Old 10-31-2011, 03:31 PM
mikoyan29 mikoyan29 is offline
Mein Auto: 745
Question for those ppl with 22" rims
i have 295 25 22 tires and i keep bending just the back rims i have 30s up front so my question is has anyone used 30's in the back? i dont know if it would rub my car is not lowered and im not going to lower it, i see ppl with 25 lowered so i would think 30 not lowered would be fine? any help is greatly appreciated
Old 10-31-2011, 07:12 PM
eb1968 eb1968 is offline
Mein Auto: 745li
I got 265 30 22 on my backs and my car is not lower it rubs only when you on the hywy and you hit those big dips not nothing to worry about I had them on for over 2 years but I have bent all my rims front and back and had them repaired
Old 10-31-2011, 07:50 PM
Mein Auto: 745
yeah if your are rubbing then im in trouble i believe i have 265 in the front but the rear are staggered and are wider 295 so i dont know how much room is left over moving from 295/25 to 295/30 i know everyone has 295/25 with no problems but im really tired of bent rims i actually havnt had alot but im not trying to have alot lol
Old 10-31-2011, 07:54 PM
kharripe kharripe is offline
Kerry
Mein Auto: 2012 BMW X5
wow post pictures of your car with 265 on the back on 22's ...i'm guessin not staggered
2007 BMW 750i Sport SOLD
2007 Infiniti M45 Sport SOLD
2006 Chevy Express G3500 SOLD
2012 Mercedes C300 Sport
2012 BMW X5 Sport Activity
Old 10-31-2011, 07:55 PM
Kerry
I'm running 265/30/22 and 295/30/22 only the driver side back rubs when I hit dips...changing to 305/25/22 real soon...
Old 11-01-2011, 12:28 AM
Mein Auto: 745
hey thanks for the replies...so kharripe your car looks lowered is it? any why r u changin to the wider tire isnt that why its rubbing?
Old 11-01-2011, 03:11 AM
W3l bad W3l bad is offline
You only live once
Mein Auto: 745i AC Schnitzer
No Problems
I have 265 30 22 on the front maily because if i go to 295s they rub when steering. And 295 30 22 on the back and have no problems. With the lower profile tyres that used to be run the rims took a hammering.
Old 11-01-2011, 07:18 AM
Kerry
Car is not lowered...=) rubbing from a 30 series tire...different brands have different sidewalls (lexani side wall smaller than pirelli..kuhmo is thicker than michelins..etc. not much but enough difference to make it rub and don't rub...I'm going to adjust the camber when I slap on the new tires..rubbing now from a bad camber
Old 11-01-2011, 10:25 AM
jgriffith007's Avatar
jgriffith007 jgriffith007 is offline
Mein Auto: 2009 750 Li
duplicate post, remove please
Sent from my SPH-D700 using Bimmer
Old 11-01-2011, 10:27 AM
I don't think the minimal increase in the tire will help. Our cars are so damn heavy, seems to bend easier than my past cars. I had bettr luck keeping the tires toward to high end of the psi, think 44lbs or somewhere in the vacinity
Old 11-01-2011, 10:24 PM
jrbeamer jrbeamer is offline
el chico teMido
Mein Auto: 7 series
Talking
ID:	299473I hav 245 30 in front & 295 25 on rear.....check out one of my old thread i put down rim size, brand ,etc.........bout the bent wheel,well u jus gotta b careful,i already fuk one of mine up.....but fukit thats the price to roll biggs....
Old 11-07-2013, 09:13 PM
marioeperu@yaho marioeperu@yaho is offline
Mein Auto: 745 LI 2003
how about 295/30/22 hi profile . I had 745 LI 2003 with 255/30/22 in front no problem . but 295/25/22 bent my wheel . so thinking change to 295/30/22 . what you thing??
Old 11-08-2013, 02:57 PM
I had 295/25/22 but bent the wheels maybe get a 295/30/22 see what happen ??
Old 11-09-2013, 06:12 AM
kmatthews kmatthews is offline
Mein Auto: 750li
You could go 285/30/22 in the rear also.
And I have the same problem as you on 295/25/22, every time I hit a pothole my rear rims and or tires always get jack up. Either a bent rim or a split tire on the rear inside and or I get ******* around the inside rim of the tire.
Old 11-09-2013, 06:18 PM
cb_tikka cb_tikka is offline
Mein Auto: E66, E39, E34
posted by mistake, please delete
Old 11-09-2013, 07:44 PM
yeah that next 285 30 22 hope be better because spend money in wheel repair nop is better spend one time in tire and drive more comfortable . thank for you reply. hope anybody used a 285 30 22 see what the experience with those tires ??
Old 11-10-2013, 06:30 AM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
offset will determine if it rubs more than tire size guys.
giving tire numbers does no good without knowing the offset of your wheels.
good advice posted above: make sure u are running around max pressure...anything under will help in damaging ur wheels when u hit potholes
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 11-10-2013, 11:42 PM
you right thank for you inf.
Old 11-12-2013, 05:08 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
DriftGirl is 100% right on this one. Really comes down to the offset of the wheels. And yes, people have ran 295/30/22 with minimal issues.
Old 11-12-2013, 09:15 PM
I'm running 295/25/22 on Vertini Hennessey rims. Car is lowered using Eibach pro springs. No issues due to offset and 44 psi in the rear. Just avoid potholes and railroad ties.
Old 11-13-2013, 10:41 AM
BimmerBrad7's Avatar
BimmerBrad7 BimmerBrad7 is offline
Mein Auto: 05 745 LI, 05 Acura RL
Offset has everything to do it with it. My old rims would rub in the rear with 295 25 series tires. My car is also lowered. With my new rims I don't rub at all. Also the type of rim accounts for alot if your rims will bend easily. I had a 6 inch lip with my old rims and rims with a lip tend to bend easier. That's why I went with a stronger rim, less delicate rim.
2005 BMW 745 LI Sapphire Black
22's, AC Schnitzer Kit, H&R Lowering Springs, Tinted tails and Signals, AC Schnitzer
Carbon Door Pillars, Cross Drilled and Slotted Rotors, Tuner Mod, Tinted Windshield,
30% Tint all the way around, and some other stuff I forgot.
22's, lowered, rims, tires
