Discussion pertaining to the flagship BMW here. |
vacuum pump! please
guys,
im trying replace my leaking vacuum pump o rings...i have a replacement for both inside and outside o-rings. i already took the vacuum pump out, however, i just cant seem to get the 4 hex screws out to open.The screw are too tight, i even spreaded PB and let it sit for hours...it just wont come off! i dont even thing the inside o-ring is leaking.. can i just replace the outside o-ring, will this fix my leaking problem? |
Hey there, sorry I don't have an answer for you but I am about to replace my vacuum pump all together.. I believe it's making a tapping noise, and I am getting a bad oil leak in that location and have already changed the oil sender.. can you tell me where on these pumps the leaks form? I see all the oil below it, but where on the pump is it coming from? Thanks!
hey, not sure...exactly if the leak if from the inner o-ring, or the outer o-ring. there are 2 o-rings...i just felt below the pump and it had a lot of oil residue. not too bad to remove, i just cannot seem to get this stupid 4 hex screws off in order to replace the inner o-ring.
i spreaded some bolt loosen-er...let it seat for hours, they still wont come out..any suggestions? thanks
Well don't strip them.. I know we tried to get the bolts off my trans pan and they were torx and started to strip, and even broke a Mac tools torx bit and twisted a Snapon bit.. I don't know what kind of head they have on them but maybe try some clamps.. viscripts or however you spell them.. I don't know what the unit looks like or where you are working, but the only other things to get bolts out are spray or heat (torch).
