Old 11-14-2011, 02:24 PM
redbull713's Avatar
redbull713 redbull713 is offline
Mein Auto: 96 M3 2/5spd
how do I remove the oil filter mount?
I have a 97 540i and the rubber mounts that hold the oil filter have sheared off. I bought the replacement(part 19 below) and can't tell what is fastening these things at the bottom.
Old 11-14-2011, 02:30 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
They unscrew out.
Old 11-14-2011, 02:31 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
Uhm, Nut #20 holds it in to the frame.
Old 11-14-2011, 02:45 PM
bimmerposer bimmerposer is offline
Bimmer Poser
Mein Auto: VW R32/Ducati 996
Part #19 holds the main oil canister housing assembly to the body mounted frame securely. Part #20 then screws from the bottom.
Part #19 (2 pcs of rubber coated screws) go thruone of the two holes in Part #21 to hold the housing in place.
Old 11-14-2011, 02:49 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
This is one of the cases where the diagram is misleading. Item #20 is actually on TOP...when you go to the car to look at your set-up...undo the srews on the top of #19...then just screw the bottom section out of the frame. The bottom of #19 screws into the frame that the reservoir is mounted to.
You can see the nut (#20) that is screwed onto the top threaded section of #19 in the pic below. Once you remove those two nuts...the reservoir is loose and can be moved out of the way. You then just unscrew #19 (or what's left of it) out of the frame:
Again, there are no nuts on the bottom of #19...the diagram has #20 (the nut) in the wrong location...as if they screw onto the bottom...when they actually screw on from the top:
Q {BMW CCA Member #191509}
(SOLD)
Old 11-14-2011, 03:36 PM
windsmith windsmith is offline
Mein Auto: 1999 540iT
I just repaired this same problem yesterday. Hammer and screwdriver. Place the flat screwdriver against the right edge of the metal plate that the rubber has sheared off of such that it will 'bite' into the disc when you rap it firmly with a hammer. The idea is to transfer the force of the hammer into an unscrewing motion. Mine came loose with 5-6 good whacks. Don't be afraid to hit it hard
Old 11-15-2011, 07:29 AM
QSilver7's Avatar
There's probably no need to whack anything...especially hard. If the rubber thingy (#19) has sheered in half...all you need to do is turn what remains COUNTER CLOCKWISE (you may need a pair of pliers) and the bottom half will SCREW out of the frame (#21). I'd try the "kindler/gentler" approach first...then move up the scale of escalated collateral damage.
The threaded bolt does NOT run all the way through the rubber...so if the rubber has sheered in half...both sections still have a piece of a threaded bolt...the lower section screws into the frame...and the top section is secured with the nut (#20). All you should need is something to grip the remaining lower piece of rubber (like a pair of pliers...or even your fingers (if you have Kung-Fu grip ) and unscrew it from the frame.
See the pics in my post above...you can see that nut (#20) is screwed onto the top threads of (#19)...when you remove the nut....the reservoir can be lifted off the upper part of #19...the rubber mount (#19) can then be unscrewed from the frame (#21)...whether it is whole or been sheered in half.
(SOLD)
Old 11-15-2011, 08:59 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
There are nutplates on the underside of the bracket. Hand-tighten the new rubber mounts into the bracket. No need to hog down on the upper nuts. Note that, after you remove the washers, the cannister will merely rotate away from the bracket.
Be sure to re-engage the lower rubber mount into its socket.
