E60 (2004 - 2010)
Old 11-14-2011, 01:52 PM
Phoenix1 Phoenix1 is offline
Sleeper Wagon
Mein Auto: 2008 E61
Carbon build up in back of the valves
Wagon still under factory maintenance.
After free oil change and new f/r brakes and disks (neither indicated by iDrive...), I went to pick up car and SA said it was running rough, gave me a loaner for weekend. Told me today that there is "carbon build up in back of the valves " and BMW NA just authorized them to open the engine and physically clean them (vs injecting a cleaner?)
Does anyone know what causes this and how to prevent it in the future? (when I am paying for maintenance.) Car is driven mostly highway, I use Shell 93 octane gas.
2008 E61/Monaco Blue/Natural Brown/Premium/Sport/Logic 7/Sirius/Escort 9500ci, Conti DWS. Build Date 1/08. HPFP replaced 6/10 and 4/11 Fuel Injectors replaced 3/11. Battery replaced 5/11 (warranty), sunroof seal replaced 10/11 free under SIB 540409. Pads and rotors replaced 11/11 under maintenance. Carbon buidlup on valves cleaned under maintenance 11/11. 59K miles. Original owner. BMWCCA Member. Route 66 Easy Street Warranty.
Old 11-14-2011, 02:12 PM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E53, E60, E92
No prevention ala ole FI(fuel injection) engine, the N54 535i is DI (direct injection); no fuel goes/spray on top of the intake valve. Overtime it'd build up carbon there. Maybe, maybe long freeway drive may help a bit.
If all engine becomes DI, the oil company ought by-pass adding detergent to gasoline and pas the saving to us
Old 11-14-2011, 02:20 PM
Munich77 Munich77 is offline
Mein Auto: 2008 535 xi
Not much you can do about the carbon build up. I try to run my engine at high RPMs onces in a while when warm for a short amount of time (usually a minute or so) with hopes that it might clean up some of the carbon.
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 11-14-2011, 06:41 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
I assume that in the future they will introduce some fuel fogging system like the ol nitrous foggers to mist a bit of fuel in the upper intake to solve this o so common DI carbon build up issue. Every DI engine has this issue so there will be an industry fix
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 11-15-2011, 01:30 PM
bbal bbal is offline
Mein Auto: 09 535xiT
My car is having hesitation issues and the service guy is suggesting the same, but telling me BMW will not cover it under the warranty. Did you have to argue with them to get them to cover it?
09 535xiT 6spd DSB/NB
06 M3 coupe 6spd SG/BLK
08 Nissan Frontier Crew
98 Jeep Wrangler
11 Honda Odyssey
Old 11-15-2011, 06:59 PM
Fahrer's Avatar
Fahrer Fahrer is offline
Mein Auto: BMW 535i
I was waiting for this. Many 535 owners are in denial about carbon buildup in DI engines. This is the big "tune up" of the future.
2008 535i, Platinum Gray/Black, Cold Weather, 6 Speed Manual - History!
2012 VW Touareg TDI Sport with Nav. - Daily driver
2008 Porsche 911S, Silver/Black - Pride and Joy!
2003 MB E320, Pewter/Black, Cold weather, Logic 7
Old 11-15-2011, 08:23 PM
supratreo supratreo is offline
Mein Auto: 08 535i
i had a problem with "shuddering" at certain rpm's. i took it in and they told me i had the carbon build up problem. Walnut blasting the valves and intake ports and $550 later the cars runs better then ever. just a problem with DI motors like others have said.
Old 11-16-2011, 04:49 AM
x54.4blue x54.4blue is offline
Mein Auto: 2008 E61
Would running Chevron Techron Fuel System Cleaner, help?
Old 11-16-2011, 05:02 AM
Fahrer's Avatar
Mein Auto: BMW 535i
No. Detergent in fuel only cleans the intake valve area if the car has port injection. It might still help keep the injectors clean but that is a different issue.
Old 11-16-2011, 05:06 AM
Mein Auto: 2008 E61
Chevron Techron Fuel System Cleaner is supposed to reduce carbon build-up. If you are building carbon isn't the carbon coming from the fuel and therefore additive in the fuel should work?
Old 11-16-2011, 05:21 AM
Fahrer's Avatar
Mein Auto: BMW 535i
The carbon buildup is from oil vapors coming into the intake area from the positive crankcase ventilation system. These oil vapors are condensed/deposited on the intake area surface. With port injection the fuel ( with detergents) is constantly washing the deposits off the intake area surface, including the intake valves. With DI, the fuel is injected directly into the cylinder. Therefore, without any benefit of cleaning the intake area.
Old 11-16-2011, 05:59 AM
Can someone explain how this would not be covered under warranty? The car has 37K miles and is not operating to spec.
98 Jeep Wrangler
11 Honda Odyssey
Old 11-16-2011, 06:15 AM
Sleeper Wagon
Mein Auto: 2008 E61
Carbon buildup - cleaned under warranty
They did the cleaning under warranty, but it had to be authorized by BMW regional service rep since this service would have been $500+. You need to push your dealer.
If you need me to scan and send the n/c report I can. Send me a private note with your email address.
Old 11-16-2011, 06:19 AM
Sleeper Wagon
Mein Auto: 2008 E61
My dealer called and got approval from the regional service advisor to do this under warranty.
There is NO reason that BMW in one area of the country is doing this under warranty, but not the others!
We need to rebel!!!
Service manager said there was NOTHING I could do to prevent this - it is a symptom of direct injection engines.
Old 11-16-2011, 06:27 AM
Thank you...I sent you a pm. I'll keep you all posted. I'm selling this car to a very good friend, but told him I won't complete the sale unless I'm sure the car is in perfect order.
98 Jeep Wrangler
11 Honda Odyssey
Old 11-16-2011, 08:01 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
Is it only problem with turbo engines?
Because 545 and 550 has valvetronic system that is closed to direct injection engines.
BMW CCA Member, Capital Chapter
Old 11-16-2011, 09:46 AM
Fahrer's Avatar
Mein Auto: BMW 535i
It can be an issue with any direct injected engine. Any engines using intake port injection should be OK.
Old 11-16-2011, 11:54 AM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is offline
U of Dawgs
Mein Auto: 2008 535iA Sport
That only works on the injector. The carbon buildup is on the back of the valve and the stem. It being on the valve is not an issue, it being accumulated around the intake manifold leading to the valve intake is the issue as it restricts the airflow to the cylinder/chamber.
It can be done in about 2 hours uninterrupted if you DIY with a Dremel cable and a small wire brush with a good strong vacuum. Some people use solvent to soften the carbon but if you don't watch it you chance a accumulation of liquid in the liner and temporary hydrolock - solvent do evaporate after a period of time.
For Sh$% and giggles, son and I opened his N54 intake manifold to see what he has at 35K with a borescope - there is carbon buildup but nothing to worry about - yet. Some dealerships offer walnut shell blaster/cleaning for approx $500. I believe they do the intake manifold passages from the throttle valve downstream - (caveat) or so I am told. I may just do my own...
Nube1Kenobi
2008 535i Monaco Blue/Dakota Black/Dark Poplar | Sports Package | Premium Package | Cold WX Package | Navigation, Voice | RTTI | PDC | L7 | HD | I-Pod/USB | PWR rear shade | Sports Auto - paddles | Active Steering | Comfort Access | Fold Down R/seats | Rear DMS Airbags | Adaptive Xenons | Now with recalled and replaced -446 HPFP
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
Old 11-16-2011, 02:05 PM
Sleeper Wagon
Mein Auto: 2008 E61
Nube
+1 - Techron does nothing to help this.
The Service Manager showed me the buildup he was cleaning in another 535. The valves closest to the front were cleanest and they got progressively dirtier with lots more carbon buildup as you went towards the rear - a big difference! So if your are checking yourself...
Old 11-16-2011, 05:29 PM
U of Dawgs
The carbon build-up is not isolated to DI's as everyone knows. Since the advent of EGR and various schemes to reduce harmful emission by burning them, the intake manifold had become dirtier as oil and other blow-bys are directed to the combustion chamber. I replaced my Pilot's timing belt, seals, water pump and tensioner last month; then decided to lift the intake manifold to retorque the heads - at 100K the manifold EGR passages were about 90% plugged up and the EGR valve was a mess. The 3 hour job became a whole day job just brushing and cleaning using copper bristle brush and lots of naphta. So it's all the engines... just a little faster with DI's. It's the nature of the beast and no one can get away from it short of elaborate misting design in the intake...
Nube1Kenobi
Old 11-17-2011, 03:41 AM
Fahrer's Avatar
Mein Auto: BMW 535i
Your Pilot had 100K miles. I don't think one needs anywhere near that mileage to have such problems with a 535 or other DI engine. "just a little faster"? I doubt it. Detergent containing fuel must offer some benefit with port injected engines. A side note...premium fuel required by many engines often have higher detergent levels than regular fuel.
Old 11-17-2011, 12:33 PM
U of Dawgs
Believe it or not... fuel is not a factor here. Oil blow by is... the carbon contamination is relative to however efficient your cyclonic oil separator, labyrinth separators, or whatever other schemes manufacturers use to separate oil from the crankcase ventilation. Maybe we should start checking condition of our carbon canisters?
Nube1Kenobi
Old 11-17-2011, 01:06 PM
Fahrer's Avatar
Mein Auto: BMW 535i
I believe the fuel can be a factor in that it "washes" the oily film before it can build up and carbonize on the intake area surfaces if the engine is port injected.
Old 11-17-2011, 02:06 PM
Interesting link about this all:
http://www.autoobserver.com/2011/06/...-adopters.html
BMW CCA Member
Old 11-17-2011, 03:18 PM
U of Dawgs
That is the key... but even those engines are not immune to carbon build-up.
Nube1Kenobi
