Old 11-13-2011, 07:36 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
How to make/borrow/buy lean-condition-misfire test tools (smoke, vacuum, & pressure)?
Lean-codes diagnosis DIY-priced test tools only!
Q: What are some cost efficient tools we can borrow, make, or buy (at DIY prices) to effectively test for lean-misfire conditions?
Specifically:
  • Can we make/borrow or buy a DIY-priced effective smoke machine?
  • How can we make/borrow or buy DIY-priced manifold vacuum test equipment?
  • Where can we make/borrow or buy DIY-priced fuel-pressure test equipment?
  • Can we make a simple propane source tester (combined with a DIY exhaust analyzer)?
This thread today, where an OP lamented spending over a thousand dollars (apparently throwing parts) on a lean condition misfire, got me thinking we need to point users to a comprehensive lean-codes DIY-test-tools-only thread:
- E39 (1997 - 2003) > $1,000 later, SES still on dont know what to do..
Specifically, this response, kindly supplied by Manybrews, hit the diagnostic nail on the head:
Originally Posted by Manybrews View Post
Why keep tossing parts at it? Diagnose it ... Use a smoke machine to check for vacuum leaks. Check crankcase vacuum ... and fuel pressure ... You can get a lot of diagnosis for 1000 bucks...
In summary, the purpose of this thread is to provide functional links to DIY-priced lean-condition misfire test equipment.
PS: I'm battling lean codes myself, and, to that end, here is a fuel-pressure tester I borrowed (for free, for 90 days with $160 deposit) from Autozone. But, I really should run a smoke test and manifold vacuum test first - so I need the results from this thread as much as anyone will.
Unfortunately, Autozone didn't have a smoke machine or manifold vacuum tester available.
  • Actron CP9920A, price = free
Please focus the discussion on lean-codes DIY-priced test tools only!
The lean codes needing diagnosis may be, for example, any of these:
  • P0171, BMW 227, System Too Lean (Bank 1)
  • P0174, BMW 228, System Too Lean (Bank 2)
  • P1083, BMW 202, Fuel Control Limit Mixture Too Lean (Bank 1 Sensor 1)
  • P1085, BMW 203, Fuel Control Limit Mixture Too Lean (Bank 2 Sensor 1)
  • P0300, BMW 62, Random/Multiple Cylinder Misfire Detected
  • P0313, BMW 238 to BMW 243 inclusive, Misfire Detected with Low Fuel
  • (any others?)
Last edited by bluebee; 11-15-2011 at 12:26 PM. Reason: Clarified the intention which is to discuss DIY-priced test tools for lean code misfire diagnosis.
Old 11-13-2011, 07:58 AM
Manybrews Manybrews is offline
Mein Auto: Car
Unfortunately, professional smoke machines are expensive. It does kinda place that out of the range of the average diy'er.
I don't know where one could be rented, either.
However, a manometer is cheap.
http://www.google.com/search?q=manom...w=1024&bih=672
All you need is one of those, then another oil cap with a nipple attached. You can easily test crankcase vacuum then, and find out exactly what it is?
Fuel pressure testers are also pretty cheap, depending on how wide you want to go with it (all cars? Bmw only? Etc).
http://www.google.com/search?q=fuel+...w=1024&bih=672
Old 11-13-2011, 08:44 AM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
I have a Mity-Vac hand-operated vacuum pump that can be used as a vacuum gauge. I think they cost about $50 now, but it looks like Autozone lists a similar pump as one of their loaner tools. Also, some fuel pressure test kits will read vacuum.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 11-14-2011, 04:42 AM
windsmith windsmith is offline
Mein Auto: 1999 540iT
Harbor Freight Tools is your friend
Examples, on their site, search for :
Fuel pump tester
Bearing puller
Pulley holder
No, they're not the best quality - but you're not going to be using them day in and day out, are you?
Last edited by windsmith; 11-14-2011 at 04:44 AM. Reason: Links not working properly
Old 11-14-2011, 07:51 AM
Fudman's Avatar
Fudman Fudman is offline
BB: Try using brake or choke spray to locate vacuum leaks. It actually works.
Old 11-14-2011, 10:33 AM
bluebee's Avatar
Yeah. I've done it. Personally, I think spraying stinks as a method (for details, see post #21 here).
- How to diagnose a BMW E39 misfire (1)
First off, there is a huge variation of the volatility of the sprays, secondly, I can't hear a thing change when I do it, even though I practically soaked the engine, thirdly you have to know all the places first before you can spray them and some are inaccessible and most people don't even know where they are (least of all me), and fourthly, the bounced spray makes a streaky mess of your windshield (especially when the washers aren't working).
I could go on - but, IMHO, the carb spray method isn't workable (at least by me, maybe because my misfire is hardly noticeable).
BTW, maybe I'm using the wrong stuff. What do you guys use?
Old 11-14-2011, 04:44 PM
You could try attaching a tube to a propane torch after covering the air inlet holes in the tip. Turn on the torch valve, and put the end of the tube where you think the leak is.
Granted, if the engine is not running rough as a result of the leak / misfire, this will have limited diagnostic effect. Some sort of monitor would be needed to detect any changes to fuel trim as a result of using this method.
Old 11-15-2011, 12:24 PM
bluebee's Avatar
While I inherently prefer the inside-out method of building or buying a (workable) smoke machine:
- How to build a $30 smoke machine to test for vacuum leaks (1)
Originally Posted by poolman View Post
a buddy that has a import repair shop is using this 30 buck smoke-machine gadget and he told me he had been using it for years--does the job and works just great. I'm headed to Spencers
what a great idea.
I should take your advice and exhaust the outside-in methods first.
I'll take my blue propane tank to the hardware store to see if I can fit a clear flexible tube over the end. How large of a "tip" would you fit onto the working end of the tubing (the end that touches the vacuum hoses)?
BTW, they seem to use propane in combination with an exhaust analyzer ... so I guess we have to add an exhaust analyzer to the mix of tools to look for:
- Random Misfire Page
- Engine Vacuum Leaks
Note: Some use kerosene or alcohol.
Old 11-15-2011, 03:46 PM
The 'tip' size is up to you - I would probably get one of the air blow guns from harbor freight with the 2 foot rigid aluminum extension (item number 68257, price $4.99) and attach that to the end of the tube. Now you have a 'wand' to probe into the engine compartment while you stand back and observe.
As for the exhaust analyzer, that's only for checking the operation of your O2 sensors and is not necessary for this test. For vacuum leaks, one only needs to monitor the idle RPM. Once the propane is pulled into the vacuum leak, the rpm will rise as the fuel / air mixture changes.
Old 11-16-2011, 02:33 PM
bluebee's Avatar
The wand seems useful, especially for the harder-to-reach areas in the back of the M54 engine where the vacuum endcaps and SAS electrical valve hoses tie to the intake manifold.
Most seem to use a simple glycol in water, at anywhere from 10% to 75% concentration ... which they then heat up with a heating element ... to make smoke (at least based on this site):
- MAKE YOUR OWN SMOKE FLUID
It looks like 'most' smoke machines use a simple 'glycol' as the smoke fluid:
  • glycerol (aka glycerine)
  • triethylene glycol (aka TEG)
  • Propylene glycol (aka PEG)
  • etc.
One problem (according to that site) is that some glycol-based smoke-machine fluids will leave a sticky residue, which I would think would be a 'bad thing' in the engine intake system - so we would need to choose well.
This Chevy thread shows how to make a $35 smoke machine from an aerosol spray can using a seven dollar AC Delco # 60G Diesel Glow plug as the heating element:
- Made a homemade Smoke Machine for Vacuum leaks
They create the 3 psi to 4psi pressure just by blowing into the tube (or using a 12 volt air pump).
Interestingly, the Chevy guys used 'baby oil' which is a simple 'mineral oil', which can be almost any light mixture of alkanes (the point being it is not a glycol).
Googling a bit, I find they're not the only ones using mineral oils:
And, no, baby oil is not made out of babies.
Old 11-18-2011, 11:08 AM
bluebee's Avatar
I've googled smoke machines and realized the similarities & differences - and I came up with my own idea for a smoke machine that is the simplest of them all (if it works).
There are three and two hole designs; but I have an idea for a one hole design.
These are the typical three holes for a smoke machine:
#1: You need an exit for the smoke to be piped to your manifold (usually connected after the MAF to the air intake)
#2: All seem to have a mechanism to generate pressure (about 2psi to 4psi)
#3: Many have a heating mechanism to generate smoke (the cleaner, the better, for the sake of your components)
The typical 3-hole smoke machine:
  • Is a metal container (typically a $1 paint can)
  • Which is filled with smoke fluid (typically a glycol)
  • Which is heated by a heating element (typically a $10 glow plug)
  • Which is forced out by air pressure (typically from a compressor or fan)
The typical 2-hole smoke machine:
  • Does away with the heating element (typically using a diesel soaked rag, burned and capped)
  • Some use dry ice for the smoke instead of the smothered soaked rag
My idea for the world's simplest single-hole smoke machine:
  • Creates both its smoke & pressure from the same action!
  • All it needs is a hole for the smoke to exit the container
I bought some of the parts already - and will attempt to create one or more of the smoke machines above to diagnose a persistent vacuum leak.
BTW, this article has a good description of smoke-machine fluids:
- Smoke Machine Chemistry
15%-35% food grade glycerine to 1 quart distilled water
125 ml glycerine to 1 liter distilled water
(glycerine creates a 'haze' at concentrations of 15% or less and more of a fog or smoke at concentrations higher than 15%)
Unscented mineral oil (baby oil), with or without water
10% distilled water: 90% propylene glycol (dense fog)
40% distilled water: 60% propylene glycol (quick dissipating)
60% water: 40% propylene glycol (very quick dissipation)
30% distilled water: 35% dipropylene glycol: 35% triethylene glycol (long-lasting fog)
30% distilled water: 70% dipropylene glycol (dense fog)
Old 11-18-2011, 12:16 PM
mkmichalek mkmichalek is offline
Mein Auto: 528i & 750i
How about a fogging machine. I think they use a water base solution. You would have to do some simple mods to it.
Old 11-18-2011, 07:50 PM
bluebee's Avatar
Our friend Poolman suggests exactly that, over here:
- E39 (1997 - 2003) > Smoke test
Old 12-18-2011, 04:53 AM
bluebee's Avatar
What would you suggest for the snorkel fitting & to power the glow plug?
Specifically:
While I had designed (on paper) a single hose smoke machine (using 20 psi CO2 vapor pressure for movement & dry ice for smoke) ...
I ended up buying the parts at ACE Hardware for
the 3-hole home smoke machine.
  • One empty quart paint can, ACE PN 16067, $1
  • One Autolite glow plug, PN 1111, $10
  • One hose barb, ACE PN 42776, 1/4 x 1/8 inch MPT, $4
  • One brass tank valve, ACE PN 11138 (38-900), $3
  • Four brass nut pipe-lock-nuts, 1/8 inch, ACE PN 4183174, $3 each
  • One 1/4" clear tubing, 3 feet, $1
  • TOTAL ~= $28
Any suggestions for the fitting to the snorkel & what to use for connecting power to the glow plug?
Old 12-18-2011, 10:48 AM
IIRC, photos I've seen of similar devices show a plastic lid on the end of the intake boot. I'd probably remove the air box and MAF. Then find an appropriately sized lid for the upper intake boot and use duct tape to make an air tight seal. You could put a hole in the lid, push the tubing through that and seal it with duct tape, too.
For power, I'd find a couple of alligator clips large enough the attach to the charging posts in the engine compartment. I'd fuse the positive wire going to the glow plug, but I'm not sure how much power those glow plugs take
Steve
OSRAM CBI
Old 02-10-2012, 08:39 PM
bluebee's Avatar
I picked up the alligator clips ... so now I should have all that I need to build the thing. I see our friend 540indiana is in need of a similar test - so - maybe that will be the impetus for me to find that round tuit and built it this weekend to see how well/badly it works out in action!
- E39 (1997 - 2003) > Anymore suggestions before I spend money on smoke test?
Old 02-11-2012, 06:11 AM
Fudman's Avatar
Here's another easy way to smoke test your engine. It's just a little hard to see anything.
ID:	311837   Click image for larger version
Old 06-01-2012, 04:10 PM
Trebbia's Avatar
Trebbia Trebbia is offline
Mein Auto: BMW E39 I6
My turn for misfires due to air/vacuum leaks.
I'm in the shop right now (Ray's Ultimate BMW in Santa Clara, CA) for the $150 smoke diagnostic test.
They removed all the rubber & plastic housings from the engine air filter back to the windshield, including the cabin air filter.
They left only the large rubber boot connected to the ICV, which they put a latex glove over the 6 inch opening.
Then they removed the endcap on the back of the M54 where they hooked up the smoke machine.
Looking from under the car, smoke immediately was coming out of the lower CCV hose (which had a half-inch crack in it).
[ I wonder why/how it passed my CCV test - I probably didn't look hard enough! ]
They quickly replaced the lower CCV hose ($100) and running the smoke test again.
[ I thought the CCV was hard to get to but they said they didn't have to remove anything. ]
They said they visually saw a crack in the small bent finger in the rubber boot connected to the ICV.
They were going to charge me over $200 to replace that $20 boot when I put a stop to this nonsense.
[ In hindsight, I should not have paid them $100 to replace the lower CCV hose! ]
I picked up the $20 ICV rubber boot at the stealer instead of paying the $200 for someone else to do it for me.
[ I'll need three cold-start drive cycles to erase the MIL. ]
By the way, with a smoke machine, they make this look so simple to debug!
[ In double hindsight, I should have just bought a smoke machine if I could have gotten it for less than around $400. ]
Do these home made smoke machines actually work?
Old 07-04-2012, 03:57 AM
bluebee's Avatar
I solved this a while ago but I realize I was remiss in not updating this thread so here's a quick update from start to finish on my various lean condition misfire codes ...
Specifically:
a) I first replaced all the rubber tubes/hoses/pipes/plugs I could easily get to in the engine bay ... which immediately helped somewhat lessen the frequency of the lean-condition misfire codes ...
- Where in the USA to get new vacuum tubing & vacuum caps (1) & what SAE sizes to get for all the metric M54 engine vacuum tubes, hoses, pipes, and caps (1) & correcting the F-connector errors in the realoem diagrams (1) & finding the ends of hard-to-locate vacuum tubes (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1)
b) I then ran a smoke test ...
- How to make your own smoke machine (1)
c) Which pinpointed a lower CCV vent hose leak ...
- Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (1)
d) I also unclogged the dipstick guide tube which was clogged solid (and perhaps was a reason for the CCV vent hose leak) ...
- How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
e) Lastly, I replaced the rubber boot which is connected to the ICV & TCV.
Those simple steps resolved my lean condition misfires!
BTW, while I rarely solve problems by replacing components without learning how to test them, I concur that one way to solve perplexing lean condition misfires, at this age of our bimmers, is to simply replace every vacuum-related rubber hose/tube/pipe/boot/cap/gasket in the engine bay.
Old 03-11-2013, 10:47 PM
bluebee's Avatar
Here is a great cn90 vacuum leak testing diy:
> E39 (1997 - 2003) > Found this Ingenious VACUUM LEAK Testing Trick
EDIT: Another DIY smoke machine was posted today:
Originally Posted by RainyRider View Post
Hi all, here is my version of a M54 vacuum system smoke tester.
Built it today with stuff laying around. I could never have come
up with this if it were not for this forum. Thanks all to contributors!
Tools:
Glue gun.
Something to cut hose.
Something to make holes in plastic.
A source of compressed air.
Parts:
Plastic jar with screw on lid.
5/8 plastic elbow (i used a tee).
5/8 rubber hose.
1/4 rubber hose.
Cheap cigar.
3/8 drive socket that fits cigar.
Assembly instructions:
Drill hole in center of lid.
Drill hole in side of jar, at top.
Glue together. Lol
How to use:
First remove air filter box and put a rubber glove over MAF.
Remove hose from brake booster (be careful, the connector is plastic).
Put cigar in socket, light it, screw on jar, shoot air (low pressure)
into 1/4 hose at top of jar to get it really smoking good.
Insert smoking end into brake booster hose. Look for leaks.
And I got the famous CCV hose to dip stick leak.
A video of using it.
And another:
Originally Posted by bkgreene39 View Post
Or you can use a cigar!!
Old 06-01-2013, 12:40 PM
lasshah lasshah is offline
Mein Auto: 2002 BMW 530I
Bluebee & RainyRider:
I have 2002 E39 530I, 13k Miles,
I need to perform smoke test, so I'm going to purchase and connect smoke machine from partycity to test vacume leak. Question for you if I follow RainyRider instruction "Remove hose from brake booster (be careful, the connector is plastic)" Q) which one is it in this picture (see pics from one of your other thread)
Thanks in advance.
http://www.partycity.com/product/fog...=smoke+machine
ID:	379694   Click image for larger version
Old 06-05-2013, 12:40 AM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
I watched mine getting done and IIRC they removed the MAF and shoved the smoke in from the big opening after the MAF.
It poured out of the boot just below the throttle plate and out of the CCV hoses.
Old 09-08-2013, 11:37 PM
bluebee's Avatar
I heard from other threads that Autozone runs smoke tests - so - if anyone here has one done, please snap a photo of where they run the hookup.
Old 10-05-2013, 12:57 AM
bluebee's Avatar
For the record, this was posted today
Originally Posted by dannydoo View Post
TOSSSING and turning I got an aha moment. For the cost of a soda bottle I can make a
smoke machine. CUZ NO ONE RENTS THEM FOR OUR CARS
http://www.bimmerfest.com/forums/sho...d.php?t=725748
If anyone been following my hell ride,I have only 2 more things to do out of about 25-30 tests i did to find a misfire that has no business being there.So........ I got this ez fast cheap idea.Prly better than a smoke machine. You can regulate the pressure and not get more than about 8lbs if u pushed hard and fast as possible.
Ill try my best to describe
Take a 2 or 3 or 1 litre bottle of soda. put aluminum foil around the top make it deep into the about the caps depth and rubber band it so its air tight. poke tiny holes in the aluminum. put tobaco or cigar in it the aluminum
make hole in side of bottle and rig up a hose.Be creative,use what you have.
cut the bottom of the bottle off.
get a pot or bucket and fill with water..but dont let bottle submerge past the water howeverr you decide what to use
submerge bottle down to its neck .Light the tobacco and pull upward...the suction will burn it and fill the bottle w smoke..
dont pull bottle all the way out,but high as u can.put cap on.
Now u have a full 2 litre bottle of thick smoke.
Use your tube you connected to the side and put in brakebooster or any vacume line.
as you push the bottle down the smoke will come out as fast or slow as you want..depending on how hard and fast you push the bottle down.
So you have 1 bottle in a pot of water filled with smoke and as you push down the water will force out the smoke if the caps on.
If you dot understand,Im sure plenty of people will chime in on the WATERBONG!! SMOKETEST
Old 03-26-2014, 02:39 PM
bluebee's Avatar
There is some new information about making a smoke test here today ...
> E39 (1997 - 2003) > Is my Head gasket blown?
Originally Posted by Svobodin View Post
I used dry Ice the last time I tried and had that go in to the air inlet boot right after the MAF. (I sealed off the MAF with plastic, to prevent damage to the MAF, and to create a sealed engine essentially so the pressure build up would be vented thru any leaks post MAF) Didn't really work well, but It was cold and I didn't really know what i was doing or looking/listening for. I do want to try it again with a DIY smoke machine as soon as it warms up.
And its not really the same as a vacuum gauge, which measures essentially the same thing that the same as your MPG gauge on the dash does, its just labeled differently. (as far as I understand) The vacuum gauge can be plumbed inline to any of the vacuum lines. I don't know what the proper readings would be, but the would certainly fluctuate with gas pedal depression.
lean codes, manifold vacuum, misfire, smoke machine, vacuum leak
