Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here.
Old 03-04-2012, 12:08 PM
slevit1 slevit1 is offline
Mein Auto: BMW x5 35i Premium
If anyone does coding near MD, I'd love to hear from you!!
Old 03-04-2012, 12:13 PM
///M Blitz ///M Blitz is offline
Mein Auto: M6, M3, DINAN 750iL, Z8
I can enter the coding sequence after typing “repxet” I can see the modules, when I select “car-keymemory” and check the boxes, I get the “konsistence check ok” message and after selecting “FSW/PSW” and checking the boxes again I get the “konsistence check ok” message. I set the profile name to “FSW PSW MAN” and all is ok; however, after I select F1 > then F3 and choose chassis e70, I get the following error message “VIN is faulty COAPI-2000 EDIABAS or SFBD Error. IFH-0018 Initializing failure of the Interface Handler.” If I input the VIN manually, I get a “VIN faulty” message.
Anyone else experience this? Any thoughts?
///M Blitz (AKA Dan)
- 88 M6 (33K mi - original owner)
"The best M6 in the World" - BMW Car mag. (Nov. 05)
**First place "Stock Class" Bimmerfest 2006
**First place "Stock Class" Bimmerfest 2011
- 89 DINAN 750iL (69K mi - original owner)
**Second place "Stock Class" Bimmerfest 2008
- 98 M3 (65K mi - original owner)
- 03 Z8 (8K mi - original owner)
- 12 X5 Diesel (dd)
Old 03-04-2012, 03:23 PM
blue dragon blue dragon is offline
Mein Auto: X5 35D
What version of ediabas are you using? Sounds like you have a mismatch between the daten versions and the ediabas version.
| ZCW | ZPP | ZPS | ZRC | ZSP | ZTP | 322 | 2VA | 456 | 4AD | 4UB | 610 | 655 | 6FF | 6FL | Combox + CIC retro |
Old 03-05-2012, 10:49 AM
Looks like Ediabas is Ver. 7.2.0. The daten files came from the "E70.rar" file that everyone claims to be V45; however, I'm not positive.
- 12 X5 Diesel (dd)
Old 03-06-2012, 05:28 PM
donce32's Avatar
donce32 donce32 is offline
Mein Auto: 2008 x5 4.8
How do I make my mirrors fold when I lock the car?
Old 04-18-2012, 04:14 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
Originally Posted by Living View Post
Can someone tell how to unlock the DVD in motion in our X5?
I just coded a 2010 X5 M series with VIM and its pretty simple but needs an extra step besides the normal NCSexper coding...You need to edit CIC file within NCSexpert daten folder of the E70.
Here is the PDF on how to activate it..
http://www.motor-talk.de/forum/aktio...hmentId=706804
Old 04-18-2012, 07:06 PM
bujjai bujjai is offline
Mein Auto: X5D 2011
hi
I could do it for you.
I would LOVVVVE to do some enhancements to the code too.... I'm in TO and have the same car as you....can you contact me at the email below and we can take it from there....thanks much!!
bujjai at gmail dot com.....
Old 04-19-2012, 04:28 AM
boostedX5SAV boostedX5SAV is offline
Mein Auto: 2012 X5
I just want to confirm, I saw an ebay seller selling the cable, he said it works on E70 up to 2010. Will it work with my 2012? Thanks.
Old 04-21-2012, 02:14 PM
mythroom mythroom is offline
Mein Auto: X5 E70
Smile
I just added the LCI rear tail lights, and coded the car.
You will need to modify your FA (Vehicle order). You need to add +MUEH to the FA in CAS and FRM. You can follow the instructions here
Once you have done that, you need to code your FRM using the Expert Profile in NCS Expert (which doesn't allow .man manipulation files). This step codes the module so that it knows you are running the LCI tail lights and it disables the brake light out warning. This will reset your FRM and any coding which you previously had in that module, you will need to redo.
As an aside, my old tail lights are for sale
Just joined this forum. And it's surprised to see that you had replaced your tail light of 2009 x5. I have same idea of changing it, but i am not sure if it looks nice in 2009 x5. Could you plz send me some photos of your car's look? Thank you.
mythroom@gmail.com
Old 05-18-2012, 05:31 AM
cafemosaic cafemosaic is offline
Mein Auto: X5 2012 35d
Are there any coders who can help with coding for side mirrors, rear hatch, etc in the Charleston, SC , Orlando FL or Atlanta GA areas? thanks so much
Old 05-18-2012, 12:04 PM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: Coupe
I might be in Atlanta this weekend, I'll send you a PM
Old 05-29-2012, 04:16 PM
X5FX X5FX is offline
Stargate Champion
Mein Auto: 2013 X5 35i M Sport
anyone in Louisiana that can code?
Old 05-30-2012, 12:44 PM
Mein Auto: X5 35D
Old 05-31-2012, 03:26 PM
daveyfl daveyfl is offline
Mein Auto: Roadster
Originally Posted by boostedx5sav View Post
i just want to confirm, i saw an ebay seller selling the cable, he said it works on e70 up to 2010. Will it work with my 2012? Thanks.
+1
Old 05-31-2012, 06:35 PM
OOO
Mein Auto: Coupe
Originally Posted by daveyfl View Post
+1
If it is an E70 (which it is), then it will work. The reason the seller posts that is because the newer 2011+ BMW's are now F series cars (7 series, 5 series, 3 series, etc etc) and this cable will not work for those. The X5 is one of those exceptions.
Old 06-01-2012, 12:24 PM
Mein Auto: Roadster
thanks for the reply. So this one will work on a 2012 X5?
http://www.ebay.com/itm/BMW-K-DCAN-D...item3a7538e8dc
Old 06-02-2012, 04:52 AM
Mein Auto: 2012 X5
Yes, 2012 X5 is E70. I'm going to read up more about coding first before I buy.
Old 06-09-2012, 08:57 AM
molloy molloy is offline
Mein Auto: 2011 BMW X5 35D
Coded:
1. Windows up / sunroof close with keyfob
2. Mirrors fold on lock with keyfob
3. Disable annoying iDrive disclaimer
4. Hazzard double blink (instead of flash, pause, flash pause, its now flash, flash, pause, flash flash, pause)
5. Foglights active with high beams
6. Corner light delete
7. Digital speedometer (Even though I already have HUD)
I still have to code the trunk close from the button inside and also the keyfob.
Hello Blue Dragon,
Just purchased a set of 2011 OEM Y spoke rims to put on my 2011 X5, it seems like they must not match up (My car manufactured prior to 10/10) and rims with TPMS after 10/10.
Do you know how to code to remove TPMS Malfunction?
Old 06-09-2012, 03:44 PM
Mein Auto: X5 35D
^^ Do you want to disable the TPMS completely? Why not just buy the proper TPMS sensors?
Old 06-09-2012, 06:37 PM
I would prefer to disable than have to pay $150-200 plus a place to install them. I'd probably install when they need new tires though. What do you think?
Old 06-09-2012, 06:45 PM
Mein Auto: X5 35D
It is possible, but you need to modify your vehicle order and code some modules
Remove 2VB from VO and remove TPMS fuse
- Code CAS with VO (FA_write)
- Recode DSC, CAPPL/CIC, and Kombi for the new VO
Old 06-09-2012, 08:40 PM
Would that be something I would understand when I get the cable and being to code the vehicle? Looks pretty tricky right now! Thanks
Old 06-10-2012, 03:15 AM
Mein Auto: X5 35D
^^ Yes, once you get the cable and read the DIY guide, you will undestand what those mean.
Old 06-11-2012, 07:55 PM
Stargate Champion
Just noticed I can fold the mirrors by holding the CA touch pad on the exterior handle for a few seconds too.
2013 X5 35i M Sport
Old 06-13-2012, 01:34 PM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
Anyone increased the LED halo brightness to 13.7v? It is awesome. You can do by using nettodat file.
