The X5 SAV Forum
Old 11-07-2011, 11:22 AM
2001X5Guy 2001X5Guy is offline
Mein Auto: Every WhErE
Angry Another Stereo Problem
While driving, my car stereo will go out. When this happens...
-The music volume will not respond, you cannot turn it up, down, or off.
-Some times the stereo display will turn off some times not.
-The Button next to my DSC button, The one that looks like a down hill cruse control? turns on and won't turn off.
-The message center in the cluster will not respond, it stops telling me to check my brake linings, it acts like every thing is fine.
-Some times when I turn on my head lights every thing will work again, some times not.
-Related or not, My stock alarm system is starting to act stupid. It will go off for no reason at all.
-Turn signals won't work when it happens.
Old 12-01-2011, 07:37 PM
bigwilly40 bigwilly40 is offline
Mein Auto: 2002 x5
Sounds like could be a battery issue..
Old 12-01-2011, 07:48 PM
Actually I found out what it was quite a while ago.
I waited until the problem was so bad it would happen immediately when turning on the vehicle.
Then I did the wiggle test on every connector and wire loom starting in the engine compartment working my way to the back.
I found a connector in the rear of the vehicle that was making all the trouble.
I disconnected it, sprayed Wd40 into the connector, and reconnected it. Almost a month later and the problem has not returned.
Old 12-23-2012, 10:31 PM
butundo butundo is offline
Mein Auto: 2001 x5 3.0
I have the same issues, as well as some others. What / where is the connector that was giving you the trouble? Mine seem to start after replacing the battery. Also, If I disconnected the battery overnight, it would usually fix the issue, but not any more
Old 12-23-2012, 11:00 PM
It's been a long time since I had that car, but it was in the left side of the trunk behind the removable trim piece...
There was a vertical connector in there...
With the vehicle running and radio on wiggle the connectors down there. And you should be lucky enough to repeat the symptom
Remove the connector and clean with wd40 and reinstall
Old 12-23-2012, 11:09 PM
Like I said, it's been awhile and it's 1am here, but what I remember it was on the left side, I think it went t the stereo amplifier or another box in that area
Old 12-25-2012, 10:23 PM
Thank you, I will try it tomorrow. I believe that is where the 6 disk changer is in my vehicle.
Old 01-11-2013, 09:00 PM
OzzyX5 OzzyX5 is offline
Mein Auto: 2006 X5 3.0d
How did you go with your radio fault?
Have had a similar fault with mine(05 diesel)
found to be the ignition switch, it affects so many different things (SOMETIMES)
and from what I am led to beleive it is a common fault.
