Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here.
Old 11-04-2011, 12:19 PM
kanar200's Avatar
kanar200 kanar200 is offline
Mein Auto: was 530d, is X5d 2011
Do you think there could be adverse effects on warranty after coding? I like the new features, but I am afraid in case something happens with the car, BMW will refuse to fix it because of coding
can you also code pulsing panic stop brake light?
WTB: spare tire kit
Old 11-04-2011, 12:45 PM
hyde hyde is offline
Mein Auto: 2012 X5
Check this topic.
http://www.xoutpost.com/bmw-sav-foru...-my-e70-4.html
Old 01-27-2012, 06:46 PM
m3the01 m3the01 is offline
Mein Auto: '12 X5-35d AW-CI
Has anyone ever lost any of their initial settings after coding? Or does the backup process prevent this?
I assume we modify a version of the backup with initial features and code this to the ECU, is that correct?
Lastly, how long does the process take?
cheers,
'12 35D AW-CINN ZAP/ZC3/ZPP/ZTP/456-multicontour/2LE-20's/300-spare/220-self-leveling/4MS/752
www.playabonita.ca -- wifes bathing suit company -- pretty girls...
Old 01-28-2012, 10:42 AM
bmw718 bmw718 is offline
Mein Auto: Bmw/Infiniti
Coding. Nice job.
Originally Posted by blue dragon View Post
Coded:
1. Windows up / sunroof close with keyfob
2. Mirrors fold on lock with keyfob
3. Disable annoying iDrive disclaimer
4. Hazzard double blink (instead of flash, pause, flash pause, its now flash, flash, pause, flash flash, pause)
5. Foglights active with high beams
6. Corner light delete
7. Digital speedometer (Even though I already have HUD)
I still have to code the trunk close from the button inside and also the keyfob.
Great job. I am in Toronto, do you know where I can go to get this done.
J
Old 01-30-2012, 09:32 AM
blue dragon blue dragon is offline
Mein Auto: X5 35D
J
I could do it for you.
| ZCW | ZPP | ZPS | ZRC | ZSP | ZTP | 322 | 2VA | 456 | 4AD | 4UB | 610 | 655 | 6FF | 6FL | Combox + CIC retro |
Old 01-30-2012, 12:43 PM
X5SMW4.8 X5SMW4.8 is offline
SMW
Mein Auto: X5 4.8i well equipped
Does coding violate the warranty?
2008 X5 4.8 - Metallic Black, Sports Package, Tan Leather, Sports, Premium, Premium Sound, Tech & Comfort Access Packages
Old 01-30-2012, 02:17 PM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
No one knows.
Old 01-30-2012, 02:30 PM
SMW
I just had my car coded a few months ago and today I bought it in complaining about the comfort access to the dealer and they didn't seem to notice or say anything, so maybe there software doesn't tell them if some adjusted the mirror settings and what not.
Old 01-30-2012, 05:04 PM
apw2607 apw2607 is offline
Mein Auto: 2009 X5 35d
I would say doubtful. You're just changing parameters BMW have already set up, with either active or not active.
Unless they read each module and looked at the code it's doubtful they would know.
Old 02-14-2012, 06:04 AM
Mein Auto: X5 35D
I just added the LCI rear tail lights, and coded the car.
You will need to modify your FA (Vehicle order). You need to add +MUEH to the FA in CAS and FRM. You can follow the instructions here
Once you have done that, you need to code your FRM using the Expert Profile in NCS Expert (which doesn't allow .man manipulation files). This step codes the module so that it knows you are running the LCI tail lights and it disables the brake light out warning. This will reset your FRM and any coding which you previously had in that module, you will need to redo.
As an aside, my old tail lights are for sale
Old 03-01-2012, 10:02 AM
Thirdy Thirdy is offline
Mein Auto: E70, E46
Coded the rear inner tail lights (foglights or brake force display) to light up during normal braking. Also QMVH (lateral - moment distribution - axle) included when you cycle through your "BC" stalk. And the cluster light to be always on even when parklights or headlights are off or as soon as you start the car.
I don't see anything more about the "qmvh" but it's just cool to have it on the cluster. Maybe if somebody can try it when driving in snow and see if those lights beside the wheels changes to see which wheel has the most drive torque.
ID:	314691   Click image for larger version
Old 03-01-2012, 10:53 AM
Living's Avatar
Living Living is offline
Mein Auto: 2007 Z4 3.0si & 2012 X5d
Can someone code me a couple things in the Chicago area???
Old 03-01-2012, 10:57 AM
icuc's Avatar
Check your PM.
I can code most of the features discussed here and anyone interested from Wisconsin?
Old 03-01-2012, 10:59 AM
Mein Auto: E70, E46
There are a lot of coders at the e90 forums. Check them out. There might me somebody in your area.
Old 03-01-2012, 05:15 PM
Mein Auto: X5 35D
Very nice! Did you use NCS dummy to find the paramenters?
Old 03-01-2012, 07:15 PM
Mein Auto: E70, E46
Somebody already did these codings and went ahead and tried it.
Old 03-01-2012, 07:25 PM
tonka858 tonka858 is offline
Mein Auto: 2011 x5d
still looking for someone in San Diego..
but i know you need newer software for the 2011 .
Old 03-01-2012, 09:29 PM
Mein Auto: E70, E46
most coders should have upgraded to v41 already and it should work with your model year AFAIK.
Old 03-02-2012, 07:13 AM
icuc's Avatar
I'm using the latest version v45 Daten files and able to code 2012 model.
Old 03-02-2012, 08:04 AM
ayu910 ayu910 is offline
Mein Auto: Sienna
blue dragon, great write up! The M HUD looks cool, I search thru BMW coding forums but can't find any info on codes to enable it. Does active Digital speedometer (V=Digital Speed) enable M HUD or it is something else?
2012 750iAH Mineral White, Oyster Nappa with Fineline Matte Wood trim. Cold, Driver Assistance, Luxury, Instrument panel leather, Sdadowline and BMW Apps. 4.6sec 0-60, World's Fastest Street-Legal Hybrid.
2011 X5 50i M Sport Alpine White, Tobacco with Aluminum trim. Tech, Premium, Rear Climat, Cold packages. LDW, Smartphone, 3rd row and HUD.
Old 03-02-2012, 08:37 AM
Mein Auto: X5 35D
http://www.bmwcoding.com/showthread....highlight=mhud
Old 03-02-2012, 12:29 PM
CamberConfusion CamberConfusion is offline
Mein Auto: bmw x5
For the "E70 hatch open and close from fob"
Do all e70's have this capability?
I have never seen my e70 do anything like this. Mine is a manual open I think?
Old 03-03-2012, 06:04 PM
icuc's Avatar
Opening the trunk door can be done via remote and button inside the cabin but if you want to close them using the remote or the button then you need to code it.
Old 03-04-2012, 08:15 AM
///M Blitz ///M Blitz is offline
Mein Auto: M6, M3, DINAN 750iL, Z8
Guys I'm looking for the E70 V41 Daten Files.rar file, but it's been deleted from every place I can find. Does anyone have it and can email or know of download site? My email is card@mwrci.com. Thanks.
///M Blitz (AKA Dan)
- 88 M6 (33K mi - original owner)
"The best M6 in the World" - BMW Car mag. (Nov. 05)
**First place "Stock Class" Bimmerfest 2006
**First place "Stock Class" Bimmerfest 2011
- 89 DINAN 750iL (69K mi - original owner)
**Second place "Stock Class" Bimmerfest 2008
- 98 M3 (65K mi - original owner)
- 03 Z8 (8K mi - original owner)
- 12 X5 Diesel (dd)
Old 03-04-2012, 08:21 AM
Living's Avatar
Can someone tell how to unlock the DVD in motion in our X5?
