E34 (1989 - 1995)
Old 11-06-2011, 07:18 AM
jack_stose jack_stose is offline
Mein Auto: 1993 525i
metallic "ringing" noise on acceleration
93 525i, 5 spd, on acceleration and deceleration there is a loud metallic ringing sound from underneath. Don't hear it when revving in neutral. Any ideas?
Old 11-06-2011, 07:45 AM
JC540I's Avatar
JC540I JC540I is offline
Mein Auto: 95' 540ia-orient Blue
a tranny squeeling sound or a catalytic converter coming apart sound?
"Straight roads are for fast cars, turns are for fast drivers." -Colin McRae
Owned/own:
1995 M3-cosmos black(E36)
1998 528I-schwartz black(E39)
1999 328IS-steel blue(E36)
1995 540IA-orient blue(E34) 5/6 speed swap soon.
Old 11-06-2011, 12:52 PM
it's a ringing noise.... seems external, not muffled as I'd assume if it was internal to tran or catalytic conv. It's sounds almost like an old mechanical doorbell and is only evident when drive train is under stress.
Old 11-06-2011, 05:08 PM
ThoreauHD ThoreauHD is offline
Mein Auto: 02/1994 530i 8cylinder
You'll need to put it up on a lift and start wiggling transmission and exhaust mounts. Can't determine a ding based on forward and rear motion without getting under there.
Old 11-07-2011, 07:24 AM
Will do - thanks much
My mech seemed unable to find source, thanks again.
Old 11-07-2011, 08:18 AM
Banned
Mein Auto: car
Did you jack up the car, start the engine and rev through all the gear changes while your mech was under there looking?
Old 11-07-2011, 08:43 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Does it make a similar noise when you shut off the engine?
Take my advice, I'm not using it.
Old 11-07-2011, 09:17 AM
JC540I's Avatar
+1
My next question was similar. is it ONLY while accelerating or decelerating?
Owned/own:
Old 11-08-2011, 05:38 AM
Yep, the noise only lasts for a second or two and only when accelerating or decelerating. It happens around 1,500 rpm.
Old 11-08-2011, 05:39 AM
no
No
Old 11-08-2011, 06:25 AM
ross1's Avatar
Originally Posted by jack_stose View Post
No
I see. I was thinking DM flywheel but not now.
Without hearing I'm no help, sorry.
Old 11-08-2011, 11:38 AM
JC540I's Avatar
See if there is a way to take an audio or video recording of it. You will most likely get an answer then.
Sent from my DROID2 GLOBAL using Bimmer
Owned/own:
Old 08-01-2012, 10:02 PM
msidd msidd is offline
Mein Auto: E39 525
Did you ever figure it out?
Old 08-01-2012, 10:59 PM
President President is offline
Mein Auto: 1995 E34 525i A
ringing sound problem on E34
I have experienced a similar sound initially when I bought My E34 that was unused for almost 6 yrs but kept in running condition. Have run pillar to post including the Exhaust repairers where finally the sound was rectified to be from Brake Disk and pad on the front right wheel. There are 2 shims on either ends of the pad to have a snug fit within the caliper, but somehow one of them was found missing which was allowing the pad to rattle and give this kind of a ringing sound on revving the vehicle to get in motion from stop. I am sure that this is your problem 99%.
________________________________________
1995 E34 525iA 13K miles - My dream come true!
Old 08-02-2012, 04:14 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
could be center driveshaft support bearing and/or guibo
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 08-02-2012, 07:05 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
+ 1
Sent from my Desire HD using Bimmer App
Old 08-02-2012, 07:18 AM
You are Correct! That was exactly the problem.
It only took my mechanic a few minutes to fix. Your diagnosis was perfect. You are truly enlightened! Many thanks.
Old 08-02-2012, 09:13 AM
Thanks again. I wanted to make sure you knew that your diagnosis was perfect. All good now. Keep the lights on over there! Jack
Old 08-03-2012, 12:58 AM
E30 above Sold
Old 08-03-2012, 10:19 AM
rdc rdc is offline
Russell
Mein Auto: 1995 525iA
This may be "pinging" under acceleration in ahigher gear with a load. Can happen if low octane or substandard fuel is used. This is also known as spark knock. Just guessing...
1995 525i auto, 1/95 build, EAT chip, abt 237K miles, , HID, Lumbar, Oxford Green/Parchment, rebuilt trany @ 211K
525i, e34, noise
