 235 square setup, how much improvement would I get in future autox? Or the difference would be minimal/non exist?
Old 10-24-2011, 02:09 PM
bimmerfrk bimmerfrk is offline
Mein Auto: 2010 328xi Montego Blue
If it gets dumber then you my friend are not going fast enough around turns!
Old 10-24-2011, 03:14 PM
Thanks! LOL, it's not like I'm saying anything that driving enthusiasts don't already know. I'm just good at summing up.
In general, I'm with the "oversteer is bad" crowd. A spin can be lethal, and takes incredible skill to escape. So much so, that I was taught to not even try. Get off the inputs, let the car leave the area in a straight line. Trying to correct can alter your course so that other people plow into you.
But let's keep perspective: even with square tires, a 3 series shouldn't oversteer much, if all. The amount of understeer car builders tune in is considerable. I'm betting that square tires still understeer under neutral throttle. I could be wrong, as I've never run a square setup on my 335, but that's my bet. Plus you've got your computer nannies in daily driving, and they are quick to prevent oversteer. So it's really not much of a worry.
(It's not like you are driving a 911. Spin city! wheeee!)
Lastly, I'll agree with DSX. Oversteering on the track is usually a fail. It is typically caused by "mixing inputs" in the corner. Either overbraking / throttle-lift on the corner entry, or excessive throttle on the exit.
Old 10-24-2011, 03:22 PM
hyperzulu's Avatar
Ich bin schneller
This goes against EVERYTHING that I learned from Jeremy Clarkson about driving fast cars fast.
Old 10-24-2011, 03:31 PM
I stand corrected. I shall go do laps in a Reliant Robin as punishment.
Old 10-24-2011, 03:34 PM
hyperzulu's Avatar
Ich bin schneller
Just make sure you put training wheels on it for stability.
Old 10-24-2011, 04:12 PM
DSXMachina's Avatar
Bimmerdex 7.4!
In my first post in this thread (#4) I said that for normal road use there would be little discernable difference among the various setups. I stand by that statement. I'll even toss in most evasive moves at highway speeds and taking exit/entry ramps at a brisk pace. Not until a car is on a track will the driver really feel a difference in adhesion and maneuverability.
Remember that the watchword of any TV show is do it right or do it wrong but never ever be boring. Drifting and snatch correcting oversteer is never boring.
Old 10-24-2011, 04:23 PM
So people are in agreement tire width does not make much difference in performance in street driving. Rim protection and aesthetics are the concern.
But what if one does occasionally auotx (not on the tracks) the car? Square or staggered? Wide or very wide?
Old 10-24-2011, 04:26 PM
DSXMachina's Avatar
Bimmerdex 7.4!
(snip)
But let's keep perspective: even with square tires, a 3 series shouldn't oversteer much, if all. The amount of understeer car builders tune in is considerable. I'm betting that square tires still understeer under neutral throttle. (snip)
I've tracked with a staggered setup and with a square setup, and have run four different brands of tires. With the nannies 'On' it is easily possible to understeer at high speeds in tight corners, however it usually results from driver error (too high a speed) and occurs at much higher speeds than for 'lesser' cars. (Example: My Saab 9-5 Aero does more plowing in corners than the average Kansas farmer.)
With DSC on it is virtually impossible to spin my 335 in a parking lot even at high speeds. The computer is smarter and faster than the driver. With DSC off, no problem spinning. Note that I'm talking about a sharp turning maneuver, not intentionally spinning like 'doing donuts'
Old 10-24-2011, 04:36 PM
CT's Avatar
CT CT is offline
GODSPD
Mein Auto: SSII E90 ///M, AW E92 N54
"Wider rear tires cause understeer" is a misnomer. What they should be saying is that "increasing rear tire width with respect to front tire width will cause more understeer than a 'square' setup with the same sizing." Increasing tire width increases traction and is a good thing.
e90m / ssii / foxred / nochrome
wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer
full challenge exhaust
WHEELS FOR SALE
Old 10-24-2011, 04:48 PM
DSXMachina's Avatar
Bimmerdex 7.4!
LOL, now we are getting into the area in which I earlier said there could be a hundred different opinions and they'd all be right. Since I don't want to end the thread with this post I'll refrain from giving my opinion.
Old 10-24-2011, 04:56 PM
Since you have the experience tracking a 335 with square setup, then you can answer my bet! With square setup, what's the bias? Not sharp turning, but when the body is relatively settled. Say, a high-speed sweeper turn?
Over, under, or neutral steer?
performance, rims, staggered, staggered-diameter wheels, wheel width
