E36 (1991 - 1999)
Old 10-26-2011, 01:30 AM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
$50 camshaft upgrade solution for M50/M52 engines
Cheap camshaft upgrade solution for M50/M52 engines.
If you are on the budget and want to upgrade camshaft on your M50 engine, then there is a $50 solution to this.
Get intake camshaft from M54b30 engine. These are sold for cheap at E46 forums. People upgrade to ZHP cams all the time so their stock cams are on sale for $25 to $50.
Get the intake camshaft from 1992 M50 non vanos head and you will use it on the exhaust side. The timing tool block will not work, so before you remove your stock cam mark the points of the lobe peak location on the cam caps. You can find this at junk yards for $15 to $25.
Cam specs will be
Intake 240 duration 9.7 lift
Exhaust 240 duration 9.7 lift
Not as hot as S50/S52 cams but close enough(in my opinion S50/s52 cams are just too agressive for 2.5 and 2.8 L engines, they deliver more peak power but reduce power on low rpm)
For the intake cam you will need to get 96+ cam tray with lifters and caps, you can mod the M50 cam tray if you are realy cheap, M54 trays will work too. If you have the option of getting M54 intake camshaft sprocket with hardware, get it, it is lighter and better than M50/M52 intake sprocket hardware. Do not remove vanos gear from the cam, just shorten it down with the grinder 5mm. And cam tool will work with M54 intake cam.
This photo shows, M54b30 intake camshaft with hardware installed on the M50 head. M54 uses just one spring washer, it is made to reduce the vanos rattle and to tighten the vanos on/off thrust, similar to M52/S52 hardware but more simple and lighter.
Old 10-26-2011, 04:22 AM
LaCrosse540i6's Avatar
LaCrosse540i6 LaCrosse540i6 is online now
nope
Mein Auto: '03 540i M-sport
So ZHP cams would also be compatable for M50/M52's? Interesting.
Old 10-26-2011, 07:35 PM
CDirks's Avatar
CDirks CDirks is offline
Is a real boy
Mein Auto: White 1997 328i
I'm surprised more people didn't comment on this. Definitely interesting.
I'll keep it in mind. Thanks for posting.
Old 10-26-2011, 08:01 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
Mein Auto: 1995 318is
Very nice. I'm glad somebody is willing to dig in and discover this kind of stuff.
-CJ
Old 10-26-2011, 08:53 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Hmm... I think I know what I'm doing for part of my turbo build...
RIP Ben "Jever" Doebele, we wont forget you
Hi, I'm Chad. Talk to me or GFY
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things!
1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
Old 10-26-2011, 09:52 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: 1992 325is
Wow this looks awesome.
Thank you. This might work without vanos....
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 10-27-2011, 02:11 AM
rooster1986's Avatar
rooster1986 rooster1986 is offline
Mein Auto: 92 325i
Yes would this work for non vanos m50? Otherwise looks like ill be spending for a used s50 cam.
Primered Black 92' 325i. Ireland Engineering Header, Ireland Engineering Catback, TMS Underdrive pulleys, TMS chip, Bav auto fpr, Power Flow cai, Bav auto coil packs, Cool Carbon pads, Eiback springs, Bilstien Sport HD shocks/struts, 3.23 LSD, Understeer short shifter, 16'' Spal Fan, Goodridge Steel Brakelines, M3 Bumper, Black out grill, clear tails, M3 mirrors.
Old 10-27-2011, 04:10 AM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
diggin it.
just a question, though. what and where are you grinding othe vanos gear?? just the end (where it appears there used to be a torx bit??)
df
Old 07-21-2012, 06:12 PM
NMSDAD1 NMSDAD1 is offline
BMW Junkie
Mein Auto: 96 328I 99 328I
Very interested..
Could you post a video of this running?
Do you have any dyno numbers?
Old 11-23-2012, 04:01 PM
bosnianwog bosnianwog is offline
Mein Auto: 528i, 328is, 323i
So basically to get this to fit in my m52 i just have to grind down the m54 cam?
Old 11-24-2012, 09:46 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Cam specs will be
+ m54 rotating assembly
3.1 super stroke monster..
You have to remove 5mm from the business end.. (?)
Is this guesstimation.. or measurement?
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 11-24-2012, 01:47 PM
OrionsGate's Avatar
OrionsGate OrionsGate is offline
Forever Nerd!!
Mein Auto: 1995 325i
Nicely done, definitely interested in doing this when I get a chance.
1995 325i, 225K miles (yes!), 5sp, LSD, M3 cat back, halo projectors, H&R/Bilstein/etc. suspension overhaul, painted sideskirts...
Old 05-12-2013, 08:55 AM
jaguarx7 jaguarx7 is offline
DON'T PANIC
Send a message via AIM to jaguarx7
Mein Auto: 1994 325is
I'd like to know where to find one of these for $50, I've been looking for one for over a year and haven't found one for less than $350. I can find used M3 cams for less. Anyone know where I can find one for a decent price?
Cars are much more compact if you don't take them apart.
There is a theory which states that if anyone ever figures out how and why the universe came to exist it would instantly dissapear, and a less rational, more complicated one would replace it.
There is another theory which states that this has already happend...
Old 05-12-2013, 01:30 PM
ditoedt325 ditoedt325 is offline
Ragtopper
Mein Auto: 1995 325 i(c)
Thanks for the info
I thought e46 was more differenter.
Ragtopper
