Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 11-04-2011, 10:44 AM
berta3rd berta3rd is offline
berta3rd
Mein Auto: 1957 vw beetle
635csi driveshaft noise/vibration
1989 635csi Installed reman driveshaft because of a constant vibration. The u joints were shot and the center support was completely gone. Test drove car and vibration was gone. Returned car to owner, next day owner complained that the car was making a thumping noise under the gear shifter. Test drove car many times and finally made it happen. Only on take off with heavy acceleration there is a knocking noise and vibration, only for a second or so. All other driving conditions no noise or vibration is felt. Removed and sent driveshaft back to reman, they sent a completely different reman driveshaft back. Reinstalled new driveshaft, same problem. Changed rear diff mount and engine and trans mounts, same problem. Going a little crazy here, please offer some suggestions, and don't say it's the rubber flex disc, this car doesn't use one. Thanks again
Old 11-04-2011, 05:05 PM
catso's Avatar
catso catso is offline
catso
Broken weld somewhere? Rear subFrame mounts? Rear dogbone links?
![/I][/FONT]
Old 05-19-2012, 01:50 AM
kerry gorman kerry gorman is offline
Mein Auto: 1987 635csi
hello, ive had a new drive shaft put in only to find out that when installed the balance welds where on oppissite sides of each other. the entire shaft was sent that way from bmw. very simple fix, none the less very aggravative figuring the bull**** out.
Old 05-19-2012, 04:57 PM
Bert Poliakoff Bert Poliakoff is offline
Send a message via Yahoo to Bert Poliakoff
Mein Auto: x5
Motor mount or trans mount??
Old 05-26-2012, 12:17 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Smile Drive shaft ?
When you say drive shaft do you mean prop shaft or as BMW call it carden shaft, When refitting a prop shaft on a BMW you must push the centre bearing assembly foreward to pre load the bearing and then tighten the nuts or bolts which hold it in place, If you do not you will get various vibrations so do this first.
Old 06-25-2012, 03:18 AM
pepepereda pepepereda is offline
Mein Auto: 1983, 633sci
Berta3rd: Have you found the problem yet? I have the same stuation only when taken of in 1st gear but not on 2nd or else even on under hard acceleration. Please advise if possible
Old 04-27-2013, 03:37 PM
Neversaynever Neversaynever is offline
Mein Auto: 2002 525i
Peter Newman, when you say refitting the propeller shaft and pushing the center bearing assembly forward, can you describe this further? I am about to be reinstalling the propeller shaft with a new front universal. I cannot for the life of me figure out how I will succeed as the universal needs to fit over the "centering" pin coming out from the transmission mounting flange. Do I need to move the engine forward, remove the entire drive shaft, or is there something much easier that I am missing?
Thanks,
Chris Lovell
CL
2002 525i 164k
1988 911 Cabrio
1986 911 Coupe (track car)
Greater Boston, MA
Old 04-28-2013, 12:13 AM
Smile Prop shaft fitting
Assemble the front coupling to the gearbox with the bolts slack and then fit the rear coupling again with the bolts slack then raise up and attatch the centre bearing assembly with the two nuts, Then tighten the front and rear couplings and you then need both centre bearing nut slightly loose and push both sides of the bearing mounts foreward two mm and this will pre load the centre bearing and then tighten up both nuts, Simple but VERY important, Have a very good day and happy BMW driving.
Old 04-28-2013, 01:13 AM
Mein Auto: x5
Also make sure the bolts on the guibo face the right way, 3 to the front, three to the back
Old 05-07-2013, 03:03 PM
mitchcornacchia mitchcornacchia is offline
Mein Auto: 1986 BMW 635 Euro
sounds like the hanger bearing. mine did the same rebuilt the entire shaft problem solved. MY shaft actually had a broken spoke on one of the universal joints. Broken but still ran all the way from Florida to NJ. BMW's are amazing when some parts are completely shot, they still run.
HTML code is Off
