Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 02-27-2012, 10:16 PM
831Doug 831Doug is offline
Mein Auto: 335d
I bought my 2011 CPO 335d in September with 15K miles on it. I've got 26K miles on it now, with no unscheduled service issues so far. First service at 24K was uneventful, except that I took the DEF down to the wire. Got a little rattle in the back that I need to chase down before I take the car in for its next service. Other than that a joy to own and drive so far.
Not related to a part failure, but I've also had to replace two windshields.
Old 02-28-2012, 06:05 AM
KarlB KarlB is offline
Mein Auto: 11 335d,08 K12GT,10 S1000
so far with about 29k miles on my less than 2yo 2011 I have had the following
1 wheel bearing (rear passenger side
1 wind shield (rock)
1 wheel speed sensor (front left if I recall correctly)
bearing ans speed sensor warranty, windshield out of pocket.
thats it other than routine maint.
and if I were in the market for a new car today it would be the 335d (since I cant get a 535d)
11 335d
2010 S1000RR
08 K1200GT
08 WR250R
Old 02-28-2012, 06:30 AM
GB's Avatar
GB GB is offline
Mein Auto: 335d, WRX, 325is, Eurovan
Originally Posted by cliffj View Post
However, I can't seem to get the USB port in the glove compartment to recognize any of 3 USB drives I've tired. All have been formatted in either FAT32 or FAT16 (the one BMW sent me). That will be checked at the "free" BMW oil change this week.
Are you trying to play music from the USB drive? That's not a supported function of the glove box USB port--it's only purpose AFAIK is to import/export music from the iDrive hard drive.
Graham
2012 328xiT
M-Sport/Manual/iDrive-free
Old 02-28-2012, 11:40 AM
Mein Auto: 335d
What was the symptom when the wheel bearing went out? Vibration/noise?
Old 02-28-2012, 02:16 PM
typical grinding noise that changed when turning right or left, was pretty obvious
11 335d
2010 S1000RR
08 K1200GT
08 WR250R
Old 02-28-2012, 08:00 PM
cliffj cliffj is offline
Mein Auto: 2012 X5 xDrive 35d
GB - No, I loaded music on the USB drive to transfer MP3's to the hard drive. My problem is that iDrive doesn't even recognize anything is plugged into the USB port. I've tried three different USB drives. Two were brand new. I am all Apple products at home, but that shouldn't matter. The USB drives were formatted as FAT32 when purchased. I know there is power to the port, because the light on the USB drive illuminates when inserted.
12 X5 xDrive 35d
Old 02-29-2012, 10:49 AM
swood02's Avatar
swood02 swood02 is offline
Mein Auto: 2015 X35D M-Sport
My SES light came on while traveling in another state over Christmas. Out of state dealer wanted to keep the car to diagnose and repair, but said it was OK to drive. Next morning light went off and stayed off till I got dealer to look at it a week later at home. Dealer found code 4035 stored for metering valve per SIB110210. Tech cleaned metering valve and reset light. Covered under warranty. No problem since; now at approx. 5500 miles.
2015 X35D M-sport
2011 335d: sold
2008 535xi: in lease heaven
Old 03-08-2012, 05:56 PM
oldgoalie oldgoalie is offline
Mein Auto: 2011 335d
New forum member. Been reading for a about a month since I got my 2011 335d.
Bad news, today with just over 3k miles, the SES light came on and the car started to run really lumpy. Fortunately my dealer got me in right away and they called today that there was a bad fuel injector which they replaced.
Makes sense with how it was running, but I was surprised an injector went bad.
Old 03-12-2012, 09:41 PM
dll2k4's Avatar
dll2k4 dll2k4 is offline
bimmerfest Supporting Member
Mein Auto: F30 328d
8000 miles: Rubbing sound in steering column during tight turns and parking space maneuvers. After 4.5 hours' labor it was solved with Lubrizol steering fluid additive:
CUST STATES THERE IS A RUBBING NOISE INSIDE THE STEERING COLUMN WHEN THE VEHICLE IS WARMED UP AND THEY'RE TURNING IN TO PARKING SPOTS. CHECK AND REPORT.
VERIFIED- TROUBLESHOOT NOISE- WHEN LISTENING WITH STETOSCOPE IT APPEARS THAT THE NOISE IS COMING FROM SOMEWHERE IN THE STEERING SHAFT, R+I LEFT KICK PANEL ABOVE PEDALS TO ACCESS RUBBER BUSHINGS- PEEL OFF RUBBER BOOT AND LUBRICATE PLATIC BUSHINGS. NOISE SEEMS TO GO AWAY BUT THEN AFTER SHORT TEST DRIVE COMES BACK AGAIN. R+I STEERING SHAFT, PULL UP PLASTIC SLEEVE ON STEERING GEAR AND LUBRICATE UNDERSIDE, REASSEMBLE AGAIN, NOISE SEEMS TO BE GONE BUT COMES BACK AFTER SHORT ROAD TEST.
ADD LUBRIZOL TREATMENT TO POWER STEERING SYSTEM. RECHECK- NOISE SUBSTANTIALLY LESS OR ALMOST GONE. RECOMMEND DRIVING SO THE FLUID CAN LUBRICATE ALL SEALS.
Next up: 340i ED - Summer 2017
'14 328d: EBII/Black, ZMM, ZDH, ZDA, ZPP, ZLP, ZTP, ZCW, 2TB, and 688
Summer 2014 European Delivery blog: 3107 miles in 4 weeks
Summer 2011 European Delivery blog: 4898 miles in 6 weeks
BMWCCA #430922
Old 03-13-2012, 10:59 AM
Alpine300ZHP Alpine300ZHP is offline
East Coast Commuter
Mein Auto: M4/X6
12k miles and two issues repaired outside of routine. 1) A/C fan belt along with pulley system. They replaced pulley and tensioner and belt. No problems since. 2) Start/Stop button was peeling and was replaced. Told wifey to use fingers and not long nails to start/stop it. No more peeling now!
~ 15 M4 (Mine)
~ 16 X6 (Hers)
- Previous BMW's - Way too many to list here (21)
Old 03-14-2012, 05:21 AM
digitaldav digitaldav is offline
Mein Auto: 2009 335d
I also had mine replaced @ 8000 mls. Right front. Mine sounded as if I had a noisy tire. At around 45-55 mph.
Old 03-14-2012, 05:42 AM
DC-IT DC-IT is offline
Love my Diesel Vehicles
Mein Auto: E350BlueTec, Jetta TDI
Last month with 4,900 KM to go before the next oil change my LOW DEF warning came on so I bought a 1 gal can and poured it in and it's all good to go for now till the oil change.
So far with 75,000 KM the D has been a great joy to drive and I do not see any suitable replacement unless the F30 comes with a 320d which might be tempting in a few years.
DC-IT
Current Rides:
2013 E350 BlueTec
2011 VW Jetta TDI
Old 03-14-2012, 03:07 PM
ljgmdad ljgmdad is offline
Mein Auto: 335d
On the wheel bearing replacements, what was the symptom when you guys detected the problem?
Thanks.
2011 335d M-Sport Alpine White Sedan
75% city mileage, A/C always on
Old 03-14-2012, 08:12 PM
stoked335d stoked335d is offline
Mein Auto: 2014 S4
Front warped rotors replaced around 9K.
SES light-Metering valve replaced.
AC belt replaced.
-One Bridgestone summer tire replaced but this is due to a road hazard and can't fault BMW for it.
Old 03-15-2012, 11:52 AM
FlyingLow78 FlyingLow78 is offline
Driving on instruments
Mein Auto: 2015 M3
I'm starting to wonder if I have a flaky RF wheel bearing as well. I hear more noise turning left than to the right, which would indicate to me the bearing is a little noisy. Also, first thing in the morning there's a noticeable clunk from that corner as I back out of the driveway onto the street. I've got a big road trip coming up in May, too, and I don't want any issues.
Old 03-22-2012, 08:37 PM
4pipes 4pipes is offline
Mein Auto: 2011 335d Alpine White
Got a adaptive headlight fault that wouldn't clear today. Could of lived with it but the damn warning is prominent in the middle of the panel and it doesn't go away. Took it in at 11:30am got it back all fixed and washed at 5pm with a loaner!
steper motor control module had failed.
Previous BMW's:
'79 530i, '93 325iC, '97 740i, '99 540i, '00 M5, '03 X5, '05 645i, '09 335d, '11 335d
Old 03-22-2012, 10:18 PM
Thanks.
It sounded as of a tire was bad. Louder than normal tire vibration noise. Noticable at 45-55 mph.
Old 03-23-2012, 01:34 PM
Mein Auto: 335d
Thanks. Sorry I noticed the same question was already asked/answered. Either tire vibration noise or a grinding noise when turning.
Old 03-25-2012, 11:21 AM
JAPearson JAPearson is offline
Mein Auto: 335D
2009 335d launch car stripped so to speak pleather etc but ofcourse has better tranny, HID's etc
rear view mirror, they can't seem to fix
adblu took two trips to dealer to have light go out
belt squeal, did not fix. "couldn't replicate"
front suspension clunking did not fix
Old 03-25-2012, 11:51 AM
Mein Auto: 2015 M3
Sounds like you might need to find a new dealer.
Old 03-25-2012, 06:54 PM
taibanl taibanl is offline
Mein Auto: 335d (e90)
Unplanned def fillup due to lost pump prime
Ac belt squeal. Two dealers to fix
Ac fail after above due to shredded belt
Gas mileage issue took 5 trips to 2 dealers to solve even though its right in the hidden bc menu!
Old 03-26-2012, 04:26 AM
meeksdigital's Avatar
meeksdigital meeksdigital is offline
Send a message via AIM to meeksdigital
I had this done too, right around 12k miles. The squealing was ridiculous, and it took 4 dealer visits to get it resolved, but they ended up doing the belt and pulleys (I think there's a service bulletin out on this?)
At around 6k I had a wheel replaced... it was cracked from hitting a pot hole. Tire/Wheel insurance covered it no problem.
That's all! Loving my D... trouble-free, fun to drive, and the best car I've ever owned, hands down!
2011 335d | Montego Blue | Saddle Brown Leather | Sport, Premium, Cold Weather, Convenience, Comfort Access | Harmon Kardon | Nav | Combox | (Delivered 11/24/2010)
Old 03-26-2012, 06:07 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '17 340iGT
Have put 7K miles on my former serivce loaner D and has not been back to the dealer since I picked it up (excluding the screw in a tire). But what do you mean about the mileage issue? You mean the OBC? Mine reads about 5% low (I get better than displayed), this can be corrected?
Old 03-26-2012, 12:13 PM
dagylca dagylca is offline
Mein Auto: 335d
Last week SES light came on. Car felt like it was missing at light throttle. 28K miles dealer replaced fuel injector
Old 03-26-2012, 01:22 PM
Snipe656 Snipe656 is offline
I had a sensor go bad around Mar-2010 and one specific to being a diesel, triggered an SES light. My guess is around 8-9k miles on the car but can't find the paper work to verify. The part number for the sensor was 13-62-7-808-013 and description was differential pressure sensor for exhaust system. That is the only diesel related problem my car has had. That sensor turned into a very frustrating experience that lasted around 2 months(1 month solid at the dealer) to finally get it resolved.
I did have some interior rattles and even my front dome light "fell" and had to be completely replaced but I think that is it. Had a low oil light once, they topped off the oil for free while doing other service. Had a low DEF fluid once but while it was far from time(mileage wise) for an oil change it was to the point of the yearly change so that was topped off for free as part of the oil change. I have had very randomly issues with the car not seeming to fully engage into reverse but they never could find a problem and not sure it even happened after the last software update to the car. I had a windsheild wiper blade break and become unusable but I just waited until the yearly oil change and had it replaced under the yearly maintenance.
So basically if I drove the car more back then I'd been faced with a need for windsheild wiper blades and DEF fluid well before the need for an oil change happened. So no idea if I'd had to pay for that out of pocket or if they'd been nice.
--Admiral Aaron Rouse
335d, cost, maintenance, mileage, unscheduled
HTML code is Off
