E90/E91/E92/E93 (2006 - 2013)
Old 11-04-2011, 02:11 PM
Q&A Q&A is offline
Mein Auto: 328i
Car resistance on Neutral
Hello,
I decided to start a new thread rather than highjacking another one.
When I put my E90 on neutral in the morning and let it roll down my driveway, it will move very slowly, while every other car (small or large) will move farther and faster then my BMW. Anybody knows the reason? I asked at a the dealer once and they said my brake calipers were not touching the rotors and did not need to be adjusted. If they were, they said I would be able to smell it.
Has anyone else notice this?
Old 11-04-2011, 02:46 PM
///M-ratedE90's Avatar
///M-ratedE90 ///M-ratedE90 is offline
Ego writing cheques that
Mein Auto: Subaru Forester
BMW uses transverse electromagenetic induction cooling (DFUCT) on the transmission casing. At certain times of the year, approximately midway between the solstices and equinoxes, the magnetic field of the Earth can align with the residual rheostatistical magnetism in the transmission, if the car is parked orthogonally to this field, approximately East-West. When this happens, the induced electrical moment created by the car rolling through this magnetic field causes a minimal perturbation in the flux capacitance of the cooling mechanism, slightly magnetizing the cogs and slowing down their rotation. Normally, with the crank joined to the driveshaft, one doesn't feel this effect, however, without the much larger resistance of the engine to overwhelm the magnetic resistance, one might feel it.
"To suffer the penalty of too much haste, which is too little speed." - Plato
Old 11-04-2011, 04:08 PM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
^ agreed!
FYI: http://www.bimmerfest.com/forums/sho...d.php?t=561869
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 11-04-2011, 04:20 PM
dtc100 dtc100 is offline
Mein Auto: 2011 328i
Since the Earth magnetic field is shifting, soon you will notice your car rolls back as freely as others in neutral.
By the time you notice your car moves up the driveway by itself, in neutral, we, along with all life forms, would soon be all extinct
Old 11-05-2011, 06:04 AM
Q&A Q&A is offline
Mein Auto: 328i
Originally Posted by GarySL View Post
I read that thread, but this is different. The car is in neutral. I was just wondering if anyone else experienced this or I need to go back to the dealership.
Old 11-05-2011, 06:22 AM
Is it a manual or an automatic?
Old 11-05-2011, 08:57 AM
BobBNY BobBNY is offline
Mein Auto: 2011 328iX
I fixed this by.....
Agreed! I fixed this issue by redoing my driveway North-South. Problem gone!
BB
Old 11-05-2011, 09:17 AM
GarySL's Avatar
Why would anyone purposely attempt to move their car in neutral?
Old 11-05-2011, 09:25 AM
I actually thought about trying this in the morning, while I was parked on a incline. The engine was on, I put it in N, released parking brake, my car quickly started rolling back, I had to abort the experiment before hitting another car.
Old 11-05-2011, 09:36 AM
Savidio44 Savidio44 is offline
Mein Auto: 2007 335 I Coupe and 1967
Car Resistance in Neutral
The construction of the BMW transmission contains forty-one manestically spaced grouting brushes arranged to feed into the rotor slipstream a mixture of high S-value phenylhydrobenzamine and 5% reminative tetryliodohexamine. Both of these liquids have specific pericosities given by P = 2.5C.n^6-7 where n is the diathetical evolute of retrograde temperature phase disposition and C is Cholmondeley's annular grillage coefficient. Initially, n was measured with the aid of a metapolar refractive pilfrometer, but up to the present date nothing has been found to equal the transcendental hopper dadoscope. Undoubtedly, the BMW transmission has now reached a very high level of technical development. It has been successfully used for operating nofer trunnions. In addition, whenever a barescent skor motion is required, it may be employed in conjunction with a drawn reciprocating dingle arm to reduce sinusoidal depleneration.
Because of the above detailed explanation, it appears that your BMW transmission performance is normal.
Old 11-05-2011, 09:44 AM
Can I remind you that this is a family forum?
Old 11-05-2011, 10:24 AM
Q&A Q&A is offline
Mein Auto: 328i
Automatic.
Old 11-05-2011, 04:32 PM
1985mb's Avatar
1985mb 1985mb is offline
A pair of I6s
Mein Auto: E93 335i, E90 330i
Automatic.
Wtf are you doing rolling in neutral in a torque converter-equipped automatic?
How does a "Status-tician" live with himself while driving an entry-level grocery-getter?
2012 Mercedes-Benz E350
Prev: E90 330i, E93 335i, etc.
Old 11-05-2011, 05:41 PM
Practicing drive through car wash?
Old 11-06-2011, 05:10 AM
Q&A Q&A is offline
Mein Auto: 328i
I appreciate the replies but I think some of youu guys are missing the point. This is not something I do often o recommend others to do. I had my car parked on my driveway and one morning after turning the engine on I put it on neutral and let it roll down the driveway (50ft). I noticed it didn't move much. Then I tried with my wife's car (also an automatic) and it moved faster and further. Then I tried with a friend's car out of curiosity and it also moved much further. All I am trying to find out is if this is normal or there is sokething wrong with my E90 that is causing additional friction.
Thanks.
Old 11-06-2011, 02:51 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
Thanks.
I suggest you are using a bad test based only on "voodoo knowledge." Your car isn't designed to roll easy in neutral, so why does it matter whether it does? What would it prove if it does or doesn't roll easier than a different car? Nothing at all. You are testing the wrong thing.
If what you REALLY want to know is whether there's something wrong with your car, then put the car on the road and watch your MPG. Is it unusually low? Open the windows. Are there any squealing or scuffing sounds? If the car isn't deviating from normal performance, then there's nothing wrong with it.
If the car is too new for you to judge whether it is acting normal, then take it to a mechanic.
Old 11-07-2011, 06:10 AM
Q&A Q&A is offline
Mein Auto: 328i
Squidget, thanks for the reply. You said "Your car isn't designed to roll easy in neutral." I am not sure why that is, but your answer is all that I was asking for. I don't notice anything else wrong, but I had never had a car that didn't roll easily on Neutral.
Thanks.
Old 11-07-2011, 06:30 AM
hpowders hpowders is offline
IRS SUCKS!!!
Mein Auto: E90, Porsche 911, VW GTI
I believe it has something to do with the earth's magnetic field.
There is no more beautiful car on Bimmerfest than my gorgeous Forest Green Porsche 911 coupe!
Obama is an incompetent liar!
Porsche: Accept no substitute, unless you're poor!
The E90 sedan is the last in the line of great 4 door 3 Series BMW's. Too bad.
"The VW GTI remains and will likely continue to be one of the finest compact sports cars in the world." Christian Seabaugh, Motortrend, March 27, 2012.
06/02/2005-03/02/2013: 7 3/4 Great years on Bimmerfest!!!
Old 11-07-2011, 08:55 AM
SD Z4MR's Avatar
SD Z4MR SD Z4MR is offline
(formerly SD 335is)
I do this all the time. While the floor of my garage is flat, the driveway has a slight decline. If I need to move my S2000 to get to something in the garage I just reach in (top down) put it in neutral, and take off the parking brake while giving it a slight push. With my hand on the parking brake I just walk it out of the garage. Or, if the top is up, I get in the car and with my foot on the brake and the car in neutral, I just give it a push with my foot out the door. I've done this for 12 years with the S2000 and it's not the first car I've done this with. I also do this when I wash either car although the BMW is harder to get moving, being about 800 lbs. heavier. Why start the car for only 15 seconds when you don't have to?
Do you think that moving the car in neutral is going to damage it in some wayl?
Squidget, what is the source for your statement "Your car isn't designed to roll easy in neutral"? I've never heard this about a BMW or any car. I'm talking manual transmission cars.
- Tom
Old 11-07-2011, 10:50 AM
What you have described is common, I think the issue some people have is the OP does it while the engine is running.
Old 11-07-2011, 11:07 AM
sunny5280 sunny5280 is offline
Mein Auto: 2007 X5 4.8i
Why would anyone here have an issue with the OP rolling his vehicle in neutral with the engine running?
Old 11-07-2011, 11:46 AM
I have no idea. I think some people when they can't answer the question, they blame the person who raises the question in the first place
Old 11-07-2011, 01:49 PM
SD Z4MR's Avatar
(formerly SD 335is)
Well, in that case, if I'm in bumper-to-bumper traffic on a downhill, I leave the transmission in neutral and just let the car roll forward with the traffic, using the brake as usual. No need to put the car in gear to roll forward if gravity can do the trick. I don't see how this could hurt even if the car is an automatic.
- Tom
Old 11-07-2011, 02:03 PM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
Great, now even rolling down an incline in Neutral the 328i stands no chance. Even when the engine isn't involved it is too slow against the competition.
Next I'm getting a Camry...they come with a dog. At least something to get respect on the street.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 11-07-2011, 02:09 PM
I don't know if it will hurt the car, likely not but I just don't know for sure.
But it might hurt the fuel economy. I read somewhere that when the car is cruising in low speed and low RPM, the engine is kept "alive" by the car's momentum while the tranny is engaged, without gas injected and no firing in the chamber.
But in neutral the engine is running on its own, requiring small amount of fuel to keep the engine running at idle speed
brakes, coast, e90, neutral
