Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E90/E92/E93 M3 (2008+)
The latest and greatest V8 powered M3!
Old 11-07-2011, 07:47 AM
chrischeung chrischeung is offline
Mein Auto: 2012 ActiveHybrid 7 SWB
Summer performance tires driving in non-snow winter?
I have summer performance tires, and moved to Dallas this year from California. Having limited experience about tire compounds and treads in cold winter conditions, can someone please share if I need to be concerned about loss of grip due to temperature near 32 degrees F, if there is no snow or ice on the ground? Will the compound of the tire, which I expect is optimized for higher temperatures, will have really poor grip due to low winter temperatures? Should I drive the wife's car with all seasons on days like this? I expect I can ***** foot it around and find out for myself, but I'd like to avoid mistakes, or at least have an indication of what I'm in for.
TIA.
2012 ActiveHybrid 750i ED
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 11-07-2011, 10:53 AM
JG's Avatar
JG JG is offline
TTSam
Mein Auto: E92 M3 - 535 xDrive
TIA.
Here is a quotation from a Wheels.ca web site............+7C is equal to 44 degrees.
So basically when heading toward freezing the summer compound loses grip. Note the 44 degrees is in reference to all seasons not summers............
Having said all that I don't see why you would have problems in Texas other than a freak snow storm.
Once the average daily temperatures are over +7C, it is time to make the changeover to summers or all-seasons. Self-preservation should be the motive: the changeover may help you avoid a collision or a blowout.
All classes of tires - winter, summer and all-season (really three-season) - start life with quite different rubber compounds. Each is optimized for a different temperature range. If we run a tire outside of its comfort zone, it reacts badly.
Summer tires in winter turn hard as hockey pucks; in winter, all-season tires start to lose grip as temps drop below +7C and are virtually useless for grip below -10C. Winter tires lose grip as the temperatures climb above +7 C. Just as all-seasons wear tread faster in winter, winters wear faster in summer.
When in doubt - pass out!
E92 M3 AW
535i xDrive M Sports Carbon Black
911 Retired
328xiT Retired
X3 Retired
Old 11-07-2011, 12:41 PM
335i 335i is offline
Sup3rman
Mein Auto: '11 E90 AW M3/ '11 AW X5d
TIA.
I've driven in conditions similar, no snow, but cold - and you should be fine for daily driving. That said, if you push it, you'll experience reduced traction (because of the cold temps) so handling wise, you'll want to take it easy. The tires will become less grippy, and the back end will be even more prone to rear wheel spin (as if it's already not easy enough LOL).
2011 ///M3 Sedan Alpine White/Bamboo Beige/Piano Black ED 9/16/2011
2011 X5d Alpine White/Cinnamon/Bamboo PCD 6/21/2010
2007 335i Coupe - 6MT Alpine White/Saddle Brown ED 5/23/2007 (retired)
ED Trip Report W/ Pics (And Engagement Story/Pics)
Old 11-07-2011, 01:23 PM
CT's Avatar
CT CT is offline
GODSPD
Mein Auto: SSII E90 ///M, AW E92 N54
My PS2's end up requiring some reasonably significant warm-up time even on mornings where it's around 50F outside. I would be very, very cautious in the DFW area as the overpasses there are notorious for ice build up.
e90m / ssii / foxred / wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer / no chrome
WHEELS FOR SALE
Old 11-07-2011, 02:48 PM
tim330i's Avatar
tim330i tim330i is offline
Administrator
Mein Auto: Ti Silver 03 M3
Having driven more then I should in the winter with summer tires I can tell you that on clean pavement you'll be fine if you're gentle with the right foot. On snow/ice you're screwed. I could get stuck in a 1/4" of slush or the slightest ice.
Tim
The 2014 F32 4 Series Coupe Concept
BMW F32 4 Series Coupe on sale summer 2013
Old 11-08-2011, 06:44 AM
carman26 carman26 is offline
Mein Auto: '08 M3 Vert
Summer Tires in Winter (TX)
I would advise against using summer tires in the winter, even in TX...read the post below.
http://www.m3post.com/forums/showthr...r+tires+winter
Old 11-08-2011, 07:35 AM
1985mb's Avatar
1985mb 1985mb is offline
A pair of I6s
Mein Auto: E93 335i, E90 330i
In all fairness, 24 degrees in the wet is a lot colder and more treacherous (ice) than what the OP is talking about, 32+ presumably in the dry.
FWIW I have taken the OEM Bridgestone summers on 36 degree dry and low 40s wet. Obviously wasn't driving like a maniac but no problems driving 'like a normal person'--that being said, I will be getting winters mainly for the prolonged below-freezing temps as well as occasional snow & ice
How does a "Status-tician" live with himself while driving an entry-level grocery-getter?
2012 Mercedes-Benz E350
Prev: E90 330i, E93 335i, etc.
Old 11-08-2011, 08:08 AM
Basically I'm not going to drive the car on days below 40.
Old 11-08-2011, 09:30 AM
1985mb's Avatar
A pair of I6s
IMHO you will be fine. Unless the michelins or whatever brand you have react massively different to 40 degrees than my bridgestones did, which I somehow doubt
I would have gotten caught in last week's suprising "snowctober" storm but I waited till it was low 40s and sunny (nothing on roads except some water from melted snow) and was fine for a 4hr drive home
