Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 04-12-2004, 11:30 AM
Hal H Hal H is offline
Mein auto: 2000 528
Angry 528 overheats? Help
Just recently took my 2000 528 on a trip to Fresno via the grapevine. I usually do this trip in excess of the posted speed limit and have had no problems with a four-passenger load, and the a/c on. The Temp gauge has never gone beyond 3/4 of the way to red. I will preface with 4000 miles ago I had a reserve tank rupture in my garage and it was replaced under warranty, but this was the first long distance trip since then.
Half way up the grapevine the temp gauge gradually moved to within a hair of the red. I killed the ac with little effect. Slowed to 70 with some luck but, except for downhill legs, or with the heater on, the temp gauge stayed above 3/4 to the edge of the red (anything over 70mph 2500rpm pushed it to the red). This high temp reading happened all the way to Fresno, even on the flats!
Had the local BMW dealer check it out, they found air in the cooling system, and pressure checked and certified ok. Ran the car around Fresno and so no major problems, but on the return trip had the same temp problem occur.
Don’t want to waste another $122 to fix nothing. Anyone have any ideas??? It happens at high speed so it shouldn't be fan clutch. The pump has a metal impellor. You would figure that the coolant should be fresh and that the level should be good. Thermostat???
Thanks for any sage advice you can offer
Old 04-19-2004, 10:32 AM
DanT DanT is offline
Cars Suck
Mein auto: I drive your cars
How many miles on the car?
if it has high mileage perhaps the radiator is becoming restricted.
Old 04-28-2004, 04:12 AM
Toxic Toxic is offline
Mein auto: 97 523i
Could be a mixed bag of either thermostat/pump, leak. I had a small leak in my coolant system in one of the pipes a few weeks ago giving me air locking in the system.
Old 05-03-2004, 09:44 AM
Mein auto: 2000 528
I got my dealer to give me a "goodwill service" due to my 51000 miles and they replaced the thermostat. We'll see it that is the cause.
Old 05-26-2004, 09:32 PM
528iheat 528iheat is offline
Mein auto: 99 528i blk/blk
keep us posted please.
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
