Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 12-04-2011, 09:07 AM
Superhart1977's Avatar
Superhart1977 Superhart1977 is offline
Send a message via AIM to Superhart1977
Mein Auto: BMW 645CI
The way I see things is if it ain't leaking, don't mess with it. When you take the sensor, coolant does come out, lowest part of system
2005 BMW 645ci
Stratus Grey Metallic/Black int.
20" M6 replicas
2006 BMW 325ci Black
18" RPM rims
50% tints, Black grill, tinted tail lights
Eclipse double din Nav
Retired BMW's
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 12-04-2011, 09:19 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
Originally Posted by hipertec View Post
I wonder how the Home Depot O ring will hold up to the heat?
Can I just pull sensor out or will the coolant spill all over? Thinking about changing out just as a precaution..what do u guys think?
Sent from my Transformer TF101 using Bimmer
I have to agree with the comment surrounding will it hold up to the heat of the engine ? Rubber o rings can be of different material to stand up to the riggers of the engine, but for $3 it may well be an effective solution.............
Does my bum look good in this !
Old 12-04-2011, 10:03 AM
Di0nysu5's Avatar
Di0nysu5 Di0nysu5 is offline
Obsessive or Enthusiast?
Mein Auto: 650i Coupe
Yeah, that was my first concern too. I can bet the BMW o-ring is of higher quality for sure. But it did give out eventually. I plan on keeping an eye on it to see how long it lasts.
As for your second question, you've got to keep in mind that coolant will definitely fountain upwards (almost instantly after pushing the two clips on either side of the sensor) because of a small pressure that builds up in the system. I think its best to do it in the morning after the engine has been turned off for several hours and is as cold as possible. Try to use your palm to direct the coolant flow downwards into a drip bucket. You don't want coolant spilling on the ground making its way into storm drains, etc. Its toxic stuff. And also make sure to rinse off any coolant spills in the engine compartment.
Cyrus
650i Mods list:
Lumma Roof Spoiler
19" Miro M6 Replica Wheels
H&R Spacers - 10mm Front, 20mm Rear
MGP Custom Caliper Covers
M6 Custom Steering
SMG M6 Illuminated Paddle Shifter Retrofit
DCT Illuminated Shifter
14K HID Upgrade, White Angel-eyes, LED License Plate Lights
50% Huper Optik Ceramic Tints
OEM iPod Integration
In the Garage
BMW 650i
MB C63 AMG
Nissan Murano SL-AWD
Old 12-04-2011, 10:52 AM
Di0nysu5's Avatar
Alright, For those who are concerned about the O-rings at home depot, here is some additional research. Hope it helps:
I managed to find the approximate heat resistance rating of the O-ring sold at Home Depot. The brand I purchased is called Danco and its the #31 (click here). According to this page (click here), there are many O-ring materials with various resistance to heat and application suitability. Danco's o-ring is advertised as Buna N material (see here) which is supposed to have an operating temperature between -65°F to +275°F. So material wise it will hold up to heat just fine since water's boiling point is about 212°F if I haven't mistaken. Quality wise, I haven't been able to find much info on comparing Danco with other manufacturers but hopefully they aren't too inferior.
Cyrus
650i Mods list:
Lumma Roof Spoiler
M6 Custom Steering
In the Garage
BMW 650i
MB C63 AMG
Old 12-04-2011, 12:42 PM
Well it has been over a month with the o ring from home repo and not a drip, that is car been driven everyday for work. We shall see how long these last but for three dollars for a pack of ten you can't beat it
2005 BMW 645ci
20" M6 replicas
18" RPM rims
Retired BMW's
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 12-04-2011, 03:05 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Wow great work guys!!
mujjuman
Old 01-28-2012, 09:03 PM
DBLAZE's Avatar
DBLAZE DBLAZE is offline
Mein Auto: Jet Black e63
The Danco Replacement O-ring that I have listed here is a tried and true method for fixing this temperature sensor leak issue. The E46 3-series temperature sensor is the exact same part number and they've been using this method of repair for years now with great success. Users only have to change the O-ring once and never again. Most of the time, the sensor itself will outlast the life of the vehicle.
BMW E63 (Jet Black w/Chateau Red Interior, Sport Pkg, Cold Pkg, Nav, Logic 7)
-20" Status 931 Staggered Wheels (Black Lip)
-Continental ExtremeContact DWS XL Tires
-AC Schnitzer Pedals/Footrest
-Lumma Roof Spoiler (Painted)
-50% Smoke Window Tint
-5W Kaibird LED Angel Eyes
-Black Vinyl Corner Overlays
-K&N Air Filter
Old 01-30-2012, 08:17 PM
BMW645 Germany BMW645 Germany is offline
Mein Auto: BMW645 CI
Had the same issue, went to BMW, he said that they would change hose and sensor normally, I order the O-RIng, to make sure to get the right on. $3. I changed then also the coolant, because I mixed it with a another brand. Just want make sure not to ruin my internal sealing. Since then dry.
Old 10-13-2012, 04:45 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Wish I seen this before I went and bought the sensor from BMW for $45. They don't carry just the washer so I bought the entire sensor with new washer. This is great info. I will share with my fellow e65/e66 owners. Thanks guys!
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 10-13-2012, 08:21 PM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
Originally Posted by tampamark View Post
This is all great info, I am happy that you guys are posting the cause and fix. The simple O ring is the way to go. If the sensor is good and the hose is good I wouldn't replace either since it is simple enough to do if and when they actually fails. The O ring is obviously the weak link in the system. Another BMW engineer fail!
Certainly if I ever have a lower leak this is the first part I would check.
+1
I got a low coolant notice last night. I was going to fix it in a week or so but may dive in this weekend armed with this info
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato
BMWE65: 20x10 / 20x11 Asanti ELT
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS400:Air suspension,MAJOR A/V setup, 19"Leon Hardiritt
Lexus LS430: VIP , custom Air Suspension, 19" Amistad (SOLD 2012)
Old 10-21-2012, 12:38 PM
3Pedals_6Speeds 3Pedals_6Speeds is offline
Mein Auto: fun cars
I just did this o-ring replacement today, and was surprised at:
1) how little coolant came out (maybe 4oz) even though the level is full (engine stone cold)
and
2) how the sensor doesn't 'click' in or anything similar. I was left hoping it's in all the way. I guess that just shows how important that o-ring is to the seal.
Diagram a few posts up was money, helped me find the sensor with ease.
Drive fast, take chances.
Old 11-27-2012, 03:49 PM
trekwars2000 trekwars2000 is offline
Mein Auto: '06 750Li and '08 FEH
How are you guys getting to the temp sensor? Is any jacking of the car up needed? I am being told by the stealer that my lower rad hose is leaking and needs replaced on my 06 750Li. From everything I read on here I am going to assume only the o-ring on the sensor needs replaced and try that first.
Also, this would be on the bottom left side of the radiator when looking at the car from the front of it?
Thanks in advance.
My Garage:
2011-Current 2006 750Li
2008-Current 2008 Ford Escape Hybrid
Retired:
2006-2011 2006 325i
Old 11-27-2012, 06:28 PM
Mein Auto: fun cars
and
Follow up note. MY comment of the lack of a click became really relevant when I drove this around until it was hot and discovered that it SHOULD click in (the sensor), but I'd been too gentle with it. As soon as it got hot and pressurized, I had an empty coolant system.
So, if you do this mod, it is easy, just make sure you get that sensor all the way back in.
Old 11-27-2012, 06:29 PM
Mein Auto: fun cars
Thanks in advance.
I got at it from above. Doesn't seem like you can, but it will work.
